PC reboots after changing graphics card
10 (0.01/day)
System Name Home
Processor Intel Core i5 - 6600K
Motherboard Gigabyte GA-Z170-HD3
Cooling Zalman CNPS10X PERFORMA/+
Memory 16Gb DDR4 3000MHz Corsair Vengeance LPX (2x8Gb KIT)
Video Card(s) Gigabyte GeForce RTX 2070 SUPER GAMING OC 8G
Storage 240Gb SSD Kingston UV400, 1Tb SATA-III Seagate Barracuda
Display(s) Samsung C27F396FHI
Case Cooler Master CM Storm Scout 2
Power Supply Thermaltake Evo Blue 2.0 750W
Hello everyone.
After replacing my GTX 1060 with new Gigabyte RTX 2070 Super 8Gb Gaminc OC, my PC started rebooting while gaming from time to time.
Its doing great in tests, tried AIDA64 and Furmark for couple of hours each, so reboots happen only in games. Temperatures never get higher than 63-64 deg. Load in game i play is 70 percent at max.
Tried: 1) uninstalling drivers with DDU, then installing from official website without Geforce Experience;
2) resetting BIOS settings to default;
3) used Memtest86+ for half a day, everything fine;
4) cleaned PSU and tested in with multimeter;
5) tried placing card in x4 slot;
6) installed chipset drivers;
7) reinstalled Windows, it helped for about 2 days, then reboots started to happen again.
My specs: Gigabyte GA-Z170-HD3, i5-6600k, RTX 2070 Super 8Gb Gaminc OC, Thermaltake Evo Blue 2.0 750W, 16Gb DDR4 3000MHz Corsair Vengeance LPX.
Any ideas? I have only one left is to bring card back to vendor to test it, but i assume they just run some tests and say it works fine because it does pass any test without errors.
Thanks.
BIOS is of latest version F22f btw, updated about a year ago.
259 (0.07/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
I would suspect the PSU or the new video card.
Check windows error logs if there is something related to the reboots.
Some nvidia cards allow you to set the power limit below 100%. Setting it below 100% should lower the power consumption of the card. If the reboots stop after you do this, it could indicate that the PSU has trouble supplying enough power.
You can also run a CPU and GPU stress test at the same time. If done correctly, this will load the system and the PSU more than by running a single component stress test. If reboots happen when you do this, it could indicate that the PSU has trouble supplying enough power.
Best way to check would be replacing the PSU with a known working unit if you have one on hand, but I'm guessing you don't.
Also, check that all power cables in your system are correctly plugged in.
5,853 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
How old is the PSU? Make sure you have controlled test environment, if everything worked for two days after reinstalling what changed?
40,739 (6.54/day)
What's the specific power supplymodel number? Get a picture of the entire power supply lable.
8,077 (1.38/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
That PSU was tested on Tweaktown, in 2013, with good results. It shouldn't be the weak link, but to me this is a power problem.
OP, I'd suggest unplugging and re-plugging the 24 pin power connector. That PSU comes with a 5 year warranty, so if it's older than that, you may want to consider replacing it.
Is it the same game, or does it happen with multiple games?
What GPU are you upgrading from?
3,048 (1.71/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (378W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
PSU is rated as Tier-B on this list (for entry level systems), and should by doing the job(?), but I'm not sure that 2070S is entry level card... guess not!
8,077 (1.38/day)
Hillsboro, OR
System Name Main/DC
BTW, is there any way it could be your power source?
FreedomEclipse
~Technological Technocrat~
23,597 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Yeah but the PSU was released in 2012. Thats still an old PSU technically.
8,155 (2.23/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
manufacture date is what matters. it could have sat on the shelf for a few years too. Smaller shops might refurbish without and still try to sell as new.
Deleted member 194470
Power supplies usually last a long time if they are good. It could be the power cable or you didn't plug in the card right. I had this problem with cards that I installed. I wasn't use to the special power adapters for the video card and I didn't have it plugged in all the way.
187 (0.10/day)
System Name Times Killer
Processor Rytzen 5800X3D
Motherboard ASUS TUF Gaming X570-Plus Wifi
Cooling Corsair H110 Extreme Performance AIO
Memory 2x 16gb G.Skill Ripjaws @ 3800Mhz 16-16-16-38
Video Card(s) Geforce RTX 3080 10gb +130/1200 / MSI RTX 3060 VENTUS 2X OC +180/+850
Storage 2 X 1TB WD blue 1X 4gb WB red 1x LG WH16NS40 16x blu-ray writer 1X 12TB WD Gold
Display(s) HP Omen X 27
Case Corsair Obsidian 750D W/ airflow kit
Audio Device(s) SoundblasterX AE-5 plus / Asus Xonar DX
Power Supply Carsair 850-M
Mouse Logitech Proteus spectrum G502
Keyboard Logitech G213 Prodigy
Software Windows 10 home
might be the hdd the games are on starting too give out.
2,849 (0.51/day)
MN
System Name Personal / HTPC
I've seen odd power issues. A similar case where a guy had a space heater plugged into the same circuit breaker (different outlet on the same wall, and the space heater sat on the other side of the room) his PC was plugged in - heaving game with the space heater going was causing his PC to power off and back on. He said his temps weren't over 70C on his GPU and his CPU wasn't going over 60C, so overheating wasn't the culprit. After he finally unplugged the space heater the rebooting issue on his PC stopped.
10 (0.01/day)
System Name Home
Im not sure what to look for in logs, i can upload it if it can help.
I was doing every single stress test in AIDA64 and furmark at the same time for about 2 hours, i thought that makes sure PSU is not the case.
Also i replugged every single cable in my PC while trying to solve this.
PSU is about 4 years old.
Yeah i guess if there is no other solution ill try to reinstall WIndows again. Thing is, i didnt do anything specific before reboots started to happen again.
Replugged every single one of them.
I play Witcher 3, for testing purposes downloaded also RDR2 and Metro Exodus. Metro was fine, didnt want to play long tho, RDR2 rebooted during start intro, so i stopped trying.
As it reboots randomly from time to time and almost always at certain moments, i thought there's something with software. Maybe reinstalling BIOS on graphics card can help?
Tried installing a game on both SSD and HDD.
8,077 (1.38/day)
Hillsboro, OR
System Name Main/DC
No, just no,
That's telling, but it doesn't tell us exactly what's causing it. PSU? GPU? Motherboard? (yes, really) Where/what you have the system plugged in/to.
The troubleshooting steps from here are to exchange parts, starting with the PSU. You really only need a 550 watt PSU for that system.
10 (0.01/day)
System Name Home
No, just no,
I mentioned in 1st message, previous Gpu was gtx 1060. PC connected to common surge protector or w/e its called.
Yeah I still dont get it how it may be PSU fault considering it passes couple of hours long stress tests.
First i think ill give GPU to a friend to test it. Want to mention again: problem started only after i changed graphics card.
40,739 (6.54/day)
Put old card back in, however if the gpu exibits no problems in froends machine or in a shop its your rig, could be ram even, disable windows automatic restarts afer crashes
10 (0.01/day)
System Name Home
Sold old one right away.
I hope i can force my friend to play witcher for me :D
Automatic restarts disabled, it doesnt BSOD, it just instantly reboots.
40,739 (6.54/day)
Got temperature monitoring tool,
2,960 (0.87/day)
Long Island
PSU Tier Lists are poorly evaluated and I can not recommend using them. For example, you will find an entire model series put on the list based upon one review of one model from that series. And quite often, the lower sizes in the model line are made by a different OEM and / or on a different platform. For example:
Corsair's TX line came from 2 different OEMs CWT / Chicony) using 4 different platforms
Corsair's HX series came from 2 different OEMs (Seasonic / CWT) using 5 different platforms
EVGAs G2 series came from 3 different platforms ... same for P2
1. Is anything overclocked ? If so drop to out of box settings and turn off XMP for comparison purposes
2. How many different games have exhibited this behavior ?
3. If it can handle Furmark, take the PSU outta the equation ... you used AIDA 64 and Furmark at same time ... few systems can handle that, it's not the PSU.
4. The budget MoBo is a bit out of balance with the CPU / GPU
5. If automatic re-start is disabled ... it should present an error screen. Note the time of failure / report and thenafter reboot look in Evenbt Vuewer Windows system logs for description of err event(s) ... anything in yellow (warning) or res (error) should be investigated.
6. Try in another box.
10 (0.01/day)
System Name Home
Yeah, temperatures never were higher than 63-65 both on GPU and CPU during stress tests. Its even lower in games since Witcher on ultras only loads about 60% of CPU and GPU.
1. CPU was overclocked since i bought it using default option in BIOS, as i said before i tried resetting BIOS setting to default, thus removing any overclocking.
2. I play Witcher 3 atm, tried Metro Exodus also for about 2 hours, it was fine, and Red Dead Redemption 2 - PC rebooted during starting cinematic so i stopped trying it.
3. Yeah i thought the same way, voltages measured with multimeter were also perfectly fine.
4. Yeah it was fine before upgrading GPU, now it seems a bit weak, but i would've accepted performance decrease as a result of some sort of bottleneck, not these reboots.
5. No as i said there's no BSOD as if there's not enough voltage on CPU during overclocking, it just insta reboots. Should i post event logs here when i get home? As i recall It just says something like "kernel power code 41", i guess it just states the fact of PC shutting down not as it should be.
6. Didnt understand this one :D
853 (0.35/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
Looks like PSU problem related to transient response.
Nvidia card throttle when it sees Furmark. Also it put linear load with not much transient.
Try Unigines Superposition and see if it exhibit same problem.
10 (0.01/day)
System Name Home
Ok ill try it. Btw i also tried decreasing GPU frequency by max. of 500Mhz with MSI Afterburner, didnt work.
799 (0.44/day)
Processor Intel i9 13900KS 6.2GHz/Allcore5.9
Motherboard z790 Apex
Cooling LT720 360mm + Phanteks T30
Memory 32GB @8000MT/s CL36
Video Card(s) RTX 4090
Storage 990 PRO 2TB / Firecuda 530 2TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Prime Ultra Titanium 1000w
Mouse Scimitar Pro
Keyboard K95 Platinum
I had issues on my 2070s rog strix too, restarts, turns out it was 2 problems. DP cable that came with the monitor (LG 27GL850-b) went bad after about a month on top of issues caused by using LG's monitor driver.
New vesa certified cable and stock windows driver fixed all problems. If you can go over HDMI you could try that.
10 (0.01/day)
System Name Home
Didnt install any monitor drivers and its connected via HMDI cable which monitor was complete with.
40,739 (6.54/day)
41 is going to be the psu/motherboard
