Oh boy here we go again...potential X3D woes
3,462 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Unfortunately GN talks about ASRock UEFI/BIOS versions but nothing correlating to AGESA version. In the past UEFI/BIOS versions might be different between motherboards.
From what I gathered UEFI/BIOS update after AMD AGESA PI 1.2.0.2a might be problematic at least for ASRock boards with 9800X3D
349 (0.51/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
110 (0.14/day)
Processor Ryzen 7 9800x3d
Motherboard Asrock X870E NOVA wifi
Cooling Noctua NH-D15 g2 LBC
Memory Gskill Trident Z Neo DDR5 6000 2x32GB
Video Card(s) Inno3d 4070 TI
Storage 4 TB SSD Samsung 990 Pro + 2 TB SSD Samsung 980 pro + Toshiba 18TB
Display(s) MSI MAG274QRF-QD
Case Antec Flux Pro
Audio Device(s) Creative Soundblaster AE-9 + Klipsch R-51 PM
Mouse Razer Basilisk V3
Keyboard Razer Blackwidow V3
No problem for me.
105 (0.07/day)
System Name desktop
Processor Ryzen 9800X3d
Motherboard Asrock Pro Rs
Memory G.Skill Flare X5 6000mhz cl30 1.35v
Video Card(s) Asus GeForce RTX 4080 TUF Gaming - OC Edition
Storage 2TB WD_BLACK SN850X NVMe
Display(s) Acer Predator 1440p
Case Fractal R6
Mine still hasnt blown up but the national web shop has incredibly low failure rates or returns, so might be a bit overblown issue.
3,462 (1.69/day)
Mouse Logitech M575
Bugged firmware would be my bet at this point. I long for the days you didn't need to update UEFI/BIOS so much.
977 (4.52/day)
It was a summary news piece. All information takes together in a video. In my point of view a few days too late, as I read about that asrock 9800X3d topic a few days ago here already.
I dislike the statement in the video to not update the Bios. My asus mainboard x670 has a lot of security issues. This is a very bad advice.
Steve could have said instead. Please do not update the bios on an asrock mainboard with the 9800X3d until we have more facts.
Steve also mentioned some other mainboard brands but he focused than most only on asrock mainboards, the 9800x3d processors, asrock japan and the firmware version history.
He also explained well that some reddit posters are not that well educated. A dead cpu will not revive with another uefi version. a dead cpu will have no post at all. POST = power on self test - a part of the booting process - a part in time what your computer does when you turn it on.
Last time i stated it was some sort of bad overclocking. Steve barely mentioned that. Overclocking is not supported. Not a cpu issue - it is an user issue.
3,462 (1.69/day)
Mouse Logitech M575
This was already written here in another topic
I just watched the video a few minutes ago.
I dislike the statement - do not update the Bios. My asus mainboard x670 has a lot of security issues. This is a very bad advice.
It's a catch22 situation with AMD. I want to update my UEFI to fix issues, but updating my UEFI might cause issues. Thank goodness flashback is pretty much a standard feature now.
True. More facts are needed. That video was messy in hindsight and arguably to prepare the audience for future clicks.
I must have missed it.
977 (4.52/day)
i think these wiht a quick search
In summary: More of the same topics. Same reddit user - same error mode. Different pictures. Some posts I got the impression the user on reddit has no idea about dram overclocking. 3 or 4 news posts were most only sourced by "reddit" by some "unkown" "newbie" "computer user" with barely any computer knowledge. We also had that situation when someone was unable to put a cpu in the am5 socket and turned it on. (my impression so far with -- reddit vs techpowerup vs asrock vs am5 )
13,726 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Sorry but no watching that video. No doubt it is another example of taking over 23 minutes to say something that could have been said in less than 5. :(
Anyone who watched it care to summarize for the rest of us?
3,533 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
IMO, newbies making mistakes is an opportunity to see how safety measures can be improved.
I feel like on first boot the motherboard should test the pins to ensure they are all properly aligned before sending voltage down the wrong ones. I feel like in general this would be useful for not just custom desktops but integrated products like laptops as well. There are instances where integrated products can be misaligned on the solder balls as well. Then again it should also be near impossible to install the CPU crooked. I feel like the socket design could be improved, I've never liked the idea that a single slip of the hand can cause bent pins in LGA designs (at least with the way we currently are required to install CPUs).
21,873 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000(Running 1:1:1 w/ FCLK)
Case Thermaltake Core X31
Software Gentoo Linux x64
This is all techtubers in a nutshell, only with at least 5-10 mins of commercial endorsements on some of the worse ones running around.
Anyways, I'm with you. I just don't have time for that anymore.
1,642 (2.15/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
There has been 1.2.0.3a Patch A in the meantime.
977 (4.52/day)
This is my point of view.
That INTEL CPU Socket which AMD copied is bad. Just bad. I replaced parts of the AM5 socket with a screwed one from Thermaltake. 8€ including tax and shipment well spend.
In my point of view, those am5 pins are more likely to get contact with other cpu contacts when the user is unable to properly place the cpu in the socket.
Less thermal paste residue where it does not belong. You see it already in that 1 year old picture. CPU stays in place.
AMD has a design problem with the am5 socket which are justified by some user handling. MY cpu will not move, it is screwed down. I trust screws more than this ordinary stock am5 socket.
the older am4 socket was more newbie friendly. Or let's rephrase it. A newbie would have bend pins and therefore prevented sometimes such fried motherboards.
-- A bit off topic:
You may read it yourself and than think about it please.
I classify that topic on igorslab as total nonsense in my point of view. I wrote there but I did not looked for any response.
DE: https://www.igorslab.de/amd-ryzen-9000-boot-probleme/
EN: https://www.igorslab.de/en/amd-ryzen-9000-boot-probleme/
The author claims to be
Chief Test Engineer at Cybenetics LTD
Ph.D. in Wireless Sensor Networks
Bachelor in Computer Science and Electronics
Never - ever touch a cpu on the pins or the contacts. use esd protection kit while working with electronics. Touch it on the side. there were too many unanswered questions. The hole topic on igorslab leads to an users faults in my point of view and a lack of proper training, understanding and education.
105 (0.07/day)
System Name desktop
Case Fractal R6
Well ive been through a few buggy bioses, so it could be possible but not seen any weird voltage behaviours yet.
43,886 (6.80/day)
199 (0.04/day)
When the best desktop launch of the past 12 months was arguably Zen 5 non-X3D, solely on the merits of it being an actual launch with real availability (not a paper launch), not a significant regression in performance, and not being prone to melting, that's a big oof.
15 (0.01/day)
All of the complaints were isolated to Asrock Motherboards. And point too buggy BIOS originating from the Board Partner. This should be straighten out soon with a few rewrites.
No Biggeee
freeagent
9,961 (4.22/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I just have to say.. because I am not using one, nor have I seen one irl..
But that offset mount looks janky AF.
3,462 (1.69/day)
Mouse Logitech M575
I'm not sure this picture makes sense. Were you reusing some 3 point Intel cooler for your AM5 socket?
21,873 (3.41/day)
Olympia, WA
System Name Pioneer
-- A bit off topic:
I can't believe you seriously just tried to critique a guy for touching the pins on a cpu and then posted... that mount...
I see two sins yes but that mount looks eggregiously worse than touching some pins.
3,564 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Well my 9800X3D keeps getting BSOD on cold boot, after the PC restart everything is fine, never crash during gaming.
535 (2.07/day)
System Name XPS, Lenovo and HP Laptops, HP Xeon Mobile Workstation, HP Servers, Dell Desktops
Processor Everything from Turion to 13900kf
Motherboard MSI - they own the OEM market
Cooling Air on laptops, lots of air on servers, AIO on desktops
Memory I think one of the laptops is 2GB, to 64GB on gamer, to 128GB on ZFS Filer
Video Card(s) A pile up to my knee, with a RTX 4090 teetering on top
Storage Rust in the closet, solid state everywhere else
Display(s) Laptop crap, LG UltraGear of various vintages
Case OEM and a 42U rack
Audio Device(s) Headphones
Power Supply Whole home UPS w/Generac Standby Generator
Software ZFS, UniFi Network Application, Entra, AWS IoT Core, Splunk
Benchmark Scores 1.21 GigaBungholioMarks
Ouch
