Overclock Evga 770 sli crashed
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi there.
I have a problem.
I had an Evga geforce gtx 770 superclocked i i overclocked it and everything was fine but now that I got I second graphic card and both are in sli when I do the same overclock I get a blue screen.
Can someone tell me what am i missing?
Cheers
sneekypeet
not-so supermod
29,587 (4.35/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
you need to check speeds for each card. It is fairly likely your new card cannot handle the same clocks the original card could do. Also with much more power draw with two cards, it is possible that the power draw of the PSU could also limit their ability to OC to such levels and still be stable.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
here is a screenshot. hope it can helps.
the PSU is an Enermax Platima 80 plus Platinum 750W
43,606 (6.50/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Does the issue happen when both cards are on stock settings?
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
no, just happen when overclocked it.
here you can see the overclock and the defualt settings
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Then your new card can't handle the overclock like your other one could. Redo the overclock from scratch. Start from the beginning, find a clock both your cards can run at with no problems.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
if that's the problem then i am really disappointed and i don't see any sense having 2 graphic cards....
same graphic cards and can't be overclocked at same speed...
there should be something wrong:banghead:
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
So, what? You thought that because the cards run in SLI they would work at the same clock? No, they are still 2 different cards, that are not of the same quality so they do not overclock the same. Its really quite basic. Just got to find a clock they can both run at. Obviously lower than what your other card could do.
If I were to do SLI on some 780s, I wouldn't even overclock them. I would just let them run at their max boost clock and be done with it. No sense in overclocking a configuration, already so damn fast.
12,062 (2.62/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Almost double the GPU power is better than a 5-10% increase via overclocking one card though right?
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
i have 770 Superclocked
12,062 (2.62/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Aren't superclocked already at the brink of stable overclocking, hence the naming moniker?
My last 3 780's couldn't get past 1200 without more then 1.212v which was the maximum voltage on consumer cards. Then again they were different silicon.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
correct me if i am wrong, but overclocking the GPU wont help to gain some fps?
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
Not necessarily, with EVGA cards, you can still overclock beyond the clock they set for their Superclocked variants. But yes, sometimes the cards won't want to go much further.
12,062 (2.62/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Well of course it will, but the percentage FPS gained by relative GPU clock increase isn't exactly huge on the 770 silicon. No doubt you would see an increase, but not by more than a few extra frames with 50mhz.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
i got 112 FPS doing the benchmark but some more wouldn't hurt
12,062 (2.62/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
If your monitor is more than 60hz, then yes, by all means more may be better.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
@Knoxx29
Okay, you really need to understand that computer hardware, like CPUs or GPUs will not all overclock the same. Even if they are of the same variant like your Superclocked version, they wont be able to reach the same clock. Each chip is different in a sense. That is why you have people who have the same CPU, but much different max overclocks they were able to achieve. Same thing happens with GPUs. Your newer GPU does not overclock as well as your other. That is very normal, and not something to get your panties in a wad about. Live with it.
You also need to realize that CPUs or GPUs bought much earlier in their life times (near their release date) will overclock better than ones bought much later after release.
64K
6,773 (1.73/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
tomorrow i will try to overclock it once again till i find a clock both cards can run at.
12,062 (2.62/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
If your monitor is 60 Hz then why would your think that more than 112 FPS would help?
It wouldn't, but it may improve minimum FPS, however I think CPU deals more with minimum FPS figures.
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
Why bother? You have two cards, you don't need to overclock. :)
FireFox
The Power Of Intel
7,507 (1.91/day)
Germany
It doesn't bother me, i just wanted to know why I had issues when I was trying to overclock it, I am very happy with my 2 Evga 770.
But you now sometimes we just want to push our hardwares as much as they can offer us without cause any damages. ..
One point we never mentioned here was the power supply, could be that it doesn't handle 2 gpus plus a cpu overclocked
7,265 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Knoxx29 i guess u miss one part of all of W1zzard's reviews and i qroute:
W1zzard said:
Every sample overclocks differently, which is why our results here can only serve as a guideline for what you can expect from your card.
taken from the newest review of a gfx here on TPU which is Palit GTX 750 Ti KalmX 2 GB
i guess u can see this clearly here even u have the same brand and model they can't overclock the same.
