Optimising memory management to use cpu cache more efficiently
Status
Not open for further replies.
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Motherboard MSi H110-PRO-D
Cooling LC-CC-95 @ Arctic Cooling fan
Memory 2X Crucial DDR4 2400 4GB
Video Card(s) Integrated HD 610
Storage WD 500 GB + Seagate 500 GB + Toshiba 3 TB
Display(s) Lenovo D221
Audio Device(s) Manhattan Flex BT Headphones, Encore P-801 stereo speakers
Power Supply Corsair CX450M
Mouse microsoft office mouse
Keyboard Modecom mc-800m
Benchmark Scores gorstak @ hwbot.org
9,268 (3.34/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The cache is a hardware component that can't be disabled/enabled, not in modern CPUs and not by the operating system (and not under normal circumstances). If that would have been the case and the caches were disable your computer would be massively slower. This is probably a legacy thing for embedded use , don't bother.
10,440 (1.71/day)
Austin Texas
Processor 13700KF Undervolted @ 5.4, 4.8Ghz Ring 190W PL1
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
The cache is a hardware component that can't be disabled/enabled, not in modern CPUs and not by the operating system. This is probably a legacy thing, don't bother.
This
Also ur cpu doesn't have l3.
7,412 (2.89/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
seems my pc is running faster now, even my mouse movement is smoother
9,268 (3.34/day)
Case Phanteks NV7
Placebo. The caches on Intel CPU are inclusive, meaning that if one is disabled none of them would work.
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
not necessarily disabled, have you read the article? Simply put, windows memory management wasn't optimised for my system....it doeesn't touch the cache, it changes windows memory management.
FireFox
The Power Of Intel
7,507 (1.96/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
How it comes?
For sure not because you enabled l2/l3
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
is it a troll fest today? Read with understanding please. I didn't enable nor increase cache on cpu, I optimised windows memory management for my system. And now I'm noticing my ram usage and swap usage is way lower then what it was before restart.
9,268 (3.34/day)
Case Phanteks NV7
Believe what you want, I am trying to explain to you that on your CPU changing anything about the cache is not possible. The caches and their functionality are not exposed to the operating system or to any software, it's a hardware function that is transparent to the code executed. The only thing that I can think of about that registry edit is that it may enable some different code path for something that was compiled differently with other optimizations enabled.
But I am convinced it doesn't affect performance in any tangible way.
Download more RAM ? I have a feeling you're trolling. None of the things you say make sense.
Here is a link that was posted in the same article : https://msfn.org/board/topic/25766-registry-myths-2-setting-the-l2-cache-size/
This is not related to the hardware; it is only useful for computers with direct-mapped L2 caches. Pentium II and later processors do not have direct- mapped L2 caches.
SecondLevelDataCache can increase performance by approximately 2 percent in certain cases for older computers with ample memory (more than 64 MB) by scattering physical pages better in the address space so there are not so many L2 cache collisions. Setting SecondLevelDataCache to 256 KB rather than 2 MB (when the computer has a 2 MB L2 cache) would probably have about a 0.4 percent performance penalty.
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
I'm not sure what the issue is here. I might be writing in turkish and failing to notice it. Nobody touched cpu nor it's cache. What was changed was software, specifically windows memory management settings. This isn't a jesus being resurrected, it's a simple tweak for your os to work a few % more efficiently, maybe more, I don't know, since I didn't test it yet. There is probably a line in the code somehere that says something like for 512 then that....what I did is order that part of code to use for 3072 then that...
A simple optimisation, nothing else.
9,268 (3.34/day)
Case Phanteks NV7
Again, believe what you want. If you're convinced your PC is faster and is using less RAM, wonderful, I guess.
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
You can't make your cpu go faster, but you can make windows use 100% of it, instead of bottlenecking it...
and now i have to see if there is a hidden setting or something that will make use of RAM as additional cpu cache.
silentbogo
5,514 (1.41/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
https://docs.microsoft.com/en-us/pr...ro/windows-2000-server/cc938581(v=technet.10)
Scroll down to the end of the page.
These settings were obsolete since Vista (or maybe even earlier) and only for old platforms (probably the ones that still had controller for external cache expansion). Nowadays cache is fully managed in hardware (e.g. by CPU itself).
Plus, you have to understand that cache is not memory. You can't "use" it, it's just there to fetch and store some recently-accessed data while all you see from the "platform" or "user" point of view is memory(RAM) access. You don't even need to be aware of how much L1/L2/L3 you have or whether you have it at all, all you do is read from RAM or write to RAM and CPU does the rest.
dorsetknob
9,106 (1.28/day)
Of Course you Can :)
depending on Motherboard you can Overclock :)
you cannot increase the CPU l2 cache its fixed as its on CPU Die.
Time to Polish my Troll killing Club as its covered in blood and brains
11,878 (2.25/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Epic fail then bro.
ALLWAYS test before, record /save results.
Effect change.
Then retest and record/save results.
Then come on here and convince the world.
As has been stated , modern processors have extensive lists of settings that get read on boot.
Many registry keys are set to 0 by default because that default is auto.
And the auto behaviour to find out cache sizes by the os is to check the CPUs internal codes as it boots , same for core count.
The tangible gain's you say you have mean naught because you can't validate they happen.
Aquinus
Resident Wat-man
13,153 (2.87/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Show me numbers and I might be inclined to think about why, otherwise everyone else has already said what's on my mind. Windows has no control over if cache is used or not. That's up the the CPU or BIOS if disabling cache is supported, but most modern hardware doesn't let you disable things like L2 cache anymore because it would detrimental to performance and this isn't something that can typically be altered while the system is hot.
Anecdotal evidence is not evidence. Restarting your machine will always use less memory and swap because it's starting fresh. It's not like anything is cached in swap or anything. Use the computer for a bit and you'll see that number grow, even if you close everything you already opened.
newtekie1
Semi-Retired Folder
28,472 (4.16/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
These registry entries are from way back in the day, when you could actually add cache to the system manually. They are leftovers from the Windows 9x days. They don't do anything in modern versions of Windows, and haven't for years. The OS now reads the CPU and it's capabilities on the fly. Don't believe me? Open the modern Windows Task Manager on Windows 10, it will list the cache sizes of your CPU. So it knows what they are, and how to use them.
Kursah
Super Moderator
14,706 (2.26/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I would like to add that if there's a reason that experienced and knowledgeable members are doubting a very legacy feature on a modern OS and system, there's likely a good reason for it.
If all you have to show for it is nothing more than claims from what is more likely placebo, there's not much for you to actually argue or support. That's on you to prove, nobody else. No need to degrade your own topic if folks don't believe you, be constructive and get some proof to share.
It also seems you will not provide actual before and after results or evidence to support your claims, yet want to resort to calling others trolls and taking the low road by choice. It won't end well if you continue to make that choice.
You may want to re-read our forum guidelines before posting here or in any topic. I have it conveniently linked in my sig.
:toast:
2,707 (0.78/day)
On The Highway To Hell \m/
I can Enable/Disable CPU L1 & L2 Cache in the BIOS on my Syntax s651m(SiS 651 chipset) motherboard. If I disable them the OS hangs on boot.
21,082 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
I'm can to Enable/Disable CPU L1 & L2 Cache in the BIOS on my Syntax s651m(SiS 651 chipset) motherboard. If I disable them the OS hangs on boot.
Fun fact, doesn't really hang, just goes really, really slow. You might get a post screen in around 12 hours...
565 (0.27/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Ok. I did some testing and there is no difference in any test. I was wrong and that article is bogus.
Status
