PC reboots under GPU stress test and videogames
AlexPTT
1 (0.00/day)
Recently i built my new PC with the following specs:
CPU: AMD Ryzen 5 5600x
GPU: Sapphire Radeon RX 5600xt Black Edition
Mobo: Gigabyt B550m ds3h
PSU: Seasonic 550w
RAM: 2x8gb Viper Patriot 3600mhz cl17
The PC reboots (no blue screen) when I try to stress the GPU in Furmark and Unigine Heaven after a minute of doing the tests. The temps right before rebooting are like 58 degrees.
Also, after a few minutes of playing Red Dead Redemption 2 the PC restarts when the gpu is fully loaded. And if i press multiple times alt+tab while i am in the game. For example if I play CS:GO nothing happens, everything is alright.
I did the test on CPU as well using AIDA 64 and after 15 minutes of stressing it the temps are like 80 degrees running at @4.55Ghz.
I googled the problem and most of the times it was the PSU for not faulty or the GPU . I wanted a second opinion from you guys regarding this problem.
Thanks
426 (0.11/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Definitely the PSU...please check again with a higher rated one..
Had similar experience with my system while running american truck simulator..changed my psu and there was no more restarts during gaming..
Also check your processor heatsink mounting and thermal paste application..
Rei
656 (0.42/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
I agree with @Jose Jeswin that the issue could lie with the PSU, though I find it odd that 550W should be able to power your rig just fine. Perhaps it's faulty.
Can you perhaps take a photo shot of your PSU's label as well as the connector to the mobo & GPU? Could also be improper plugging of connectors.
3,804 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Reboot under full load is 9/10 the psu.
3,493 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.10.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2161), upgraded from Win10 to Win11 on Jan 2024
PSU: Seasonic 550w
Thanks
Before you start spending more money I would suggest to reverse any kind of overclocking (CPU, RAM, GPU) and test again extensively. Temps may be ok but that is not an indication of stability.
Also it could just be your RAM. Compatibility issues...
3600MHz CL17? what model is that?
EDIT: typo
111 (0.06/day)
Australia
System Name wasted talent
Processor i5-11400F
Motherboard Gigabyte B560M Aorussy Pro
Cooling Silverstone AR12
Memory Patriot Viper Steel 2X8 4400 @ 3600 C14,14,12,28
Video Card(s) Sapphire RX 6700 Pulse, Galax 1650 Super EX
Storage Kingston A2000 500GB
Display(s) Gigabyte M27Q
Case open mATX: zwzdiy.cc/M/Product/209574419.html
Audio Device(s) HiFiMan HE400SE
Power Supply Strix Gold 650W
Mouse Skoll Mini, G502 LightSpeed
Keyboard Akko 3084S
Software 1809 LTSC
Benchmark Scores 3968/540 CB R20 MT/ST
Also it could just be your RAM. Combatibility issues...
If it was the RAM I suspect CSGO would also error out.
also no BSOD. my RAM BSODs usually comes with BSOD with useless error messages, but he did say no BSOD.
@AlexPPT you should also post your PSU models, stickers, anything so the PSU fiends can take a crack at it. (still, the cheapest S12III-550 should power this no problem, you got a friend to borrow a PSU from?)
  • Like
Reactions: Rei
14,062 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Don't use the power virus Furmark, and try different Ram (with an even Cas Latency).
izy
1,012 (1.17/day)
You can try to set power target of you GPU lower ( i would say start at 50% ) and see if your system still reboots , if not go higher till your system reboots again , that will mostly indicate a power supply failure.
You can also lower your GPU core / vram and see if that will fix the problem. Also you should change the power cable to the GPU and/or move it on another port in the PSU.
lavlav
12 (0.02/day)
I sent the power supply for testing in the store and it turned out that there is no problem.
also i have a new cpu,Motherboard and ram
izy
1,012 (1.17/day)
You should try what i told you , maybe your RX 5600xt Black Edition is eating too much power , thow it shouldnt or just switch to "silent BIOS" and see if the problem is gone.
Lei
1,143 (0.93/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
Say your full specs. How long are you using gpu? Temps
What psu?
lavlav
12 (0.02/day)
sapphire rx 6900 xt
ryzen 9 5900x
32GB ddr4 3600
asus rog strix 850w 80+ gold
i have this gpu About 2 two years
even less
4,566 (0.93/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
sapphire rx 6900 xt
ryzen 9 5900x
32GB ddr4 3600
even less
the rx 6900 xt may be tricking that seasonic OCP (that unit uses the focus plus/gx platform)
in fact @freeagent just posted a minute ago he had a similar issue with his GX PSU
lavlav
12 (0.02/day)
I didn't really understand what the problem is
there is a solution?
Lei
1,143 (0.93/day)
usually in my shirt
@lavlav
Temps while doing stress test/gaming
Better tag the post rather than the poster lmao :D
lavlav
12 (0.02/day)
the temps are very low. under 60/70.
i have a custom water cooling system
Lei
1,143 (0.93/day)
usually in my shirt
Look here
My GX750 had a real hard time driving my rig at full load with F@H while using my 5900X. I was seeing 650w at the wall and the PSU would trip, and I would have to flip the switch. It is running fine in my second rig. I was forced to buy a 750w G+ when I bought my GPU, and it can handle the same task for weeks on end with no troubles. My 3070 Ti can do 325w on the core, and 290w board power.
lavlav
12 (0.02/day)
Sorry, I still don't quite understand. What is the problem? Is there a solution?
490 (0.24/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
He’s saying your psu is tripping because the system is pulling to much power
Lei
1,143 (0.93/day)
usually in my shirt
Well it's weird a 55w GX750 was tripping a 650w power supply
I suggest you ask your question in the link below
@freeagent and @Bill_Bright are there
4,566 (0.93/day)
the post itself won't help as much as freeagent himself going into detail about his experience plus his mod ability allows him to lurk in threads anywhere and everywhere
the overcurrent protection may* be tripped by your higher power needs. The solution would be to contact Asus customer service directly assuming that is the actual problem (I would guess it is but the hardware is not in front of me to play around with and test).
*you would need to test the PSU properly to find out but it has been an issue brought up on that particular platform across many threads both on this site and other tech sites
