Packing Ties vs. Cable/Zip Ties
Scar Mountain
1 (0.04/day)
If I don't want to spend on zip ties, is it alright to bind the cabling in a complete system with the surplus simple packing ties various wired items ship with?
(Is there a built-in way to display a smaller resolution image in-thread? Other forums usually scale this automatically IME.)
Solution
Why would you expect this to cause a problem? The cables themselves don't care what is used to bind them.
Cable ties suck because they're single-use items and to remove them, you have to bring a sharp blade near delicate cables. This can be overcome by using reusable/releasable ones, which can be unlocked to remove them. Or you can opt for velcro hook-and-loop straps, which are reusable as well as more durable than plastic that can perish over time.
I'm cheap and hate unnecessary waste, so I reuse packing ties for my cable management. This has worked fine for every computer I've built over literally decades.
66 (0.03/day)
System Name Ryżem
Processor AMD ryzen 2700
Motherboard MSI b450 tomahawk
Cooling Silentiumpc grandis 2
Memory 2x8gb corsair venegance
Video Card(s) Zotac gtx 1070 Ti mini noctua industrial 140mm fan
Storage 500 GB Samsung 970 Evo plus, 3tb Toshiba p300, 1tb WD blue
Display(s) Dell 21 inch fhd
Case SilentiumPC regnum rg4t
Audio Device(s) Integrated
Power Supply Seasonic focus plus gold 550
Mouse Logitech Mx master 2s, g100, corsair dark rock pro rgb
Keyboard Motospeed ck104
VR HMD HTC vive pro
Software Windows 10 ltsc
If You don't short anything with wires in this packing ties it's not a problem, You can even just use string or shoelace :)
For example in electric wiring if You haven't got zipties or other cable management You could just snip some cable and use it as cable ties. What works for You and don't short anything, and be carefull around components, cause there is voltage and current, and can make short.
Edit. And don't tighten it to much to not expose wire from this packing ties.
6,390 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Solution
66 (0.03/day)
System Name Ryżem
VR HMD HTC vive pro
About zipties there are reusable zipties, not as popular as normal zipties. (ah and about zipties i hate to disconnect them for new build, cause when i was clipping one i cut power cord to pc speakers.
6,594 (1.57/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Zip ties are fine for SOME things, which are/will be somewhat permanent, however, in the rigs I build for my clients as well as my own, I use either the reusable ones like above, or the simple twisty ties like those on a loaf of bread or other packaged goods, then carefully trim off the excess with really small wire cutters, leaving just enough to be able to untwist them later...
But as already stated, the cables themselves will not care one way or the other, just DON'T over-tighten any of them, which can damage the wires inside the cable & cause all sorts of problems :)
bluntzera
8 (0.89/day)
Brazil
If you are looking for a cheaper and not permanent solution I would recommend looking up for lacing cord, widely used on aviation cable management and rc cars/planes as such.
It keeps cables neatly organized, it looks pretty and it's not too expensive
1,254 (4.96/day)
Just buy one 100 pack of those. They are reuseable for many things
And if they do not fit you can use several of those to extend them.
I use them for any cable related cable management inside and outside of the computer case.
-- those zip ties you showed I use only for my car.
