PC doesn’t turn on after plugging in 8-pin CPU cable
10 (0.03/day)
System Name Windows 10
Processor Intel i7 - 10700K
Motherboard Asus ROG STRIX Z490-F Gaming
Cooling Corsair iCUE H100i RGB PRO XT
Memory 2x 8GB Ballistix DDR4 2666Mhz
Video Card(s) Nvidia GeForce 2070 RTX
Storage 2x 1TB NVMe M2
Case NZXT H5 Flow RGB
Power Supply EVGA 750 G3 Supernova 80 Gold
Mouse Logitech PRO X Superlight
Keyboard Logitech G710+
I'm currently in the progress of rebuilding a setup, with combinations from 2 setups.
I read a ton of posts but not really gotten any further on this issue.
Currently the motherboard is out of the case, as I read breadboarding would be a good idea to rule out the case short-circuiting the setup.
I've done the paper clip on the PSU to rule that out, fans spinning as expected.
I've tested with only Motherboard, PSU, CPU, 1 RAM, and both with and without GPU.
Everything works as expected until I plug in the CPU pin.
I think I did a CMOS reset, by removing the battery from the motherboard.
One thing I'm a bit uncertain of, is when running without CPU cable, and the GPU is on, should I be able to see something on the monitor when plugged in? It just goes to blank, and says no device connected
Any help is much appreciated.
How does one test a motherboard in other ways?
Toothless
Tech, Games, and TPU!
9,533 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Have you done the normal troubleshooting steps? (Clearing CMOS, letting capacitors drain, different hardware, etc)
10 (0.03/day)
CMOS I did.
Tried different CPU cooling, RAM, and GPU. The motherboard is the main thing I haven't changed.
Can you elaborate on letting capacitors drain
Maybe I just fried the CPU, if at all possible?
I just did start up, i tried with another PSU, it didn't sound too good, and started smelling burnt.
Now the motherboard lights red on the CPU shortly, and shifts to yellow on the DRAM...
389 (0.12/day)
System Name 06/2023
Processor R7 7800X3D
Motherboard ROG STRIX B650E-I GAMING WIFI
Cooling Custom 240mm cooling (for CPU) with noctua nfa12x25 and Phantek T30
Memory 32gb Gskill 6000 CL30
Video Card(s) RTX 4070 dual asus deshrouded with 120mm NF-A12x25
Storage 2tb samsung 990 pro + 4tb samsung 870 evo
Display(s) Asus 27" Oled PG27AQDM + Asus 27" IPS PG279QM
Case Ncase M1 v6.1
Audio Device(s) Steelseries arctis pro wireless + Shure SM7b with Steinberg UR
Mouse Corsair scimitar pro (this mouse need an overall guys pls) + Logitech G Pro wireless with powerplay
Keyboard Sharkoon purewriter
Software windows 11
Benchmark Scores Over 9000 !
CMOS I did.
He is talking about PSU capacitors drain. Just turn off the PSU and let it off during 1 hour and then try again.
10 (0.03/day)
Tried it, didn't work :(
I think the motherboard is toast.. When turning on power, both the CPU cooler and the Motherboard LEDs only show red lights.
Not the indicator lights on the motherboard though, just all the visuals.
Tested with another CPU cooler, in case the current were dead, same response.
Going to test with a new motherboard. But how do you actually confirm a motherboard is dead?
2,935 (2.11/day)
United Kingdom
How many watts is the PSU and how much power is needed? - "I tried with another PSU, it didn't sound too good, and started smelling burnt."
2,291 (0.48/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
CMOS I did.
Sounds like all the signs of MOSFET failure. But I usually expect that on motherboards with inadequate MOSFETs.
10 (0.03/day)
The original 750W, the one where it started to smell burnt, was 650W.
But only motherboard, 1 RAM block and the CPU Cooling when that happened
Have seen that on a few posts, just seems unlikely as I understand.
guess I’ll have to pull out a multimeter and test
2,935 (2.11/day)
United Kingdom
I will quickly add my motherboard has 8 + 4 for the CPU, where 8 is enough without overclocking if I remember right.
Indeed I would do some power tests and see what you can find. Hopefully its a simple problem.
10 (0.03/day)
My motherboard has the same connectors for the CPU, only using 8 of them. Same for the previous setup it was used in, where it worked.
Are motherboards really so delicate that a slight knock on it can kill it? I thought I was very gentle with it in the build process
2,935 (2.11/day)
United Kingdom
It used to be possible to bend capacitors and other connections, but current processes allow them to assemble them tight to the board.
Many years ago it would be possible to bend a whole group of parts when trying to attach the board or other.
I don't even think static is much of an issue these days as long as its a small amount.
10 (0.03/day)
So just really unlucky with the board?
Still can’t make sense of the PC not booting at all with the 750W PSU. But trying something with the 650W
2,935 (2.11/day)
United Kingdom
If the board and its current bios supports the CPU and power requirements and the PSU's can supply that, then yes, unlucky indeed.
10 (0.03/day)
Going to try with a new motherboard and new CPU.
Not sure of the odds of the CPU dying just randomly, but didn’t expect the Motherboard either
575 (0.60/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
I had an Asus Crosshair Dark Hero X570 motherboard that just didn't boot one morning. One RMA later and everything is working again with a new motherboard. So the price of a product does not mean it is immune to sudden failures. This happened after about 6 months of normal use.
So the odds are higher than 0
10 (0.03/day)
I have a slight idea where it might have gone wrong. I remember now that the old PSU i used in this new setup, weren’t the original cables that followed it as of new. I back then just plugged it in at reused all the cables already installed in the PC.
Now with the new motherboard I just hooked it up the same way, and figured that might have blown something on the motherboard.
313 (0.80/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
Oh dear. Yes that is a major no-no. The power supplies tend to have different pin-outs even though they'll use the same modular connectors. I've seen a few people fry SATA SSDs like that, among other things. Hard to say exactly how many parts have been damaged at that point. You always want to use the power cables that came with each power supply.
Toothless
9,533 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
That'll do it. Board is toast.
10 (0.03/day)
What are the odds that it worked on the other motherboard, been running with that setup with mixed cables for over a year.
and then just instantly kill a new motherboard?
2,305 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
If re-using modular cables, always quadruple-check the pinouts with a DMM!
I recently re-used PCIe and CPU-EPS cables; if I hadn't re-pinned them, fireworks would've ensued.
435 (0.08/day)
New York
System Name Unobtainium
Processor 3600X
Motherboard Gigabyte X570S Aorus Elite AX
Cooling DH15 Chromax Black
Memory 32GB Ripjaws 3200MHz
Video Card(s) EVGA 3080 Ti FTW Ultra w/ Alphacool Eiswolf
Storage 500GB SN750 | 3.84TB Micron 7450| 4TB SP XS70
Display(s) Asus 144Hz display + LG Ultrafine 4k
Case Evolv X
Audio Device(s) Schiit Hel + AKG Q701s
Power Supply Seasonic FOCUS PX-750
Keyboard Filco Majestouch II
Yep. She is done Jim. NEVER reuse cables from other power supplies. Even between same brand different models (unless same model just more wattage). Corsair is the exception if it is ones using their own speced cables, IE if your power supply uses their P4 cables and your new one uses P4 cables then it is safe to reuse old cables.
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Odds are, that you changed a cable over without realising - one unused cable on the old system that is used on the new one, that's enough to kill something without knowing.
It's not 100% certain death to mix cables as sometimes they're compatible - but it should never, ever be done unless they're from the same brand and clearly labelled (like corsair with their gen3/Gen4 labelling)
That's actually *nothing* working as in that situation except the PSU, the PC is brainless and inactive.
In case the cable issue has NOT the system and the parts are actually fine, let's cover some of the basics:
POST requires
1. Motherboard with BIOS that supports connected hardware
2. CPU supported by the board and BIOS
3. Ram supported by the CPU and BIOS
4. Graphics output of some kind
5. PSU with at least 20 ATX and 4pin EPS connected. Boards may want 24 and 2x8 EPS, but 20 and 4 is enough to reach the BIOS usually.
Any extras like a GPU or PCI-E card, even USB devices can screw with things and should be removed. Test out of the case on top of the motherboard box if needed, but do NOT use the anti static bag as those conduct electricity.
*ROG STRIX Z490-F GAMING requires bios 2103 for an 11900k, and shipped with 0403. Very unlikely that CPU will work on that board without it being manually updated.
The board supports USB flashback, so you can manually update it in it's current state as long as you can follow the instructions precisely - going off-script will not work, and you get no indication of errors when doing this.
1.You'll need a FAT32 formatted USB flash drive with the current BIOS file for the board on it (and nothing else)
2.Unzip the BIOS .zip file, extract all files to the USB drive.
3.Run the included renamer batch file, which renames the file to one the bios flashback for that board accepts
4. The Motherboard must have the power connectors for ATX and EPS connected, and have power. DO NOT POWER THE PC ON.
5. Connect the USB to the correct port.
Red arrow is the port, red circle is the flash button, blue arrow is the LED that should blink as this proceeds.
6. Press that flash button, look for activity on the LED and wait for it to finish. It can take several minutes depending on the speed of the flash drive, so give it 10 minutes and do not cut power to the system while it's blinking unless an extremely long time has passed like an hour.
*RAM is only supported to 2667 without overclocking, while it may run higher and a cleared BIOS will definitely work, automatic settings may not work for faster speeds depending on your RAM used.
10 (0.03/day)
So an update on this.
Apparently both the Motherboard, the CPU cooling and the PSU itself got fried…
not sure how the PSU itself decided to stop working.
I had done the paper clip test previously when the Motherboard started acting weird, and everything was good then.
So I got a new PSU and new CPU as I thought I maybe had killed that as well, and everything is running now, just need to change the CPU cooling as well now.
quite a surprise that mixed PSU cables, can kill the Motherboard, CPU Cooling and PSU itself at once. Lesson learned.
