Oracle VM is crashing my PC
144 (0.26/day)
For some reason, Oracle VM VirtualBox is crashing my PC about two or three times a week. It seems very inconsistent, so I'm not sure what's causing it. It usually works just fine for hours on end, and then it randomly crashes. In the most recent crash, my PC crashed as soon as I opened VirtualBox. I am using the Debian 12 Bookworm OS on my VM for class although I'm using Windows 10 Education as my actual OS. I tried to reduce my number of processors to 5 and then 4 instead of 6, but that did not help. I tried to adjust my base memory as well, but that also didn't work. I'm not sure what else I can do to fix this.
PC Specifications:
Motherboard: Asus TUF GAMING B650-PLUS WIFI ATX AM5 Motherboard
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor
CPU Cooler: Noctua NH-U12A chromax.black 60.09 CFM CPU Cooler
GPU: Sapphire Pulse 6800 XT
SSD 1: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
SSD 2: Crucial P3 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
RAM: (4x16) G.Skill Flare X5 32 GB (2x16 GB) DDR5-6000 CL36 Memory
Power Supply: Super Flower Leadex III Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Windows: Windows 10 Education
AMD Driver Version: 24.7.1
306 (2.83/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
Any specific error messages in the Windows logs? Does it still happen with a fresh VM instance? Does it only happen with Virtualbox?
Failing all else, you can always try booting Debian from LiveUSB, and maybe then make a dual-boot install for your class needs.
144 (0.26/day)
Thank you! I saw some critical errors in Windows Event Viewer around the times my PC crashed which I'll put at the end. By a fresh VM instance, do you mean I should try setting up a completely new VM to see if it still happens? I've experienced crashes with VirtualBox and OpenRGB. I'm not sure why OpenRGB is crashing, but it only happens when I run as administrator. It gives me a message that says it can't find motherboard LEDs when I don't open it as an admin, but it just freezes up my PC when I do open it as an admin. I don't think my motherboard has LEDs other than the error lights, so I was thinking that might be why it's freezing, but I'm not sure. Sleep mode always gives me an AMD driver timeout error, though that's probably unrelated.
Anyway , here's the critical error I saw. It seems they're all the same as far as I could tell. They all fall under "Event 41, Kernel-Power." Here are the details:
General: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Details: System -
Provider
[ Name] Microsoft-Windows-Kernel-Power [ Guid] {331c3b3a-2005-44c2-ac5e-77220c37d6b4}
EventID 41 Version 8 Level 1 Task 63 Opcode 0 Keywords 0x8000400000000002 - TimeCreated
[ SystemTime] 2024-09-03T23:52:24.2576682Z
EventRecordID 144777 Correlation - Execution
[ ProcessID] 4 [ ThreadID] 8
Channel System ComputerDESKTOP-59C1JVC
- Security
[ UserID]
S-1-5-18
BugcheckCode 0 BugcheckParameter1 0x0 BugcheckParameter2 0x0 BugcheckParameter3 0x0 BugcheckParameter4 0x0 SleepInProgress 0 PowerButtonTimestamp 0 BootAppStatus 0 Checkpoint 0 ConnectedStandbyInProgress false SystemSleepTransitionsToOn 0 CsEntryScenarioInstanceId 0 BugcheckInfoFromEFI false CheckpointStatus 0 CsEntryScenarioInstanceIdV2 0 LongPowerButtonPressDetected
false
If I can't fix it, I'll definitely go with LiveUSB then. Thank you for the help!
306 (2.83/day)
System Name Kuro
That looked like something that pops up on reboot without a clean shutdown, not the crash itself.
System instability with no clear cause is...complicated. Others would know more.
For now, make sure to back up your courseworks and anything else that mattered.
5,212 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Corsair Vengeance LPX 3600MHz (16GBx4)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
Share the .dmp in your "Windows\Minidump" folder. If their isn't one, make sure error dumping is turned on (Advanced system properties -> startup and recovery).
