*P O L L* Liquid Metal damage ---> Integrated Heat Spreader, Copper & Nickel
  • IHS *corroded*
  • IHS *discoloured*
  • IHS (caused NO damage)
  • COPPER *corroded*
  • COPPER *discoloured*
  • COPPER (caused NO damage)
  • NICKEL *corroded*
  • NICKEL *discoloured*
  • NICKEL (caused NO damage)
  • Never used Liquid Metal or only used for delid
Results are only viewable after voting.
470 (0.15/day)
Scotland
Examples
-If you used it on your IHS with a Copper heatsink and it caused no damage then you would cast 2 votes (1 for each) so your selections would be:
-If your Nickel Plated block was discoloured but your IHS was perfectly fine (with no permanent damage) then your selections would be:
-If you've never used Liquid Metal or only use for delid select:
Maximum of 6 votes per person
~If it caused damage to your IHS, Copper or Nickel what was that damage? How bad was it? Was it permanent? How did you correct it?
~How long did it take?
~Anyone out there who got more than a 5c difference compared to a decent regular paste?
P.S.
Not interested in what it did to your aluminium (we all already know not to use Liquid Metal on Aluminium)
Thanks,
Nick
393 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
Block was used directly on GPU DIE for 2 years the indents are from me scraping the rests of the Liquid Metal Pro
metal off.
Used on An i5-2500k IHS and a ... i dont even know anymore direct heat pipe Air cooler Like this one
The only issue was that after a while The Liquid Metal makes a very good Bond like an alloy only way to get rid of ....Scrap it off with sandpaper.
Conclusion:
Used Liquid Metal PADS Instead of Liquid Metal ""paste"", 100% easier to remove, 50% harder to Apply .
Got around 3-5C° on Load. On Air it was Less.
780 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
Did no damage to mine but the laser etchings were almoast all gone.(relative short usage timeframe ~6months)
Le: used inbetween ihs and hs as die was soldered to ihs.
4,849 (1.50/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600 32GB kit OCed to 6600
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply EVGA 850 BQ
Software Windows 11 Professional v24H2
Used it on my R9 280, caused stubborn/hard to remove discoloration on the copper base, and the exposed die had a scuffed appearance.
2,591 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Delid.
470 (0.15/day)
Scotland
Someone just asked me for help determining if Liquid Metal would damage the GPU DIE on his GTX 1080. (or small shiny IHS)? Not sure which one it is as I've never de-lided so still a n00b in that respect.
But he wants to use his Corsair HG10 AOI to cool his GPU (its not compatible) but he can make it compatible by adding a 2mm copper shim between DIE and block. He wants to use Liquid Metal. But is worried it will corrode or permanently discolour the top of DIE/small shiny IHS....?
Anyone have experience with that? I have given him the link to this forum and this thread I started yesterday.
Best I can do just now....
780 (0.23/day)
Earth's Troposphere
VR HMD -
Dont is my answer for long term use of lyquid metal tim on chip die,chip die insolator is a glasslike mirror finished in that particular case.
Le:alltough doable if applyed first on waterblock and only.
10,974 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
I'm about to use liquid ultra on my delid... I used Gelid Extreme but it dried up / leaked out in like 4 days o_O
393 (0.09/day)
Mouse G703
VR HMD Rift S
The only thing that will happen to his SHINY Die is that what happened to my old i7-920 , You will scratch the shit out of it when you try to clean it off.
If he got an high quality flat Plane shim go for metal but he will need twice as much , otherwise i recommend good thermal past for shims along on the movement they will cause while installing the cooler, remember Liquid metal is conductive if he is a first time user and uses to much around the dies are components and short out If he uses to much, I used to much my first time.
Again i recommend Coollaboratory Liquid MetalPad for such thing, since you can peel scratch it off after use with your fingernail only working with it is harder.
Edit: If you want a recommendation use Thermal Grizzly i am using it as a replacement to my Liquid metal right now and its good it comes very close to Liquid metal.
470 (0.15/day)
Scotland
Okay thanks for all the info guys I'll forward the link for this thread to him so he can make his mind up :)
43,468 (6.76/day)
Use Akasa Shinetsu pads, AC MX2/MX4, AS5/ASC, Gelid. Do not use Aluminum based pads or compound on copper.
peche
Thermaltake fanboy
6,709 (1.79/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
use liquid metal between CPU die and IHS, between IHS and cooler use what ever you like, thats the most popular delid
its better to use regular thermal paste there, for example arctic mx o thermal grizzly, liquid metal corrodes or destroys aluminium, coollaboratory advises that on their site,
Please notice that the Liquid Ultra is not suitable with the usage of aluminum surfaces.
info taken: http://www.coollaboratory.com/product/coollaboratory-liquid-ultra/
also i have delidded my current i7, no problems so far, did a repaste over IHS and cooler, take out IHS by mistake so had to re-apply liquid metal again, cleaned out CPU die with minor problems [liquid metal is little sticky due thermal cicles] and also over CPU IHS, no scratches or discoloration found...my i7 was running that pastes for moar than 6 months...
some people claims that conductnaut by Thermal grizzly is better solution than coollaboratory liquid ultra, easier to apply and remove mostly,
Regards,
10,974 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
use liquid metal between CPU die and IHS, between IHS and cooler use what ever you like, thats the most popular delidit,
that's what i am doing - liquid metal between the ihs and die, and i have some thermal grizzly kryo for between the IHS and the block... my prior attempt to running it totally delidded ended in epic failure so i have to deal with ihs.
i tried using gelid extreme for between the ihs and core, but within a few days temps deteriorated from 75-80C to 95+ C
peche
Thermaltake fanboy
6,709 (1.79/day)
System Name Athenna
my bad, got confused there, also y had a delid die guard somewhere there that came with an MSI board from a build i did, customer claimed no to need so he gifted me the guard, never used must be somewhere there, running it naked its pretty extreme and also so risky dude, i wont do it,
what happened in your prior intent? =D got curious
10,974 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Couldnt get the pressure right to get the mobo to post, and in my tooling around with it, the chip ended up bending some of the mobo pins... i was able to bend them back, and got it to post with the IHS, so I decided to try again (lol) thinking that the reason it didnt post the first time was because of the bent pins, and it would work now.
Yeah that didnt happen - the chip ended up splipping slightly and the cache bent some of the pins closest to the middle... and this time when i tried to bend (a different) area of pins back one of them snapped off...
So now i have a new mobo and a science experiment to see if i can repair a 1151 socket.
peche
Thermaltake fanboy
6,709 (1.79/day)
System Name Athenna
i like that attitude, i guess i will never run a naked die ... my luck isn't enough for that
470 (0.15/day)
Scotland
Could NOT get all the Conductonaut Liquid Metal off my COPPER block (although the surface is still smooth):
Note: I tried a Citrus based TIM cleaner & alcohol based tim cleaner.
Even tried dipping the block in boiling water then scrubbing with a non-abrasive cloth.
I did manage to get most of it off my CPU (2nd picture)
Installation time was only 1-2 months.
If anyone knows how I could get this off my copper block please share?
Also; will this affect temps? (the surface is still smooth and there are no signs of "corrosion" as such.
CPU was fine (but it did take me AGES -- spent forever rubbing this weird 'black residue' that kept coming and coming) it was relentless. Even when the CPU looked clean I'd rub it again and the black residue would seem to magically re-appear. Like as if I was using a dirty cloth (but it was clean).
Eventually an hour later, it stopped coming :)
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Sounds like LQ is more trouble than it's worth. I wouldn't bother.
Use a good quality regular paste instead. These don't damage and can be cleaned off easily with isopropyl alcohol.
470 (0.15/day)
Scotland
aye, it all seems to come down to if you want the extra trouble for 4c - 5c better temps.
Anyway if anyone knows how I can get this off my copper block, (as seen in 1st pic above) please share :)
My temperature results comparing Kryonaut with Conductonaut LM is here: https://www.techpowerup.com/forums/...-vs-conductonaut-liquid-metal-73-w-mk.229167/
21,714 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
I've been considering trying this and aren't really concerned with cleaning it off.
My main questions are how hard the application is, and longevity. How long does it last? I never want to have to pull it off again until I upgrade is my logic, lol.
PS: Before someone pulls out a gun and says "away from the thermal paste froggie" based on my sig thread, remember I now recruit my brother to handle this particular kind of operation... his arms work. :)
470 (0.15/day)
Scotland
Thats a good point actually.
After doing my temp comparison (link above) I'm strongly considering just re-applying the Conductonaut LM.
However I'm more inclined to leave it a few more days first to do a further comparison. Thermal Grizzly claim there is no curing time for Kryonaut but I do faintly remember getting better results after a few days (regardless of their claim).
I'm going to do a few heat cycles and try and hurry the process up. I could be wrong; and I've not done any concrete testing on it. But nows my chance I suppose. Of course, I'll share the results :)
If the temps on the Kryonaut doesn't increase by tomorrow, I'm going back to the LM.... I can always replace the CPU block when ZEN comes out.
2,170 (0.34/day)
Austin TX
System Name Beyond Journeys End
Processor Ryzen 7 9700x
Motherboard ROG STRIX B850-I
Cooling Fractal 280 w/ Thermaltake toughfans
Memory 32Gb Gskill DDR5 6000
Video Card(s) 3080ti Game Rock
Storage Intel 905p 960gb + 2tb SKhynix P41
Display(s) LG C2 OLED 42"
Case Fractal Era 2
Audio Device(s) HD58X
Power Supply Asus loki 850 SFX-L
Mouse Glorious Model O
Keyboard Akko Mod 007b HE
Software Tiny 11 + Ubuntu dual boot
you should never have to replace the TIM, in some other threads its mentioned that its best used between surfaces that are not going to be serviced often such as between the die of a processor and the IHS or the die of a GPU and its cooler. the application is not difficult you just have to be MUCH more careful and take your time applying it as it is liquid metal and will kill components if it is not were its supposed to be.
the liquid metal is a better choice overall, as for removing it from blocks (staining) you can use metal polish to remove most of it and return the surface to very fine. if you want to completely remove the LM from the surface of the block to resell or whatever you'll need to lap it with sand paper and re-polish the surface.
this is the stuff i use:
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Exactly. It's the only way to completely remove it.
470 (0.15/day)
Scotland
Wouldn't that ruin the "convex" design shape of my block? giving worse temps? Might just be better to polish it with a metal polish as suggested then leave the rest of it.
My thoughts would be that if its impossible to remove most of it (without lapping) (the bits that are impossible to remove) have actually filled the "pores" in the copper creating in effect a better contact?
-The surface of the block is still smooth.
-The old LM paste was only installed for 1-2 months.
-I will probably be going back to LM soon.
-The *old* LM only seems to be present in the "pores" of the copper since the block is still smooth to touch. (I've scrubbed it and scrubbed it). So what ever residual layer must be very "fine"? Or just in the "pores"?
-Lapping / Sanding the block could reduce the "convex by design" shape worsening temps more than this very thin layer of old LM?
-I can probably get even more off by using some metal polish to smooth it even further? (better than lapping and ruining shape)?
/\ that was my thoughts (to explain it a bit better).
If I'm still wrong; then you learn something new every day.. as I seem to have been doing a lot lately, lol ?
7,099 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Coollaboratory Liquid Ultra put a white crud rough alloy corrosion resembling bird shit on my H100i's copper block. I had to lap it with sandpaper to get it level again, but the H100i's pump died shortly afterward for unrelated reasons, because it was a junk product.
I recommend you lap the product that is affected. You can also lap the lid of the CPU. If the lid of the CPU has already been made concave because of a convex waterblock, then this will correct it. Use paste product in the future like Arctic Silver 5.
