PC causes horizontal line on LCD TV
cly
96 (0.02/day)
Processor i5 6600
Motherboard Gigabyte Gaming 3
Cooling Hyper 212
Video Card(s) GTX 1070
Display(s) LG 34UC88-B 34-Inch 1440
Case Fractal Design R5
Power Supply EVGA 650G2
Mouse G502
Keyboard Sidewinder
Software Windows 10 64 bit
I am hooking up my PC to my 47" LCD TV with a DVI to HDMI cable. While watching normal digital calbe I can see these fainst horizontal line scrolling vertically on my screen. If I unplug the HDMI PC cable the lines go away. Would a better cable fix this or is there another solution or reason for these? Thanks
43,594 (6.61/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
A different cable would be a good place to start since it's the cheapest fix. Give it a go! :toast:
381 (0.07/day)
Lost in space
System Name Geting old
Processor AMD Phenom II X4 940 Processor BE 3.8 Ghz
Motherboard MICRO-STAR INTERNATIONAL.. MS-7388 1.0
Cooling CORSAIR H50 water cooler
Memory 8 GB of Patriot Extreme Performance DDR2 4GB (2 x 2GB)PC2-6400 Enhanced Latency
Video Card(s) AMD Radeon R7 200 Series
Storage Seagate Barracuda 1 TB
Display(s) LG FLATRON W2361V 23"
Case RAIDMAX SMILODON
Audio Device(s) HD Realtek
Power Supply Two 1000W ULTRA X3 wired together
Mouse Logitech G9x Laser
Keyboard Corsair K65 RGB
Software Windows 10 pro
381 (0.07/day)
Lost in space
You may have a broken wire in the cable you have
cly
96 (0.02/day)
Processor i5 6600
Cooling Hyper 212
Mouse G502
Keyboard Sidewinder
When I am using the PC on the TV it is fine but the DVI/HDMI cord seems to cause interference when I am watching cable on the TV.
43,594 (6.61/day)
Storage WD m.2
Keyboard Tester84
1,745 (0.26/day)
The Nevada Wasteland
System Name 9th Level
Processor AMD Ryzen 5 5600X
Motherboard MSI X570 Carbon wifi
Cooling EK Basic 360, x2 250mm, x1 140mm, x1 120mm fans.
Memory 32GB Corsair Vengeance 3200mhz.
Video Card(s) EVGA RTX 3080 12GB FTW3
Storage 500gb ssd, 2tb ssd, 6tb HD.
Display(s) MSI 27" Curved 1440p@165hz
Case HAF 932
Power Supply Corsair HX850W
Software Windows 10 64bit
Athlon2K15
HyperVtX™
7,909 (1.21/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
v12dock
Block Caption of Rainey Street
1,969 (0.34/day)
Go to your local cable provider and tell them the HDMI cable they supplied you with isn't working right. I did this and got a high quality cable for free!
cly
96 (0.02/day)
Processor i5 6600
Cooling Hyper 212
Mouse G502
Keyboard Sidewinder
Ahhh! My cable box is hooked up to my TV using Component Video. My PC is hooked up to my TV using a DVI to HDMI cable. While watching cable TV i get the faint horizontal 'floating" lines that seemed to be caused by my PC being hooked up to my TV. If I unhook my PC they go away. Is this a problem with the HDMI/DVI cable, PC, perhaps I shouldn't use component video from the cable box?
emericanmade1
1 (0.00/day)
I had this same problem when I first started using an hdmi cord. I got a new cord but the problem persisted. The problem is probably not with the hdmi cord but with the graphics settings. Here is the solution. If your using windows 8 (and it is probably similar with windows 7), right click on the desktop. Go to "graphic options" then "output to" then "clone display". Finally, select "digital television + built in display" By making this change the horizontal line went away.
