- Oct 9, 2007
- 46,828 (7.63/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
OWC, the premier zero-emissions Mac and PC technology company, and a respected provider of Memory, External Drives, SSDs, Mac & PC docking solutions, and performance upgrade kits, introduces the new OWC Thunderbolt Hub. For the first time ever, the OWC Thunderbolt hub solution gives you the additional Thunderbolt ports you've always wanted. Connect more, display more, and charge more with this new Thunderbolt 4 solution.
The OWC Thunderbolt Hub, for the first time, expands the number of Thunderbolt ports available on a Thunderbolt 4 PC. Through a single Thunderbolt 4 port, you can connect and charge any device with a USB-C or USB-A connector with this compact hub. Dual 4K displays or a single 5K/6K/8K display, high-performance storage--including NVMe solutions, A/V mixers, phone or tablet, even desktop accessories like a keyboard or mouse are all fair game. Accessories with past, present, or future USB or Thunderbolt interfaces…all connect to the OWC Thunderbolt Hub.
OWC Thunderbolt Hub Highlights:
Daisy chains can be complex. In the past, removing any device besides the last one in a daisy chain caused a disruption that rendered all devices unusable until the chain was re-established. OWC's Thunderbolt Hub lets you create a separate multi-port accessory architecture consisting of three "tree branch" chains, so you can remove devices from one chain without affecting or disconnecting the others. Now you can connect multiple portable SSDs directly to the OWC Thunderbolt Hub to experience the fastest speed your storage device can deliver.
Pricing & Availability
The OWC Thunderbolt Hub is available for pre-order through MacSales.com for $149.00 and will begin shipping in late October.
![](https://www.techpowerup.com/img/41hrH3AcPwAM2RyK_thm.jpg)
- All the Thunderbolt you've always wanted: For the first time ever, add more full speed, fully functional Thunderbolt ports to your computer
- Plug everything in: Same device compatibility and performance, whether plugged into the hub or directly into your machine
- Manage more devices: Connect storage, two 4K displays or one 5K/6K/8K display, multiple accessories you name it, you can use it
- Revolutionary development: New multi-port accessory architecture reinvents the daisy chain and allows more bus powered devices
- Adjustable LED: Customize illumination for your unique work setting
- Built-in security: Kensington Nano Security Slot for anti-theft cabling
- OWC ClingOn ready: cable stabilizer prevents work session interruption and data loss
- Independently tested and Intel Thunderbolt-certified for Windows
