OCCT PSU Test
anonemus
183 (0.03/day)
Davao City, Philippines
System Name Perpetual Upgrade Rig
Processor Intel Pentium Dual Core E5200 @ 3.5Ghz
Motherboard Gigabyte G31M-S2C
Cooling Scythe Ninja Plus, rev. B
Memory 2x2GB Kingston KVR DDR2-800
Video Card(s) Powercolor HD4650 1GB DDR3
Storage WD Caviar Blue 320GB SATA
Display(s) Acer X233H 23" 1080p LCD
Case Thermaltake V3 Black Edition
Power Supply OCZ ModXStream-Pro 500W (soon: Antec TPN 650)
Software Windows XP Pro SP3 / Win 7 Ultimate 32-bit
Folks, how exactly does OCCT tests a rig's PSU? When I tried this, my rig shutdown within five minutes :banghead:
429 (0.07/day)
Bydgoszcz, Poland
System Name "Złotko"
Processor AMD 1055T @ 3600 MHz
Motherboard Asrock 880G@890GX
Cooling Thermalright 120 Xtreme (lapped)
Memory A-Data 1600 Plus
Video Card(s) Asus HD6950 unlocked - WOW
Storage many more than you can imagine
Display(s) Acer AL1923 and Philips 40PFL5605H
Case Fractal Define R3
Audio Device(s) X-Fi Music / onboard
Power Supply Seasonic M12D 850W
Software viruses, worms, trojan horses, spyware, adware, rootkits
Benchmark Scores 2.3 promile of alcohol in my blood and still standing
This test stess everu psu line to the max. Maybe your PSU canot handle maximum amperage, that your computer can take. My old Tagan U15 530W died always after 20-30 min with 12V rail at 11.2V. This Seasonic takes this test without any issue.
295 (0.06/day)
Las Islas Filipinas
System Name SynChron
Processor Intel Core i7 3820
Motherboard ASROCK X79 Extreme 9
Cooling CoolerMaster Hyper 212X with 2 Noctua NF-F12 fans in push/pull
Memory 4x2gb Corsair Vengeance LP 1600 CL9
Video Card(s) Asus GTX 770 DCu2
Storage Samsung 830 128gb SSD, 1TB Western Digital Velociraptor, Seagate Barracuda 320gb 7200rpm SATAIII
Display(s) HP x2301 LED
Case Corsair Obsidian 750d
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X - 660Watt Gold
Software Windows 7 Home Premium 64-bit
+1 on the PSU not able to take the load of all the components. And also maybe the OC became unstable during the test...
anonemus
183 (0.03/day)
My old Corsair CX400W didn't have a problem with the OCCT PSU Test. But I was using a 4850 then.
I tried the OCCT PSU Test with my 5850 and OCZ PSU during mid day in my room with the aircon off, and twice my rig shut down.
I'll try again soon during night time with all settings at default, and aircon in the room at full blast, and with side panel cover off. This might help.
How exactly does OCCT load up the PSU test? Can it determine a user's PSU capacity? Sorry for the n00b questions
AsRock
TPU addict
18,962 (3.03/day)
UK\USA
Try getting extra cooling on the PSU see if it stops it from shutting down as the PSU might be overheating.
4,012 (0.74/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
The OCCT PSU test puts the CPU and the GPU under maximum load at the same time, which are by far the most power consuming parts of the PC. PSUs usually shut down when the temperature reaches a certain threshold or the PSU detects an over-current condition.
anonemus
183 (0.03/day)
Hmmm. I tried it again this weekend, this time with the room aircon fully on and side panel taken off. My rig was able to run stably with OCCT PSU test for full 30 mins.
I guess the PSU needs to be cooler when running on full load, or I need to make my case airflow better.
Thanks for the info, guys!
433 (0.08/day)
+1 on this
For your problem : Its most likely the PSU that gave up, but it can be a CPU/GPU oc stability issue.
anonemus
183 (0.03/day)
@ boulard -- I think my PSU doesn't perform that well when in high temp environment. It does say that its rated efficiency is at 40c. Corsairs rate their at 50c. The 80 Plus orgs test units at 25c no?
3,638 (0.62/day)
California
The thing is, if your rig doesn't shutdown during gaming then it's fine.
There's no point in testing the PSU if your rig's working just fine... Stressing your PSU will only hurt your pc.
p_o_s_pc
F@H&WCG addict
13,006 (2.06/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
my OCZ-mod-X 500 (same as you have) would make my rig restart after running the test for about 30min (see specs to see what was running) i put the Seasonic that is in it now and it runs for over an hour without a problem(stopped it after awhile)
433 (0.08/day)
False ... you should never use what you have as far as they are made for ? ....
Edit : If your PSU is really on the edge for your rig, i agree that you shouldnt load it like that too much, but your not really better when gaming ... you need a new PSU !
anonemus
183 (0.03/day)
That's the thing. My rig shut down a few times when gaming, so I tested with OCCT with regards to CPU, CPU and PSU.
I sure think Seasonics build better PSUs that Sirtec (OEM for my ModX). For my next PSU, I hope to get a Seasonic/Corsair unit
