OCZ Puts SSD-HDD Hybrid Onto a Single Addon Card
46,953 (7.61/day)
While not the very first of its kind, Intel Smart Response technology took the enthusiast community by storm, offering a middle-ground between small but fast SSDs, and large but slow HDDs. By caching on the SSD, Smart Response is able to give system responsiveness a significant boost. Before that, HDD major Seagate put a tiny SSD component onto its Momentus XT hard drive, to chop access times a little. Now OCZ inverted the concept, and strapped an HDD onto its SSD to make it more capacious, on its new RevoDrive Hybrid.
Here, the major component is a SSD RAID 0 on a stick, which pools data onto an HDD. RevoDrive is a PCI-Express x4 SSD card, which uses a number of SandForce SF-1200 driven SSD sub-units in RAID 0 that's abstract to the host machine. The card is normally available in capacities as low as 60 GB, or as high as 480 GB. On RevoDrive Hybrid, OCZ installed a 2.5-inch hard drive with capacities as high as 1 TB, with the SSD component very much intact. The device promises to give you RevoDrive-like speeds, and humongous capacities, by streaming low-access data onto the HDD.
OCZ is using the Nvelo Dataplex technology to handle the SSD caching. The host machine sees the capacity of the HDD, while the card silently juggles data based on its access, between the on die SSD RAID 0 subunits and the hard drive. OCZ claims that the device can very much offer transfer rates of 575 MB/s read, and 500 MB/s write. While OCZ didn't finalize which HDD it will use, it is very pleased with the performance of this storage model, and could even use a 5400 RPM HDD in there.
The OCZ RevoDrive Hybrid will be available in two variants, the first one has 60 GB SSD component with 500 GB HDD, and the second one has 120 GB SSD component with 1 TB HDD.
4,113 (0.69/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
I'm scared to see the price tag:eek:
46,953 (7.61/day)
It will be between that of the 60, 120 GB RevoDrive, and the higher-capacity RevoDrives. The HDD will add just a $50~$100 premium, but there's also the hybrid technology. So I'd say they'll be priced more toward the non-Hybrid low-capacity RevoDrives.
9,244 (1.62/day)
Montreal, Canada
System Name Homelabs
Great idea IMO, I'd like to see Real-World performance of this
1,180 (0.20/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
Keyboard Logitech G710+
It would be good for mini PCs and notebooks, no need for drive bays...
Mindweaver
Moderato®™
8,224 (1.46/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Glorious Gaming Model D Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (128gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
This seems a little redumbnant... Don't get me wrong.. I like the speeds... but why not figure out how to make just SSD's cheaper... Not add another way for the drive to fail... This will just add heat and noise to the system..
1,162 (0.21/day)
Chicago, Illinois
Eh, finding the middle ground is never easy.
Mindweaver
Moderato®™
8,224 (1.46/day)
Charleston, SC
1,180 (0.20/day)
Australia
Case Corsair 850D
Most of the cost is in the raw nand chips, making silicone wafers is highly technical and expensive, and done mostly by machines. Its not easy to find a cheaper way to do it.
It costs tens of millions to build a new fab so its gonna take time.
FreedomEclipse
~Technological Technocrat~
23,790 (3.75/day)
London,UK
System Name Codename: RX-7878
Processor AMD 7800X3D
Cooling AM5 Contact Frame + Thermalright PS120SE
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Video Card(s) Sapphire Nitro+ AMD Radeon™ RX 7800 XT Gaming OC 16GB
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Or people can just buy a Z68 chipset mobo, a cheap SSD and make use of 'Intel Smart Response Technology' and save on having another expansion card taking up the space in their case.
Mindweaver
Moderato®™
8,224 (1.46/day)
Charleston, SC
You are missing the point all together... I understand that it's expensive, but why spend more money on old tech... I don't see it doing well.. Maybe a novelty.. Spend the money on making those highly technical and expensive silicone wafers bigger!!... I think we are capped at 300 mm. And there is always a cheaper way... :D
2,669 (0.49/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
i'm surprised they didn't use a WD VelociRaptor 600GB SATA 6Gbps. I think it would do better at keeping up with the SSD
11,878 (2.25/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
intels Z68'ssd cacheing system will net you 100-180 Mb/s read/write speed this will do 500+ each way as my ssd does, so i think they will do well, im never going back to os on hd,it kills me to use my htpc which has no ssd and is mind bogglingly annoyingly slow at times.
i do like the fact that it seems they have gone from pciex4(full sizexX16 to x1 as i dont like to use a full size pciex slot now as i could have stuck a gfx card in there and i only started with 3 x full size pciex slots
974 (0.18/day)
System Name Grond
Processor Ryen 5 3600x PBO ~ 4.4GHz / fabric at 1900
Motherboard MSI b550 Tomahawk
Cooling XSPC Raystorm CPU w/ am4 mounting bracket+ 2 RX360 radiator + xspc Razor R9-290 w/ backplate
Memory 32gb Crucial Ballistix @ 3800
Video Card(s) XFX R9 290 w/ XSPC Razor full cover block and backplate
Storage WD SN850 1tb-OS, SN750 1tb, Samsung 860 Evo 1tb, WD blue hdd 4tb
Display(s) Samsung 23" 120hz 3d LCD w/ 3d glasses, using 'lightboost' trick
Case NZXT H630 white watercooling case
Audio Device(s) Onboard realtek ALC 1200+ Sennheiser HD 598
Power Supply XFX Pro 850 XXX semi-modular
Mouse Logitech G703 Wireless
Keyboard Steelseries 6 v2
Software Windows 10 Pro (Had some mystery error on Win7 and decided to go W10)
OCZ Revodrive : Now twice as likely to fail!
471 (0.08/day)
System Name AMD Black Dragon
Processor AMD Phenom II X4 940 Black Edition
Motherboard Gigabyte MA790X-UD4P
Memory 4GB OCZ PC2-6400 Platinum (2x2GB)
Video Card(s) ATi Radeon HD4870 512MB GDDR5 w AC Twin Turbo
Storage Crucial C300 64GB SSD, 500GB and 2TB Drives
Display(s) Samsung 2494hm, Dell (Samsung?) 1907FP
Case Lancool (Lian-Li on a budget) K7
Audio Device(s) Onboard Realtek ALC889A, M-Audio Fast Tracks
Power Supply OCZ Mod-X-Stream Pro 600W
Software Windows 7 Home Premium x64, XP Pro
They would have been smarter to put whatever flash and SF2 controller they use into a standard Hard Drive. I'm sure they already had to "team up" with Seagate or whoever's HDD that's mounted on there. I mean why not have an OCZ/Seagate standard sized 3.5" SATA Hard Drive. Like those 2.5" Hybrid drives only bigger and better! I'm sure they could fit 1, or 2x 500GB Platters (1TB) into a standard 3.5" Drive size and still have enough room for Flash memory and a controller or two. Does PCI-e really offer more usable bandwidth than SATA III 6.0 Gbps can? Yeah the Z68 Intel chipset has that cool SSD/HDD hybrid thingy going on I was really hoping the new AMD 900 series chipsets would have something similar.
This is a fine idea sure. But mounting a Hard Drive on a PCI-e card looks kinda... I dunno, ghetto?
