TheCubeN00B
- Sep 15, 2022
- 2 (0.00/day)
Hi everyone,
I just finished building a pc;
ryzen 5 2600
r9 290x
16gb dual channel ram
ga-a320-h
650w coolermaster
500gb hdd
It took a very long time, and at first when I booted it seemed fine. It booted to bios first try. I should’ve known. The fans then ramped to 100%, the display signal went out, and then the fans returned to normal speed. My peripherals, however, were still lit up (rgb). When I tried to switch off the pc (using the front panel connector) it either does absolutely nothing, or switchs off like normal. When I try to power it back on, sometimes it works, other times it does absolutely nothing, to the extent where I switch off the power supply, and switch it back on a few times (to which it just starts, even though I didn’t even click the on switch).
Unfortunately, it doesn’t just do this. When I manage to make it to the windows install screen, it says there are no device drivers found, so I can’t install it on my hdd (I’m using a usb stick to install), and whenever the pc is running it occasionally makes a zap or high picked whir sound. Could be from the HDD, but I just thought I’d mention it in case it’s significant at all.
If anyone could help in any way, I’d greatly appreciate it.
If you need any more info, just let me know.
Thanks in advance!
ryzen 5 2600
r9 290x
ga-a320-h
650w coolermaster
500gb hdd
Thanks in advance!
