paint recommendation
tribotanl
4 (0.01/day)
I just received my 750D and I would like my first mod to be a paint job...what do you guys recommend to use?
  1. Acrylic paint for metal is a fairly popular variety. Such compounds are characterized by long-term protection of metal products and structures from corrosion.
  • The material has a long service life, does not crack and does not fade, provides reliable protection to metal products from corrosion.
  • The painted coating safely withstands high temperatures; therefore, acrylic compounds can be used for coloring heating radiators.
  • The composition is not combustible and non-toxic, has no unpleasant odor, therefore it can be used for external and internal works.
  • Effective corrosion protection for 8 years.
SOURCE: https://paintcity.ca/blog/metal-paint-types-applications/
im curious to see what theme your choosing as paint motif? is it based on a game? will there be RGB? have fun...
