PALIT Reveals the GeForce RTX 3070 JetStream Graphics Card
Raevenlord
3,755 (1.24/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
Ahead of the official release date for NVIDIA's RTX 3070 graphics cards (set for October 29th, the day after AMD's Navi announcement on October 28th), PALIT has taken the wraps of their RTX 3070 JetStream graphics card. The JetStream features a relatively subdued design with a glossy black color and a gray JetStream logo (which apparently lights in with RGB illumination) in-between the dual fan cooling solution.
The card's PCB is short - extremely short, even - meaning that it ends around the middle section of the actual cooler shroud (and backplate, which accompanies the shroud). This also means that the power connectors (a 2x 8-pin solution) sits in the middle of the card, rotated 90º relative to the cards' length. This particular choice from Palit could mean difficulties for cable routing and tidying up builds. Overall, the card features an attractive, low-key design. PALIT will reveal the full card specifications come the official launch on October 29th.
1,134 (0.26/day)
Babylon 5
System Name DaBeast!!! DaBeast2!!!
Processor AMD AM4 Ryzen 7 5700X3D 8C/16T/AMD AM4 RYZEN 9 5900X 12C/24T
Cooling Thermaltake Water 3.0 360 AIO/Thermalright PA 120 SE
Mouse Logitech G303 Shroud Ed/Logitech G603 WL
Keyboard Logitech G915/Keychron K2
Software Win11 Pro/Win11 Pro
Expect a mad rush, with many whining about severe shortage of the card.....if nVidia other recent RTX30x0 releases are anything to go by.
Deleted member 24505
Looking forward to 3070, but not sure about short PCB cards
6,188 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Agreed, a very bad design choice, which will surely (hopefully) came back to bite them in the arse :)
373 (0.19/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Cooling Cyberdyne Superconduct SC5600
Memory 128TB QRAM
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) Multiple LG C9 3D Matrix OLED Cube
Software Skysoft Skynet
Palit's first priority is always make the card ugly.
1,986 (0.44/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Mouse Logitech G500S
Keyboard Keychron Q6
Why get 3070 when there is a 3070 Super/Ti in the works based on GA102.
7424 Cude Cores
10GB gddr6x
320bit bus
There rest of the specs are unknown.
182 (0.04/day)
Slovenia
:laugh:
373 (0.19/day)
Memory 128TB QRAM
7424 Cude Cores
10GB gddr6x
320bit bus
Same reason as ever? Price?
2,211 (0.44/day)
System Name Ultima
Processor AMD Ryzen 7 5800X
Video Card(s) Palit GeForce RTX 4070 12GB Dual
Storage WD Black SN850X 2TB Gen4, Samsung 970 Evo Plus 500GB , 1TB Crucial MX500 SSD sata,
Display(s) ASUS TUF VG249Q3A 24" 1080p 165-180Hz VRR
Case DarkFlash DLM21 Mesh
Power Supply Corsair RM650
Mouse Rog Strix Impact 3 Wireless | Wacom Intuos CTH-480
Keyboard A4Tech B314 Keyboard
7424 Cude Cores
10GB gddr6x
320bit bus
and same power draw as the RTX 3080, heh, and i just got a 650W PSU ugh
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
the short pcb reminds me of gtx670:
3,413 (1.00/day)
System Name M3401 notebook
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
7424 Cude Cores
10GB gddr6x
320bit bus
Because there are doubts about even cheaper than 3080 GA102 card availability.
943 (0.42/day)
I think RTX 3070 is a 215W card, or somewhere around that wattage. Anyhow, good thing about this ampere you can undervolt it a lot without losing performance. At least that was the case with 3080.
578 (0.11/day)
System Name Home PC
Processor Ryzen 5900X
Motherboard Asus Prime X370 Pro
Cooling Thermaltake Contac Silent 12
Memory 2x8gb F4-3200C16-8GVKB - 2x16gb F4-3200C16-16GVK
Video Card(s) XFX RX480 GTR
Storage Samsung SSD Evo 120GB -WD SN580 1TB - Toshiba 2TB HDWT720 - 1TB GIGABYTE GP-GSTFS31100TNTD
Display(s) Cooler Master GA271 and AoC 931wx (19in, 1680x1050)
Case Green Magnum Evo
Power Supply Green 650UK Plus
Mouse Green GM602-RGB ( copy of Aula F810 )
Keyboard Old 12 years FOCUS FK-8100
gah I don't like location of power connector.
2,012 (0.36/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
Nvidia says its 220watt and 1x8pin on reference?if there is such and recommends 650watt
354 (0.12/day)
Indonesia
System Name Nero Mini
Processor AMD Ryzen 7 5800X 4.7GHz-4.9GHz
Motherboard Gigabyte X570i Aorus Pro Wifi
Cooling Noctua NH-D15S+3x Noctua IPPC 3K
Memory Team Dark 3800MHz CL16 2x16GB 55ns
Video Card(s) Palit RTX 2060 Super JS Shunt Mod 2130MHz/1925MHz + 2x Noctua 120mm IPPC 3K
Storage Adata XPG Gammix S50 1TB
Display(s) LG 27UD68W
Case Lian-Li TU-150
If its anything as good as their previous Jetstream designs this will be an awesome card!
14,092 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
The other 8 pin is to power all the LED's. :roll:
1,755 (1.03/day)
I suspect the short PCB is an Nvidia design since they also made the RTX 3090/3080 boards much shorter than usual. To be honest, I am not sure if the primary focus is to cut cost, but the cram board will certainly run hotter than it should.
7424 Cude Cores
10GB gddr6x
320bit bus
Price and availability are key factors. There's severe shortage of GA102 chips, and likely also with the GDDR6X VRAM. In my opinion, GA102 should not be a high volume chip, so it will be hard for Nvidia to try to increase supply. Its like trying to sell a RTX 2080 Ti at launch at mid high end price range. Everyone will be flocking to get it. Naturally the demand will greatly outstrip supply.
110 (0.07/day)
Processor Intel Core i7 12700KF
Motherboard Asus Prime Z690-P D4
Cooling Arctic Liquid Freezer III 360
Memory G.Skill TRIDENT Z 32GB 4000MHz CL16 DDR4
Video Card(s) MSI Suprim X RTX 4080 16GB
Storage Kingston KC3000 1TB
Display(s) Alienware AW3423DWF 34" 21:9 OLED
Case Antec C8
Power Supply Fractal Design ION 860+ Platinum
Mouse Roccat Kone Air
Keyboard OZONE StrikePro Spectra (CherryMX Red)
Software Windows 11 Pro x64
Did all cards from x070 series have full backplates covering backside of the chip? Without taking the backplate off, it's hard to say what type of capacitors were used and how they are arranged (at least in case of this Palit).
9,910 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
Have to agree, crap design. The power jacks need to be out the back of the card, not the top and not the middle of the card.
and when you build your rig everything looks good before those cables take over it
