OCZ Announces Ultra-High Speed 1200MHz Flex XLC DDR2 Solution
Bastieeeh
459 (0.06/day)
Germany
Processor Dual Xeon 2.8GHz
Motherboard Asus PCH-DL
Cooling Alphacool NexXxoS XP and Dual Laing
Memory 4GB Samsung
Video Card(s) Sapphire X800XT
Storage 8x Hitachi 7K250 Raid 5 and 2x WD Raptor74GB Raid 0
Display(s) Eizo 21" FlexScan T966 CRT and S1910 LCD
Case Lian Li PC-V2100B
Audio Device(s) Creative SB Audigy 2 ZS
Power Supply Tagan 480W TG480-U01
Sunnyvale, CA-April 17, 2007 - OCZ Technology Group, a worldwide leader in innovative, ultra-high performance and high reliability memory, today announced the PC2-9600 Flex XLC series. The latest edition to OCZ's esteemed enthusiast lineup implements the proprietary Flex XLC design and is engineered to produce extreme speeds with rock-solid stability. The PC2-9600 Flex modules are guaranteed to run at 1200MHz with ease thanks to the supreme component screening and thermal management of "Flex."
The new DDR2-1200 modules feature OCZ's original Flex XLC (Xtreme Liquid Convention) heatsink which delivers superior heat dissipation via a hybrid copper and aluminum design alterable between passive air or water cooling. The Flex XLC module was engineered with this unique "flexible" design to give enthusiasts the option to run the modules passively or water cooled via the integrated liquid injection system. The concurrent use of both technologies (water-cooling) promotes maximum heat dissipation. Thanks to OCZ's Flex XLC heat management solution, the OCZ PC2-9600 operates with an optimal balance of extreme speeds and low latency without the high temperatures that inhibit or damage the module's ICs.
"Memory performance is the key to system performance," commented Dr. Michael Schuette, VP of Technology Development at OCZ Technology. "In the complexity of today's workloads, both speed and density are important factors when it comes to choosing memory solutions. The PC2-9600 Flex XLC kits satisfy both needs by providing 2GB of blazing fast DDR2 for even the most demanding applications. Moreover, the flexible cooling solution that can be adapted to either water or air cooling guarantees thermal balance even under extreme data traffic conditions."
The PC2-9600 Flex XLC modules are optimized for the latest cutting edge platforms and will be available in 2GB (2x1024MB) dual channel kits. As part of OCZ's line-up of premium memory, the DDR2-1200 series is backed by a Lifetime Warranty and industry-leading technical support. Harnessing the performance of high speeds and leading-edge heat dissipation, the unparalleled design of the OCZ PC2-9600 Flex XLC is a complete, all-encompassing solution for today's performance-chasing enthusiasts.
For more information on the OCZ PC2-9600 Flex XLC Series, please visit our product page here.
  • 1200MHz DDR2
  • CL 5-5-5-18
  • Available in 2GB (2x1024) Dual Channel Kits
  • Unbuffered
  • OCZ Lifetime Warranty
  • 2.35 Volts
  • 240 Pin DIMM
  • 2 x 1/4" ID (inner diameter) barbs
  • FlexXLC Heatsink
  • 2.4V EVP
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
"All your base belong to us"
-www.Engrish.com
996 (0.15/day)
Kentucky
System Name Sony Vaio - VGNFW390-CTO
Processor Intel® Core™ 2 Duo Processor T9550 (2.66GHz)
Cooling Stock
Memory 4GB DDR2-SDRAM (DDR2-800, 2GBx2)
Video Card(s) ATI Mobility Radeon™ HD 3650 with 512MB vRAM (pitiful card)
Storage 320GB SATA Hard Disk Drive [7200 rpm]
Display(s) LCD 16.4" (XBRITE-FullHD™)
Audio Device(s) SupremeFX
Software Windows 7
"Someone set up us the bomb!"
Hahah thank you to that game for giving us humor...
5,147 (0.75/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
I like the water cooling setup, but it looks like 1/4" barbs, a pity.
WarEagleAU
Bird of Prey
10,812 (1.61/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Thats just some awesome looking memory. Im sure you could tighten the timings just a tad and still get it to 1200. Awesome stuff.
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Actually I messed up - it's
"All your base are belong to us"
