OK to daisy chain SATA power?
162 (0.29/day)
Motherboard Asus Strix B550-A
Cooling Be Quiet! Dark Rock 4
Memory Gskill Trident Z DDR4-3200 (16GB x 2)
Video Card(s) Sapphire Pulse RX 7900 XT 20GB
Storage Samsung 970 Evo Plus NVME 1TB (Boot), Samsung 970 Evo Plus NVME 2TB, Samsung QVO Sata 2Tb
Display(s) Aoc 31.5" 1440p 75hz; Asus 24" 1080p 75hz (secondary)
Case Be Quiet! Silent Base 802 White
Power Supply Corsair RM750X 2021 w/ Corsair Type 4 Sleeved Red Cables
I know most power supplies include sata power cables that have daisy chained connectors but is it actually wise to have two 2.5" SSDs running on the same cable? I figure it is but I wanted to check.
tabascosauz
8,209 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
SSD power consumption is low, they're not GPUs. I've been daisy chaining 2 or 3 SATA SSDs since forever on many PSUs and never had an issue. Even if you populate all the connectors it shouldn't even be remotely an issue as long as you have an even half-decent PSU.
wolf
Better Than Native
8,399 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
You will have no issues with two SSD's - imo. They draw so little in typical use and many PSU cables have 3-4 SATA power plugs which can be taken as an indication of how many they believe you can comfortably power.
3,441 (1.10/day)
Cooling Noctua NH-D15 Chromax
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Most SATA SSDs draw 3-4w full load and <1w idle. No PSU is going to have a daisy chained SATA cable that isn't capable of handling that level of load. Even if you had all large enterprise SSDs taking 13w each, it still would not be a concern.
13,566 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
That's not daisy chaining. Those are just "parallel" power connections. Each connected device is powered independently of the other. Disconnect one drive, the other still works.
Daisy chaining is a method of connecting devices in "series". That is, for example, you connect Device 1 to the computer, then you connect Device 2 into Device 1, then plug Device 3 into Device 2, Device 4 into Device 3 and so on. Disconnect Device 1 from the computer, all the other devices lose their connections too.
In computers, the most common use of daisy chaining is with USB devices. Many keyboards for example, use daisy chaining to provide USB ports on the keyboard. The keyboard plugs into the computer, your USB devices plug into the keyboard. That's daisy chaining.
And because daisy chaining devices are in series, if the connection from the keyboard to the computer breaks, the USB devices connected to the keyboard lose their connection too.
Another good example of daisy chaining is cheap strings of LED Christmas lights where you plug a second string into the end of the first, third into second, etc.
3,758 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I have never seen a PSU that doesnt daisy chain SATA out of the box, it is fine, I have splitters I have used as well as molex to SATA convertors.
13,566 (2.01/day)
Nebraska, USA
Mouse Logitech M190
You must have missed my last post. Again, that is not daisy chaining. You are not making a "serial" connection plugging one cable into the end of the other.
PSU cables support "parallel" connections to drives.
Nevertheless, your point is valid in that every PSU I have seen supports multiple drives on a single cable - they are just wired in parallel, not series.
Ruru
S.T.A.R.S.
13,229 (2.99/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Back in the day I had 4x 7200rpm HDDs in one chain without problems.
13,566 (2.01/day)
Nebraska, USA
Mouse Logitech M190
As long as the rail and first connector can handle the current, not a problem.
4,806 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
1,033 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
Don't worry, 2 SSD-s should be well within safe usage
3,758 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
I did miss it and dont dispute your point either, innocent mistake.
196 (0.05/day)
System Name Vaksdal Venom
Processor Ryzen 7 7800X3D
Motherboard Gigabyte B650 Aorus Elite AX V2
Memory G.Skill Flare X5 DDR5-6000 32GB (2x16GB) CL30-38-38-96
Video Card(s) MSI GeForce RTX 3080 SUPRIM X
Storage WD Black SN750 500GB, Samsung 840 EVO 500GB, Samsung 850 EVO 500GB, Samsung 860 EVO 1TB
Display(s) Viewsonic XG2431
Case Lian Li O11D Evo XL (aka Dynamic Evo XL) White
Audio Device(s) ASUS Xonar Essence STX
Power Supply Corsair HX1000 PSU - 1000 W
Mouse Logitech G703 Hero
Very late reply here. Just wondering, if the term "daisy chaining" is incorrect for this, then what should we call it?
Parallel chaining? Maybe "parachaining" for short? Or parallel wiring (parawiring)?
13,566 (2.01/day)
Nebraska, USA
Mouse Logitech M190
Already answered in post #6.
2,030 (0.77/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
while its ok to do,
when my ODD was on the same cable as 2 ssds,
the disks "unsafe shutdown" count was going up (crystal disk info; (back when still using sata, and wanted minimal wiring).
going with 2 cables fixed it, unless it was cosmic interference messing with me :D
13,566 (2.01/day)
Nebraska, USA
Mouse Logitech M190
Please note the OP was talking about the "power" connections. You cannot "daily chain" (put in series) devices (loads) on a "power" cable. You can daisy chain "data" cables, however AS LONG AS the communication protocols (in this case, SATA protocols) support it.
2,030 (0.77/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
i know its about power
i know its not daisy chained (never said such thing).
but i saw trouble when using a single cable for all 3 sata devices (1 ODD, 2 SSD).
and it wasnt the cable itself (new psu btw) and/or psu port, or problem would have stayed, as i only added on more power cable for the 2 ssds.
and i havent seen consumer disks having additional sata out (data), to even be able to do daisy for it.
