PC-Beto
p0Pe
126 (0.02/day)
Hi tpu:) just registered on the site, and felt like sharing my latest mod with you. i am 21 years old, and comes from denmark, and have made a few mods before that i might post pics of sometime:)
hope you enjoy my newest mod!
PC-Beto
A big thanks goes out to the sponsors that have helped me out with hardware for this mod!
lets jump right into it. as usual i am modding an old used case!
the inspiration?
the case, and plans.
im going to watercool the system with a 3*140 mm radiator in front, and two pumps. as seen on the pics, the case is devided in 2 sections. the frame is going to be powdercoated in matte black.
this is some of the evelopment of the cad drawings i made. the big round one on the left is going to be a window.
and the finished drawings. the top drawings is going to be cut in folie, and the bottom one in green acrylic. since ac-ryan didnt reply on my mails, I found the same acrylic that they uses (for 1/4 the price) and will be using that.
finished middle plate
the middle plate is going to be bend around the frame, to give a smoother look
the little room in the top will be sealed off, and most likely used for 2 harddrives.
close up of the rad hole in the front
on this pic, the folie looks quite thick, but it wont be
the motherboard tray (yes, that old bucket have a removeable mobo tray!) is going to be made of 2 pieces of acrylic. black and green, and will look like this
for pumps holders, i designed a bracket, that will fit on 140 mm fans to hold the ddc pumps. with rubber grommets, theese should reduce vibrations too, and the cold air from the fans will cool them down a bit.
close up of the bracket.
hardware is yet to be decided. but for watercooling i will go for theese 2 for certain
2 ddc pumps
HWLabs black ice gtx 420 radiator
soo.. hoped you enjoyd this little start of my new project though it almost only consists of renders. more WILL come. (already got a lil´ testplate cut out to play with;) )
-p0Pe
4,267 (0.68/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Cool! :rockout:
I pretty sure I used to have that case... In-Win or Enlight? To give away my age, I had that case with two floppy drives. One external for custom boot floppies and the other in the hidden 3.5" bay on top with a write-protected fail-safe boot floppy ;)
Fourstaff
10,072 (1.85/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Awesome! And welcome to TPU, enjoy your stay!
6,270 (0.92/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Pretty! Nice work you do there.!
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
wow, nice cad work :)
DrPepper
The Doctor is in the house
7,482 (1.22/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
Sweet mother of christ that would be a badass pc.
p0Pe
126 (0.02/day)
thanks for the nice welcome all:)
another update:)
Sponsored by
CoolBits.dk & Noiseblocker.de
First of all, thanks to Noiseblocker for sending me some fans to work with! More details and pictures about these fans can be found later on www.itrends.dk
I had to cut a lot of the case away, to make room for the massive HWLabs 420 mm radiator
This was the piece in the front that was cut off
I left a little ”hinge” for the radiator to support to, so the acrylic plate in front wasn’t carrying the whole thing alone.
This is the case in its VERY naked state. The little piece between the two sides on the front is going to be cut away too, since it’s visible through the front
And then there is this little piece, and again the piece described above
Rivets mutilated!
And then I went Mohawk with my dremel to Guns & roses on the mp3!
The cutout
I made a cut with a wide of 15.5 cm, since the radiator was written to be 15.3 on HWLabs hp. I discovered that it was in fact 15.4, so it was a tight fit!
The support for the motherboard tray was also removed, since it needed to be cut down to size.
Note all the dust and dirt… that’s where it sat lol
And here is the radiator passing through the middle plate again. I put two temperature sensors on the radiator, but these will most likely be moved to other places duo the fact that the radiator will be hot most of the time, and readings will then be flawed.
As planned is only two 5.25” bays available, and these are already cut down to size.
I got the first test plate cut out to see if everything was according to plan, and every single measurement was SPOT ON! The results of many hours of work with the ruler:D please note that this plate is ONLY for testing purpose. The finished plate will be cut in Green acrylic, and the foil will have more patterns, as you see in the drawings in update 1.
You can here see where I did the mounting of the front panel. These bolts will be cut down to size, and foil will be over the holes so you won’t be able to see this on the finished plate.
You can see on this pic, that the metal behind have not been cut yet.
And on these two you can see how the mounting will be done.
I changed the layout of the components a little bit, so that the psu stands vertically, with the pump/reservoir by its side. This makes the brackets I made for the 140 mm fans useless. But hey, at least they looked cool xD
This puny corsair psu will suffer the space for this one that will be in my mailbox today if everything goes well!
I am going to route the cables on a way that I don’t recall ever seeing on any modding forum, so this is what I am putting most of my time on at the moment! So stay tuned for that in future updates!
I also got a package from www.noiseblocker.de that was kind enough to send some of the ULTRA hot fans for this project! More pics of these will come later on! You guys should really check their site and products out.
As you can see of the picture of the giant radiator, I already got most of the water cooling gear from www.coolbits.dk ! Huge thanks for the support is appropriate.
The pump choice fell on a Laing ddc 3.2 18W pump.
Seconds later
And internals (flipped upside down)
Shortly after, the stock top was replaced with the EK V.2 top, along with a koolance male-male fitting, that allows me to put something on the pump :O what could that be :/
This will later on be changed for a black bitspower version!
So what could I place above that pump? How about one of the Jon Lund reservoirs!
The black color is IMO spot on, and with the XFX green psu fan behind it, this will look DOPE!
Normally a Lund reservoir comes with a G3/8 inlet hole in the top, but he offered to make a custom reservoir for this mod, which needed to be a bit shorter, and have a longer inlet tube, so that the flow won’t go Mohawk in the res.
That’s all for this time fokes! Stay tuned for more:D but until then, happy newyear!
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
hot damn thats good, are you gonna poweder spray the internal metal too because it will look lame if you spent soo much time on the rest of it and left it at the last hurdle?
p0Pe
126 (0.02/day)
thanks!
every detail will be covered:) im leaving nothing blank in this one. the frame is going to be powder coatet matte black:)
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
nice!
Fourstaff
10,072 (1.85/day)
Home
And I thought modding will become a little dull once zaam finishes his companion cube :D
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
6,270 (0.92/day)
New York
hey pOpe what would that case cost someone to buy from you?
28,879 (4.67/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
very nicely done so far, looking forward to the next update :toast:
5,787 (0.96/day)
Switzerland, Heart of Europe
System Name Fractality 1.0
Processor Intel Core i7-860 @ 3.6GHz
Motherboard EVGA P55 SLI
Cooling Prolimatech Megahalems and four Fractal Design 120mm fans, sleeved
Memory 16GB Kingston Hyper RAM
Video Card(s) PNY GeForce 580 XLR8
Storage 64GB and 180GB SSDs / 1TB and 2TB HDDs
Display(s) 24" Acer V243W
Case Fractal Design Define R2, sleeved all I/O cables
Power Supply Corsair HX750W modular, sadly only stock sleeving
Software Win 7 64bit
Very nice. VERY nice. You seem to have quite some modding experience, also judging from your DNA mod. I'll subscribe. This will be killer. Totally rad, dude! Alright enough of 80s talk now.
p0Pe
126 (0.02/day)
well thank you all!
hehe i have no idea. were anyone to buy it, they would have to come to me, beacuse im not putting it up to auction by myself :laugh:
if anyone is interested, this is my DnA mod
http://www.techpowerup.com/gallery/2426.html
and this is how it looks now after i made the "DnA revisited" mod
i made a change for the side window which are now going to look like this:
took some pics of the fans noiseblocker sent me to test on this build
((NB)) pron!
XK2 & PK3
PK3
PK3´s versus HWLabs 420
multiframe
and look at this bundle that comes with the PK series!!!
also comes with an optional rubber band around the fan.
more to come;) just mounted 2 of the 120 mm versions to a noctua something something cooler inside a antec p193, and it looks EVIL! cant wait to show you guys!
i will have another update ready for you soon;)
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
cnc mods are nice. just too easy to make look good, because of the cnc. also if I want to check out your Sponsor web sites I will go there on my own,, without your influence.
p0Pe
126 (0.02/day)
and if i wanted to read your comment, i will do it, without your influence.:wtf:
seriously... dude... there isnt a tiny bit of sense in that last part of your post. so please keep the bs out :shadedshu
my mods comes from ideas, and many hours of planning. and just beacuse its made with a cnc machine doesnt mean that i have done nothing myself:slap: my dremel still have plenty of work to do;)
6,270 (0.92/day)
New York
Dude your work is excellent wether done on a CNC which most dont even know how to program, or if it was all done with a damn dremel..So hay bro your work is excellent and I believe you can make some money doing it !:toast:
p0Pe
126 (0.02/day)
thank you:p i almost cant wait to get going with the 2 square meters of acrylic that i have in the workshop :D
355 (0.06/day)
Brazil - São Paulo
System Name "I2I3 Overclocking Team"
Processor Phenom II x6 1090T 3.2
Motherboard ASUS M4A785TD-V EVO
Cooling Stoock
Memory G.SKILLl Ripjaws 4GB (2 x 2GB) DDR3-1600
Video Card(s) Geforce 9800gx2 EVGA
Storage Sansung 500GB
Display(s) LG
Case Box motherboard
Software Windows 7
Benchmark Scores Hunt3r
this is auto cad 3d?
p0Pe
126 (0.02/day)
nope:) its made with the program Cinema 4D and then i exports them to .dxf files, and showes them into the lasercutter
p0Pe
126 (0.02/day)
Sooo, after a lot of measures, and hours in front of the computer i finally got the front plate cut out.
My last attempt at bending the test front plate failed big time, so i used an akrylic bending machine. Say hello to Bender!
Bender works by heating up a small area of the acrylic, and you can then put the acrylic into the 90 degree angle you see in the front of the machine.
Cold water is running trough this thing, so that the plate cools down relatively fast.
And KAZAM! Like a glove!
Now, next machine to have a little quality time with is this one:
It cuts the foil out, like a bunny on crack! I made a little vide wich you can see here:
http://www.youtube.com/watch?v=LQbDg-VKU30
And here you see the foil. The middle is being cut in hand with a hobby knife.
Can anyone guess which of the plates i am using for PC-Beto?
Aplying the foil to the acrylic.
And the sides got cut out, and foil was put on them too!
And i had to cut the center out by hand.
The hardest thing was the tiny letters in the pc-beto
And the result!
And when put on the frame:
And look at this tight bend;)
The other side
From the inside. Remember that the frame is going to be powder coated!
And the new PSU plate that makes the psu stand vertically.
Thats all for this time;) More will come, and i have a nice surprise stored for you! just need to get some parts home before i will share that:D
Frick
Fishfaced Nincompoop
19,409 (2.85/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
How did you cut the acrylic? Awesome mod! :)
5,787 (0.96/day)
Woho, nice! That foil cutter is awesome. Altho I do think its a tad bit on the expensive site if you plan to buy it for private use :D
