OCCT power test shows a lot of error
56 (0.23/day)
Hungary
System Name PC
Processor I5 12400f
Motherboard Asus TUF b660m plus wifi d4
Cooling 3 intake, 1 outtake (these comes with the case) , intel stock cpu cooler ,
Memory G.skill ripjaws 2x16gb 3600mhz ddr4 (F4-3200C16D-32GVK)
Video Card(s) Manli rtx 3070ti
Storage Kingston SNV2S 1000gb
Display(s) Dell g2723H
Case IRID 503 ARGBv2
Audio Device(s) Including with monitor
Power Supply COOLER MASTER mpe-7501-acabw (750W)
Mouse Logitech g502 lightspeed
Keyboard Hama urage exodus 900
VR HMD NA
Software Windows 11 home (now)
Benchmark Scores Not benchmarked.
So, OCCT shows a lot of error when I first did a power test. After 30 min I tried it again and there was no error. How is it possible or what problem is that?
Update:
I wanna know that because I got errors in event viewer on a fresh new clean installed Windows. Yes I installed drivers correctly etc. Im using Windows 11 (nvidia support told me to do that). Errors I get:
56 (0.23/day)
Hungary
System Name PC
Processor I5 12400f
VR HMD NA
Maybe power supply provide uneven voltage. Did u notice anything strange during gaming?
Yes all time. Like the games are changing every time. Once it's slower once it's faster. I ran more CPU and RAM test didn't show any errors. When I apply power to the PSU, the TV that is turned on and playing a program will go black for a few seconds, but then it will come back on immediately.
dgianstefani
TPU Proofreader
5,402 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
Sounds like a PSU, electricity supply or socket problem.
56 (0.23/day)
Hungary
System Name PC
Processor I5 12400f
VR HMD NA
Since then I ran it again and still doesnt show errors. I really don't understand.
667 (2.83/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
+1 for sounds like power. If you've altered them, I'd try setting all voltages and power limits to stock and see if that changes anything. Power issues can be tricky, but are often replicable and repeatable if the psu is failing. It could very well be a software issue
56 (0.23/day)
Hungary
System Name PC
Processor I5 12400f
VR HMD NA
I didn't change any power limits, so it's stock. I don't know again I ran a lot of test to see what's the problem. I got no errors. But I still have problems with games. Like they're changing all time once slower once faster.
2,770 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Your home's electric installment might show problems when pushed by devices drawing much current at the same time and your PSU might get not constant power and you will see unstable performance. For sure a high quality PSU can alleviate some of that problem but not vanish it.
56 (0.23/day)
Hungary
System Name PC
Processor I5 12400f
VR HMD NA
Also, does anyone know what the problem could be, in Windows I get DCOM error 10010 and it's completely random. The network in the house is fine, it's just under loaded, but it should be able to handle a 750W power supply.
