pc green screens then restarts
400 (0.22/day)
hello I have an issue i like to play warzone and stream and my pc screen goes green on my second monitor and block on my first then the pc just restarts
my specs
red devil 5700xt
r5 3600 OCD to 4.2 GHz on 1.2v
16Gb ram 3600
2TB SSD
Seasonic gx850w 80+gold
plz help
3,727 (1.90/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Did you try(?):
1. reverse the CPU OC to stock
2. get latest chipset drivers
3. latest GPU drivers
4. latest board BIOS version
5. lower DRAM speed to 3200MHz (or disable XMP/DOCP completely)
2,534 (0.52/day)
Springfield, Vermont
System Name KHR-1
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Green screen=Looks like you're using an insider build. (if you're getting a GSOD error instead of a BSOD error)
400 (0.22/day)
Idk what kind of error it is it just turns green then restarts
Did you try(?):
I can try using the cpu at stock but I’m pretty sure that isn’t the issue
my latest bios version is in beta so I’m using the latest full version
And btw the green screen only happens some times then I’ll get a error saying wattman has set back to default settings due to unexpected falure
also i have a problem i just now updated my chipset drivers and when I check it in device manager it says its still on a driver from 2009
Why is it not showing the new chipset driver that I just installed
2,534 (0.52/day)
System Name KHR-1
Case Corsair 275R
LOL, that's earlier than the date of 7 RTM! That's not a real date for 10. Just like how Microsoft still uses the year of Vista, for Windows 10 drivers!
400 (0.22/day)
guys please i need help it started happening again I checked event viewer and this is what I got
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Cache Hierarchy Error
Processor APIC ID: 0
and
Processor APIC ID: 12
The details view of this entry contains further information
qubit
Overclocked quantum bit
17,865 (2.86/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Did you take out that overclock? They can induce subtle errors and is always the first thing to try.
Also, try the other troubleshooting steps that @Zach_01 suggested.
9,915 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
could be from the card, just bring it back to stock then re test it again
