PC restarts when playing Fortnite
30 (0.01/day)
System Name LFC
Processor Intel i5 3470
Motherboard MSI B75MA-E33
Memory 8GB DDR3 800Mhz
Video Card(s) AMD Radeon Saphire 7850 1GB
Storage TOSHIBA 1TB 32MB 7k SATA600
Power Supply RaidMax RX500
Mouse Logitech M280
Software Windows 10 64bit
Hello, lot of you probably heard for Fortnite. So, everything was ok for couple of months, and now my PC restarts at start of the game. (When jumping out of a bus).
I found what setting is causing it, but I would love to fix it and know what's happening.
When I put that Shadows setting to high my PC restarts, when it's on medium everything is fine.
Any idea what's causing it? PSU or GPU, or RAM...? Or something else...?
Here are my pc spec:
Intel I5 3470 3.20GHz
Amd Radeon 7850 1Gb
8Gb RAM 1600Mhz
MSI B75MA-E33
I had simillar problem with Football Manager game too. Here is the link:
https://www.techpowerup.com/forums/...ootball-manager-tried-everything-help.225654/
Tatty_Two
Gone Fishing
25,969 (3.72/day)
Worcestershire, UK
Software Win 11 Home x64
That may just be that the game does not like system memory swapping from your GDDR once it needs more than the 1GB you have, try turning off motion blur and taking the shadows back up to high and see if it works OK then.
30 (0.01/day)
System Name LFC
Mouse Logitech M280
Ok, thanks, will try that. I'm thinking it's either GPU or PSU.
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
If you want to test your PSU, try a GPU benchmarking program or stability tester (I know of OCCT and AIDA), but I agree with the previous response. It sounds like the game doesn't like running out of memory. You might try to update the drivers to see if it is a known bug that has been fixed.
43,695 (6.78/day)
30 (0.01/day)
System Name LFC
Mouse Logitech M280
One more really strange thing. When starting PC first time in a day, I get BSOD at startup, it restarts and then, it runs fine from secound try.
4,213 (0.71/day)
Vietnam
What error code/message does it give? It sounds like it might be a VRam issue, the 7850's are getting a little long in the tooth now and the Vram is usually the first thing to go.
43,695 (6.78/day)
Make sure automatic restarts are disabled.
Write down each bsod you get and post it here. That could point to a software or hardware failure
30 (0.01/day)
System Name LFC
Mouse Logitech M280
dump file was not created, and it's not same BSOD every time, tomorrow, when i start it again, gonna take a picture of BSOD and post it here.
6,117 (1.13/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
VR HMD Linktr.ee/remixedcat // for my music ♡♡
Software Linux Mint 20
Benchmark Scores Network: APs: Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
That computer is doing a yuge favor for you ;) fortnite is cancer
14,338 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I'd turn textures down if you want to keep that card, or else buy something better.
30 (0.01/day)
System Name LFC
Mouse Logitech M280
Most of time is: system thread exception not handled
Here you go:
qubit
Overclocked quantum bit
17,865 (2.84/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
That's pants. A rogue application shouldn't be able to reset Windows like that. Whatever happened to all the memory protection and security features of Windows lol?
6,270 (0.90/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Here you go:
that error is normally a harddrive issue. I think the TOSHIBA 1TB 32MB 7k SATA600 is the issue or its cable....
i would start with a
Perform a chkdsk scan.
The RAM is my second guess and i would run the ram threw some tests as well. Good luck.
30 (0.01/day)
System Name LFC
Mouse Logitech M280
Thanks, but tested everything few months ago, even bought and installed system at SSD, still the same. Ram test was ok too. So it's not HDD for sure. Maybe Motherboard, im really running out of ideas.
Tatty_Two
Gone Fishing
25,969 (3.72/day)
Worcestershire, UK
Do you have windows managing your page file?
14,338 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
A Windows repair or reinstall may be required to fix the file system.
30 (0.01/day)
System Name LFC
Mouse Logitech M280
