Oculus Rift S USB 3.0 Issue (Please Help)
5,432 (0.90/day)
Australia
Hi everybody!
I have a odd problem with a clients PC and her Bday gift (Oculus Rift S) that wont work because of a USB 3 error, basically its plugged into a USB 3 port like your meant to but it thinks it is not a USB 3 port and or its saying its running at USB 2 speeds. Now what I think the issue is that its a Sandybridge System and on the gigabyte website it only has W7 official USB 3.0 Drivers and she is running windows 10 with im guessing an unofficial USB driver. Her motherboard is a GA-H77M-D3H which runs a Intel USB3 Driver and I cant find anywhere if there is a update for an official W10 USB 3.0 Driver. Does anyone on here have any ideas on this? or come across this issue before?
Otherwise I was thinking of installing a USB3.0 expansion card that has proper W10 support that might be able to fix or by pass the issue so she can use her Oculus Rift S.
:toast:
8,182 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
what does the Device Manager say? Have you tried other USB3 devices in the same port? Is there other software settings for the headset?
other thoughts:
checked the usb3 cable connection to the motherboard?
Is there a BIOS setting possibly set wrong?
5,432 (0.90/day)
Australia
other thoughts:
Device manager says its working fine and fully up to date with whatever driver Windows 10 has installed for it. No I havent tried any other USB 3 devices as I havent got the machine here with me sadly.
Its hard wired to the Motherboard and I also tried the front USB 3 port still no difference.
No BIOS should be fine as it was my old Motherboard I used but I run 7 on it and it worked fine with the USB 3
8,182 (2.19/day)
SE Michigan
System Name Dumbass
hmm.. I wonder about that, does the motherboard have a separate USB3 socket?
1,774 (0.61/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
When You installing Oculus Home make sure that your device is unplugged first and when installation is finished then plugged in your Rift in USB 3 port sometimes this can fix the certain issues...GL
Amanoe
1 (0.00/day)
Hello i'm litteraly having the same problem my motherboard is a Gygabites H310M S2H 2.0 i've been trying a lot of things to fix it (Clean uninstall + oculus install ; Remove the drivers ; Update every drivers ; Disable power management on the usb devices ; Disable legacy drivers ; rollback firemware) but i can't find a solution.
The weird part is that i didn't have a problem with it during my first three days and suddenly it stopped recognizing my USB ports (It doesn't make sense) i tried my oculus on my laptop and it's being detected so the rift works (i had doubts about the cable at first)
The only thing that i haven't tried yet is the reformat the whole system and make a new windows installation but i don't want to do that (Too much troubles). i sent a ticket to the oculus support yesterday still waiting for a replay but i think they're just gonna ask me to buy an USB 3.0 card.
If someone can help me here i'll be grateful thank you !
5,432 (0.90/day)
Australia
What do you mean exactly? It has a USB header and then your native USB ports at the back, thats it.
Yeah we tried many times this and other combos to see if it would work but it keeps saying that the USB 3 port isnt USB3
I was thining I can try another clean OS on it but I think getting a USB 3.0 add in card will be the easy way to work around this issue, well I hopeing it will be!
5,432 (0.90/day)
Australia
Well after all that it was just Windows 10 been a Sh@t and I had to wip it clean delete all the partitions and format it completely and it fixed the issue.
Bloody Windows 10!!!!!!!!
16 (0.01/day)
I have had the same problem for ages, Rift headset showing as USB 2 but it is plugged into a USB 3, 70% it comes up as USB 2 and the other 30% it comes up as USB 3, and today I noticed that now one of my sensors is showing as USB 2 and it is still plugged into the same USB 3 port it has been for over a year (I did have a windows accumulation update today so that's probably why my sensor is now showing as USB 2). When I click on to set up the Rift again and the circles go round whilst it is finding the 2 sensors and Headset, it all comes back as USB 3, then when I start oculus home it shows as USB 2. I am going to have to live with it as I really cant be bothered formatting and reinstalling windows. I definitely wont be buying another Oculus as they know about the problem but they just try and put it back on the user.
Headset USB 2.0 1st sensor USB 2.0, Headset USB 2.0, Headset USB 3.0 1st sensor USB 2.0, Headset USB 2.0 1st sensor USB 3.0
All screen shots taken after restarting my PC
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
powered USB 3.0 hubs are also a great solution and solved a stutter issue with my rift S on my ryzen 1400 system... the rifts are a little fussy when it comes to USB support
847 (0.37/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
afaik oculus (oculi?) don't like USB ports run off certain controllers, its best to plug into a native 3.0 port if you have one
Ruru
S.T.A.R.S.
12,340 (2.86/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 256+240+128+480+2x1TB SSDs + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p144
Audio Device(s) Corsair HS35
VR HMD Oculus Rift CV1
Running on a cheap ebay USB3.0 card myself and no problems here. Sensors are on motherboard's USB2.0.
Like said above, rebooting usually helps.
5,432 (0.90/day)
Australia
All 3 of these methods were tried and sadly none of those fixed the issue, in the end it was whatever USB3 driver that W10 installed just didnt work till the whole OS was reinstalled and the issue disappeared.
Im surprised people are still commenting on this thread haha
Ruru
S.T.A.R.S.
12,340 (2.86/day)
Jyväskylä, Finland
Checked the subforum and noticed this thread, better later than never I guess.. :D
Straycatuk
1 (0.00/day)
I had the same problem for a few days , tried different USB 3 ports all on my mother board , it didn't matter which one i tried , the rift kept declaring that it was in a USB 2 port , Tried different chipset drivers and different stuff ... what I did was go to device manager , universal serial bus controllers and uninstall all drivers and install generic ones for the USB ports , restart Pc then all should be good . if you find that the rift is still displaying that's its connected to usb 2 , uninstall only these drivers , Generic SuperSpeed USB hub and also Generic USB Hub . works for me everytime
5,432 (0.90/day)
Australia
I had also tried this method at the time and it still refused to work, the only solution (and i used a different HDD AND OS to test) was to reinstall W10 fresh on the PC and the problem went away and I havent heard from the client since!
CallMeNoah
1 (0.00/day)
Not sure about anyone else, but I am having the issue with the CV1, My sensors come up as 3.0 but when I swap them out with my headset USB cable, it shows as 2.0, I don't get why. I did multiple restarts, a windows clean install on a separate drive (didn't want to lose my data) and the same problem still occurs. Any ideas?
Mobo: MSI x570 Gaming Edge
CPU: Ryzen 5 3600
GPU 1070 Ti
OS: Windows 10 Pro
2,238 (1.05/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
i remember i had the same prob about two years ago with the rift saying it was usb 2 when it was plugged into a usb3 but the headset still worked allright it got resolved sometime with a update never noticed when but just checked and everything is showing usb3. not sure how this will help but thought id mention it.
Mindweaver
Moderato®™
8,240 (1.46/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Glorious Gaming Model D Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (128gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
I bought the preferred USB 3.0 card on oculus from Amazon. I had some issues with a 3.1 usb port. I'm lucky enough that I don't have any issue with my onboard usb 3.0, just the 1x 3.1 port.
Mussels
58,413 (8.00/day)
Oystralia
With the exact same hardware, changing the CPU from a Ryzen 1400 to a Ryzen 2700x improved the USB port detection issues... it's weird, but some are direct from the CPU so i guess it makes sense.
