Hi, I went to change my thermal paste and clean my pc and also put on a new intake fan ( fan was not the problem as after removing it it still didn't show anything)
For the start i am quite a noob when it comes to actually handling pc components, i've never changed the paste or even removed anything hardware related in my pc other than put a dvd drive in it so i might have screwed up. My pc components are as follows : i5 7400, asus h110-r motherboard, 2x4 gb of 2133mhz ddr4 ram,
asus gtx 1050 ti.
so i shall go into more detail here:
I opened up my pc case, i used a cotton cloth because i heard that microfiber ones can damage it by esd even tho some said to use a microfiber cloth i said that im better safe than sorry. I did tap the metal fan grille on the back of the case before i touched anything inside. I gently removed the cpu fan and then the cpu and cleaned them with the cotton cloth with some 70% rubbing alcohool ( i didnt have 99% in the house so i had to do with what i had). Now i accidentally put the pc over the cpu for 20 seconds because i forgot about it but it wasn't with all the weight of the pc and i inspected the inner pins of the cpu and they all looked alright, none bent or anything. After that i cleaned the cpu and cpu and applied the paste pretty crapply but i put it back anyway. The cpu was alligned well and all. Then i mounted the new case fan and closed it up. Hoping that everything went well.
I press the start button, the fans start and the normal beeping that i hear everytime is boots up. As of now everything is normal, but then i realise something. The monitor doesn't display anything. I turn it on and off a few times but to no avail. I then open the pc back again and scraped off the badly put paste and applied a new round of paste that i think was a lot better than the first with only one hiccup, that a small bit of paste fell and touched the green part of the cpu and i tried getting it off but it wouldn't budge so i put it back up and removed the new case fan and still no image on the monitor.
I don't think the monitor is faulty as it worked perfectly fine before this and if i disconnect the dvi cable it says it has no signal, only when i put it back on the gpu/mobo dvi port ( tested both because i thought maybe i damaged my gpu by esd but both didn't change anything) it becomes totally black and it says it is on standby.
Another thing may be the ram because i tried to take it out gently but it wouldnt budge so i pressed it and closed the tab that holds it in even tho i also tried to remove it 6 months ago and it also wouldnt move and i pressed on it and closed the tab and it worked normally.
I really hope i didn't damage the cpu even if i kinda wanted an upgrade as that would mean i can't use the pc until i get it fixed back again so guess no gaming for me if thats the case.
Thanks in advance.
asus gtx 1050 ti.
Thanks in advance.
