Mayonnaise
- Aug 16, 2023
- 18 (0.03/day)
I'm currently using an ASRock B650 PG Lightning with a Ryzen 7 9800X3D, and so far I've set an undervolt (-30/-40mV per-core) and custom thermal limit (89C) and +200 boost, though I'm running it at the stock clock right now. No issues so far with the PBO power limits set to 'Auto' or 'Motherboard' in the bios, though the same can't be said for when I try to set custom values.
As soon as I try to set any custom values, be it the stock values for 120, 105, 65w TDP, or motherboard limits, Windows simply just takes forever to boot, and I can't even reach the login screen. To see if it was a problem with Windows, I then tried to boot into Debian Linux, which also took forever, but I was able to get into the desktop. When I did check the system readings using btop, the cpu under load seemed to be running at a maximum of no more than 600MHz.
Under normal operation (with PBO set to anything but manual, or turned off), no apparent issues with instability, temperatures, etc.
This seems to be some kind of firmware issue, I'm currently using version 3.16 which is the latest non-beta version. Recently I've seen news of burning issues with the 9800x3d in ASRock boards specifically, so this otherwise just weird bug is causing me some great concern. Has something similar happened with anyone else with an ASRock + 9800x3d combo?
