Oven Baking a R9 280X
oliversl
7 (0.00/day)
Hi, looking at the instructions at this thread:
https://www.techpowerup.com/forums/threads/oven-baking-a-6870-success-and-more-cards.212136/page-3
I will give it a try baking in the oven a MSI R9 280X Gaming 3G. The card started to flicker a few months ago, then I got grey screen and Windows 7 Freeze during gaming and later the vertical grey/white strings. I have to confess I used it for Boinc/Seti@Home in the last year. Also, the card sits with the heatsinc downwards in the CPU.
I bought new thermal pads and also new thermal Artic X4 paste too.
I have an spare 6870 so I will test the procedure with that first.
Any advice is welcome. Wish me luck!
Regards,
Oliver
Solaris17
Super Dainty Moderator
27,057 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Iv done it a hand full of times with great results. I raise mine up off a baking sheet with aluminium foil balls.
42,503 (6.66/day)
Regards,
Oliver
Dont try a reflow, flicker results from clocks or voltage being too low. Ask msi for a new bios.
Post your white sticker from card here also give us a GPU-Z screenshot to see what bios you have.
oliversl
7 (0.00/day)
Tks, I have the GPU ready to bake so I can't connect to the computer. Will wait until the new thermal pad/paste arrive, assemble it, connect and get the GPU-Z screenshot. It will take 8 to 10 days.
Meanwhile I have the white stickers, they say:
SN: 602-V277-38SB1401096xxx
EAN: 4 719072 314026
UPC-A: 8 24142 01599 5
Then a little white label says: E116458170
The PCB says: V277 VER: 1.2
Tks, do you cover also the capacitors? I cleaned with a toothbrush and neutral hand soap, washed with water, immediately dried and cleaned with contact cleaner spray, let a few hours to dry. Removed all plastic and paper labels. The contact cleaner is great for removing the glue from the labels.
Then covered the plastic parts with aluminum foil and raised it with it too. Put an inverted pirex glass pan and the card on top of it with the chips facing upwards. I done all this with the 6870 that I got from a coworker. He said it does not work anymore. But will wait a little more for baking the R9 it seems, because thats my primary game card.
Also I let the card inside the oven for 2 minutes with door open, then moved it to the kitchen, didn't fan cooled it.
Regards,
Oliver
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
A 285 is a dual gpu, it will work but the card is plaiged with heat issue's.
Should start your own thread....
AlienIsGOD
Vanguard Beta Tester
5,118 (0.86/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 5700 8GB | GTX 1650 4GB
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer Nitro x27OU 27" VA 165hz Freesync Premium|TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
oliversl
7 (0.00/day)
My GPU is from november 2013, it has been working fine even done a few months of LTC mining back in the day.
42,503 (6.66/day)
Take a picture of all white stickers and post them here please, it looks like some info is missing...
3,244 (1.22/day)
System Name Grunt
Processor Ryzen 5800x
Motherboard Gigabyte x570 Gaming X
Cooling Noctua NH-U12A
Memory Corsair LPX 3600 4x8GB
Video Card(s) Gigabyte 6800 XT (reference)
Storage Samsung 980 Pro 2TB
Display(s) Samsung CFG70, Samsung NU8000 TV
Case Corsair C70
Power Supply Corsair HX750
That thread title suddenly made me wonder if anyone has made an Easy Bake Oven case mod. :p
14,161 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I think Nvidia tried that already with the Fermi series :roll:
Self baking GPU's.
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
I removed all stickers that could burn
Preheat to 190c leave in for 13-15mins
open oven pull tray out let cool a bit before removing fully out oven
I made a jig for my gtx 560 where the pcd lay on corners of dry wall screws and cabled tied to mounting bracket
the 560 lasted for 4 months before had to do it again,again ,and again till was replaced
The issue i had was drivers started failing then months later got big green squares all over screen - Vga mem test failed with errors
After bake - no errors on Vga mem test
oliversl
7 (0.00/day)
How do you gpu mem test?
Will do. Also, this card had a bad fan and was RMA after 15 days of receiving it. So I think the stickers are not the same as the originals.
521 (0.20/day)
Omg it's offtopic a bit, but I might try that with a laptop I have here that I blew up the screen with my fist. I thought of converting it into a tower, why not an easy bake oven?! I could game and, in the same time, my niece will prepare me some cookie.
467 (0.14/day)
Mouse Logitech G9
2,707 (0.75/day)
On The Highway To Hell \m/
There are many ways. But I don't put a lot of faith in any of them. Mainly because GDDR is ECC memory. So "errors" do not necessarily means there's a problem. In fact, it can just as well mean the VRAM is working perfectly fine.
For example, the GDDR5 on my 280X runs perfectly stable and produces no artifacts @ 1850MHz. But HWiNFO64 reports a massive amount of "GPU Memory Errors".
1,901 (0.32/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
Baking is bandaid sergery nothing more, may work for a few months or limp but eventually..........
2,707 (0.75/day)
And, according to a popular Youtube "logic board repairman", that would be because it's not the solder "reflow" that even fixes the problem(s). It's the heat applied to the IC(s) that works to temporarily fix internal "bad connections"(for lack of a better term). Which eventually work themselves "loose" again(one more time...for lack of better terms). He's a staunch proponent against "reballing", particularly GPUs, for that reason. He claims it never works for more than a very temporary fix. And has nothing at all to do with the solder. It's the heating required to melt the solder that actually does the trick.
oliversl
7 (0.00/day)
Here are the photos, the one in the oven is a broken 6870 I used to test. The R9 is waiting for the thermal pads/paste so I can boot up and get GPU-Z info.
Thats my idea, to get a few extra months out of a R9. Maybe until Christmas ;)
2,388 (0.62/day)
Shenandoah Valley, Virginia USA
System Name Home Brewed
Processor i9-7900X and i7-8700K
Motherboard ASUS ROG Rampage VI Extreme & ASUS Prime Z-370 A
Cooling Corsair 280mm AIO & Thermaltake Water 3.0
Memory 64GB DDR4-3000 GSKill RipJaws-V & 32GB DDR4-3466 GEIL Potenza
Video Card(s) 2X-GTX-1080 SLI & 2 GTX-1070Ti 8GB G1 Gaming in SLI
Storage Both have 2TB HDDs for storage, 480GB SSDs for OS, and 240GB SSDs for Steam Games
Display(s) ACER 28" B286HK 4K & Samsung 32" 1080P
Case NZXT Source 540 & Rosewill Rise Chassis
Power Supply Corsair RM1000 & Corsair RM850
Mouse Generic
Keyboard Razer Blackwidow Tournament & Corsair K90
Software Win-10 Professional
Benchmark Scores yes
I tried to bake a GPU once and it didn't work for me.
I have a Sapphire R9-280X Toxic card in a Linux box that has been like the Energizer Bunny.
It runs like the day it was delivered to me brand new.
773 (0.33/day)
Germany
System Name FATTYDOVE-R-SPEC
Processor Intel i9 10980XE
Motherboard EVGA X299 Dark
Cooling Water (1x 240mm, 1x 280mm, 1x 420mm + 2x Mo-Ra 360 external radiator)
Memory 64GB DDR4
Video Card(s) RTX 2080 Super / RTX 3090
Storage Crucial MX500
Display(s) 24", 1440p, freesync, 144hz
Case Open Benchtable (OBT)
Audio Device(s) beyerdynamic MMX 300
Power Supply EVGA Supernova T2 1600W
Mouse OG steelseries Sensei
Keyboard steelseries 6Gv2
Any update, any results?
This reminded me that I have a dead GTX 670 which I may be able to bring back through the ancient and forbidden knowledge of oven-necromancy.
2,199 (0.43/day)
I've baked a few GPU's and complete laptop motherboards as well. Out of 7 i think 5 succeeded. But when done too short, it will fail within a small period of time again, and when done too long, you might actually brick the thing you are attempting to bake. When done proper, the card or mb can last for a really long time.
Most important set of rule is to properly let it cool off. Remove it from the oven and carefully place it where it can cool down. Do not move, touch, shake or drop as the solder is 'weak' and can actually 'move' components from the PCB. It's very fragile, trust me.
I always did 200 degrees at a minute of 6 to 7. Do not inhale any of the fumes coming out of it and make sure the place is properly ventilated.
2,388 (0.62/day)
Mouse Generic
Frick
Fishfaced Nincompoop
19,659 (2.86/day)
Piteå
System Name Formula 409
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Memory 2 x 16GB Corsair Vengeance
Storage Kingstong XC3000 1T | WD Black SN750 2TB |WD Blue 1TB x 2 | Toshiba P300 2TB | Seagate Expansion 8TB
Case Fractal Design Define R4
Keyboard Dell SK3205
So he's against it because it works, but not for the reason people think?
10,821 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
silentbogo
5,549 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
He's against it because it's not repair.
When you repair something properly, there should be an expected reliability period, which you perceive as "repair warranty" on a piece of paper at the end.
Even if it's non-professional self-repair, it should still follow the basic human logic. I bet you don't patch your leaking sewage pipes with dried cow shit and bubble gum, even though it might work in 30% of the leaking pipe cases. If a passenger door in your car won't close, you don't use a rubber-band-to-the-driver's-door hack as a permanent solution.
With "baking", results are unpredictable at best. You may either throw your card into remission for a few days, weeks or months, or you can immediately kill it.
In late 2000s, when this "baking" craze has took off with great speed(due to 8000/9000-series cards dying like flies), it bred a shitton of "PC repair specialists", who's only real skill was to be agile and endurable enough to circle-jerk a hot air wand for 10 minutes. "Baking" and "reballing" became a universal remedy for any GPU/Motherboard/Laptop problem, regardless of the cause: first you bake it, and if it won't work - reball it.
I make the majority of my living with component level repair, and I can tell you an awful lot of ridiculous stories about baking.
About once or twice every month I'm getting either an ASUS Zenbook or any other ultrabook w/ most of its components soldered on motherboard, that was previously "repaired" or "unsuccessfully repaired" in various small workshops in Kiev. Some of those have faulty soldered RAM or VRAM, some of those had trivial backlight issues, but what was the first thing those "repairsmen" did? Of course bake the fucking GPU or the PCH! Any AMD-based HP envy laptop comes pre-filled with solder flux and remnants of aluminium sticky tape. Some managed to charge customers upwards of $150 for a GPU "replacement", even though the original GPU corner standoffs were still intact.
Best case scenario - the chip stays alive and all I have to do is clean the shit out of it beforehand, and then eliminate the original problem and do some thorough testing. Worst case - they mercilessly kill a perfectly functional GPU for no reason and the customer still has to pay me for diagnostics.
Just last month I had a Dell Precision M4600 which only needed a power jack replacement, but some dumbass thought that random shutdowns were caused by a malfunctioning NV Quadro GPU, so he baked the shit out of it. Now it's nearly dead (some VRAM banks died, and GPU was giving artifacts even after VRAM fix), so after the trivial jack repair I had to remove the GPU, leaving the customer only with Intel HD graphics (though, he was very happy with improved battery life).
I also have an entire collection of GPUs which were tortured by baking, while the real problem of "no image" or "artifacts" was totally unrelated to the GPU.
So, as a professional I don't give a flying fuck if baking helped some people to prolong their GPU life. All I care about, is that sooner or later this GPU or laptop is gonna end up on my desk and I'm gonna have to deal with consequences of someone else's incompetence, starting with explaining the concept of "reflow and reballing is not repair" all the way to breaking down why do I charge so much comparing to those other guys (since I actually have to buy replacement parts and include them in my final bill).
