Odd Corsair H100i readings
65 (0.02/day)
So I recently installed a Corsair H100i on my computer, at first it was doing something like this but as I found out it was a Windows 8.1 bug. So then I fixed it and the problem went away. Today, When I turned on my computer, My pump and temp readings were at 0. I know the H100i was still functioning because my cpu temps were where they should be, but now I can't change the LED, or change the fan modes. I've already tried uninstalling and re-installing the micro-usb that goes into the pump. Is there anything else I should do?
It is a bug with Corsair Link. It has basically lost communication with the H100i, but it never deletes things once it is added.
You can try clicking the "Check for Updates" button at the top of the devices page. That will have Corsair link search for new devices and hopefully find your H100i. You might want to check to make sure the USB cable is fully seated before doing this.
Also, make sure you have the latest version of Corsair Link: http://forum.corsair.com/v3/showthread.php?t=125350
View attachment 63208 View attachment 63209
I had the same problem there is a video on YouTube to sort this. Have a search.
