Open box i5 12600k?
52 (4.00/day)
I just bought this cpu and realized cpu inside the box was slided upwards and security side was taped. Shall I return it ?
13,499 (2.00/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Where did you buy it from? How was it advertised? As brand new or used?
You say "open box". Was that how it was marketed?
7,086 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
If it bothers you and you have an easy and free return then you should return for another.
13,499 (2.00/day)
Nebraska, USA
Mouse Logitech M190
If the seller is legitimate and will accept your return, then I would return it immediately. My worry is, if it was marketed as new, the box should not have been opened, there should be no tape, and no fingerprints on the CPU. This would make me question the legitimacy of the seller and I would worry I would not get my money back.
Good luck. And keep us posted.
52 (4.00/day)
Yeah it is a Turkish website like amazon and one of randıman seller. Customer service insta called the cargo guy to Come anc pick it up. The thing is we are running out of 12600ks and what's left is 12600kf and Which I her lots of failures. I will keep the post updated
