PC Enthusiast's Next Stop is... 12VHPWR Power Connector with Active Fan Cooling?
AleksandarK
2,809 (1.02/day)
Just when you thought you'd seen everything, a Taobao seller has unleashed what might be the most over-engineered power connector solution yet: a 16-pin 12VHPWR power adapter complete with its own cooling fan and real-time monitoring display. Yes, you read that right—we're now actively cooling power connectors. The $30 adapter appears as manufacturers continue struggling with melting cable problems on NVIDIA's RTX 4090 series, despite the company's claims of resolving the issue. The adapter includes an LCD screen showing real-time temperature and power consumption readings, while its 180-degree design prevents sharp cable bends that are often blamed for connection problems. However, unlike more comprehensive solutions proposed by engineering experts, it doesn't address the fundamental issue of uneven power distribution across the connector's 12 power wires.
The adapter works with RTX 4090, 4080, and 4070 graphics cards. Still, it shouldn't be used with newer RTX 50 series cards, as the sales listing doesn't mention any GeForce RTX 50 series compatibility, and the latest "Blackwell" GPU design uses an updated 12V-2x6 power connector, which still appears riddled with issues. While adding a fan to a power connector may seem excessive, an intriguing possibility is that we may soon find water-cooler power connectors for the newer 12V-2x6, so users can prevent their $2000 NVIDIA GeForce RTX 5090 GPUs from melting their power connectors. Irony aside, power delivery safety is a growing concern, and no clear resolution exists. NVIDIA has reassured users in the past that these problems are now solved, but the issues are piling up as more users get ahold of their RTX 5090 GPUs.
17,715 (4.69/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Display(s) 27" QD-OLED Glossy 240hz 1440p
Case NZXT H710 (Red/Black)
I mean, if I owned a 5090 and this was a fullproof fix, $30 is small price to pay for security of a 2k card. Tis sad to see none the less.
197 (0.04/day)
Brazil
Processor Ryzen 7 7800X3D
Motherboard ASRock B650M PG Riptide
Cooling Wraith Max + 2x Noctua Redux NF-P14r + 2x NF-P12
Memory 2x16GB ADATA XPG Lancer Blade DDR5-6000
Video Card(s) Powercolor RX 7800 XT Fighter OC
Storage ADATA Legend 970 2TB PCIe 5.0
Display(s) Dell 32" S3222DGM - 1440P 165Hz + P2422H
Case HYTE Y40
Audio Device(s) Microsoft Xbox TLL-00008
Power Supply Cooler Master MWE 750 V2
Mouse Alienware AW320M
Keyboard Alienware AW510K
What a joke of a solution.
As it's the same whiny little fans they've been putting on pci-e 5.0 sdds.
37 (0.02/day)
France
System Name Enter name here
Processor Ryzen 7 3700x w/ PBO
Motherboard Asus Prime B550 Plus
Cooling Bequiet dark rock 4
Memory 2x16 Crucial Ballistix 3200 Micron E-die@3800Mhz 1,41 18-16-20-18-38-58
Video Card(s) MSI RX 6800 Trio X
Storage Samsung 980 1Tb + Crucial mx500 250go + Toshiba HDDs
Display(s) Dell s2721ds
Case MSI Mag Forge 100R
Power Supply Coolermaster MWE bronze 650w
Benchmark Scores CInebench R20: 5085
I mean if the cable isn't well plugged in, i don't think this little fan is gonna cool the 600watts the cable provide.
It would make more sense to me to put the fan on the other side (upper if we're accounting for that lcd screen) and so helping cooling the cable & connector
1,728 (1.40/day)
System Name Raspberry Pi 7 Quantum @ Overclocked.
You can copy this one, Jensen. It's patent-free. :cool:
2,305 (0.77/day)
The design of this connector just gets worse and worse.
If I owned a 5090, my wife would have left me and I would be buried under my burned down house by now. Okay, maybe only the first part would be true.
INSTG8R
Vanguard Beta Tester
8,118 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
An expensive “band aid “ for a connector nobody asked for and has proven “unreliable“ in the sense that it must be absolutely perfect or risk imminent damage…
8,817 (4.02/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Nvidia's 12VHPWR is a sunk cost fallacy now.
3,561 (0.85/day)
Athens, Greece
I want a siren on it. When something goes bad to start screaming.
8,817 (4.02/day)
Case Veddha T2
Mouse MX Anywhere 2
This thing is a total scam. The 5090 has a current balancing problem and the only way to fix it is to add circuitry to ensure that power draw is distributed evenly across the pins.
Yep. This CT scan is damning.
The PSU's job is to provide the current when a load draws it. The GPUs job is to draw that current from each 12V wire pair in a safe and controlled manner, because the PSU is (by design) going to be a single rail in most units.
Nvidia making their GPU end a single-rail is a super-stupid idea given the existing fiasco of melting 12VHPWR connectors. It's like intentional sabotage, because if someone hypothetically tried to come up with the exact opposite of what is needed to solve the melting connectors issue, the 5090FE's single rail would be it.
537 (0.37/day)
Germany
System Name Homebase
Processor Ryzen 5 5600
Cooling Scythe Mugen 5 RGB
Mouse Sharkoon Sharkforce Pro
Keyboard Fujitsu KB955
Well the fan can either cool the cables and/or nourish the starting fire xD
903 (4.38/day)
I wonder how often this will sell.
Bad ventilation will not help the customer when he has chosen a bad airflow with a very bad ventilated pc case.
You need a high temperature difference for the air blown to that connector to maybe see a difference. Therefore you may heavily reduce the temperature in the computer case first. You should aim to get below 40°C under load. Than they should focus on proper airflow. Than they may add additional fans which may point to these connectors.
I want to see a AIO 420mm for that connector. Basically 2x a AIO each with 420mm. One for the graphic card side and one for the psu side. Proper cooling. :p
6,446 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Just an FYI, but April 1st is still over a month away :D
8,817 (4.02/day)
Case Veddha T2
Mouse MX Anywhere 2
I have 0 faith that this would stop a cable from melting
It'll stop the CONNECTOR melting.
Briefly.
Before the whole PC catches fire.
And then the connector melts in the fire, too.
17,715 (4.69/day)
Something like this for 1sth April fool day?
First time I used some AI to generate a picture out of text.
Note: Not a real product.
that looks like a custom water tube to going to the connector, lmao thats great
760 (1.82/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Yes. It will sell out in waves because normies are stupid and can't be bothered to research 5min of basic electronics.
It isn't just the grammar that gets lost but the entire language.
413 (0.12/day)
Perth , West Australia
System Name schweinestalle1 and schweinestalle 2
Processor AMD Ryzen 7 5700X3D / AMD Ryzen 3200G
Motherboard Asus Prime - Pro X570 + Asus PCI -E AC68 Adapter / Asus Prime B450 M-K
Cooling AMD Wraith Prism / AMD Wraith
Memory Kingston HyperX 2 x 16 gb DDR 4 3200mhz / Kingston HyperX 2x 8Gb DDR 3200mhz
Video Card(s) AMD Radeon RX 7800 XT 16GB Pulse / AMD Reference Vega 64 8GB
Storage Crucial 1TB M.2 SSD and WD Blue 500gb Nand SSD / WD Blue 240gb M.2 SSD
Display(s) Asus XG 32 V ROG and LG ultra gear 32gs75q / TCL TV
Case Corsair AIR ATX / Corsair Air Mini ATX
Audio Device(s) Realtech standard / Realtech standard
Power Supply Corsair 850 Modular / Corsair 750 Modular
Mouse CM Havoc / Microsoft Wireless
Keyboard Corsair Cherry Mechanical / Razor piece of shit
Software Win 10 / win 10
Benchmark Scores Soon ! whateva
freeagent
9,843 (4.19/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Briefly.
This 100%
Nailed the sequence too.
The top of my case is ventilated.. I should move back to my Torrent to seal in the bbq.
