Overclocking My System Advice for CPU, RAM, and GPU
freeagent
9,213 (3.99/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I noticed a pretty big difference from 3600XT to 5600X, its still a good CPU. 57X3D is probably what you should be aiming for, or maybe a cheap 5600X3D if you can find one. And if you do hold onto it, its pretty rare lol..
600 (0.38/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Thanks for your reply! By the way, do you think it’s possible to get CL14 or CL12 timings on 3200MHz RAM instead of going for 3600MHz? Also, I noticed something my GPU supports 4.0, but since my motherboard doesn’t support 4.0, it should be running on 3.0. But why is it running on x8 instead of x16? Theoretically, PCIe 3.0 x16 and 4.0 x8 provide the same bandwidth, so could there be an issue with that?
You can check GPU database or reviews to be sure, but 6600 just works on x8 iirc. It’s not a big deal for this GPU, @W1zzard tested the more powerful 6600 xt and the loss is 2% I think.
