PC Turns Off Immediately After Pressing Power Button--Must be Held Down to Power On
22 (0.02/day)
Processor R7 5800X3D
Motherboard ASUS ROG B550-F GAMING
Cooling EVGA CLC 360
Memory Corsair Vengeance 32GB 3200MHz
Video Card(s) XFX MERC 310 RX 7900 XTX
Storage Sabrent Rocket, 970 Evo Plus
Display(s) ASUS ROG XG349C
Case Lian Li PC-O11 Dynamic
Audio Device(s) Beyerdynamic DT 770 PRO // DT 990 PRO & Schiit Magni/Modi
Power Supply Corsair RM850x SHIFT
Mouse Corsair Nightsword
Keyboard Corsair K95 Platinum
Hey everyone! I have a weird issue that cropped up when I moved back into my dorm after winter break (so around 7 weeks now... I've been busy lol). Whenever I try to power on my system the lights, fans, and the rest all wake for a split second then everything plunges back into darkness. The issue is extremely consistent--it happens every single time I press the power button. Pressing it again just does the same thing. I have to hold the button down for around a second for the computer to actually maintain power.
The process goes like this:
press power button > everything springs to life (for around half a second) > everything dies (RGB components turn off immediately) > graphics card PCI-E power connector fault lights all turn on and persist for 3-ish seconds as they slowly fade out > press power button again > exact same thing happens > HOLD power button > exact same thing at first, but then BOOM: she's awake. computer boots like nothing was awry.
Nothing changed between moving my computer from my home to my dorm besides removing then reinstalling my graphics card for transport. I even buckled my desktop in the back seat with a seatbelt and set it on a blanket to prevent transport trauma.
I'm really not sure what the cause of this issue is, hence the General Hardware category. I suspect some issue with the power button's debouncing timer, but why?? How? Would that even cause the computer to shut back down like this? So, power supply issue? Motherboard? Case... firmware? (do they have that?)
Note: my power supply (Corsair RM850x SHIFT) arrived beaten up in shipping through Best Buy's genius idea to tape two smaller boxes together rather than find one larger box that would actually fit it inside? I never had any issues with the power supply, and I still don't under load, but maybe some component involved in the power on process was damaged in the recent transport process.
Appreciate yall
2,162 (0.33/day)
Metro Manila, Philippines
System Name Zangief (Reborn) 2.0 AM4 not dead yet!
Processor AMD Ryzen R7 5700X3D (tweaked PBO)
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v
Video Card(s) Asus RTX 3080 Rog Strix Gaming OC
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD | Steelseries Arctis Nova Pro Wireless
Power Supply Corsair HX750i
Mouse Logitech G903
Keyboard Corsair K70 RGB MK.2 Cherry Browns | Akko 3908N Purple v3 Tactile
Software Windows 11 Pro 24H2
Does it also happen if you jump the motherboard to turn the computer on , bypassing the power button itself?
Also could be the PSU, do you have a spare or borrow a spare one to check?
283 (0.05/day)
System Name mad1394
Motherboard ASUS TUF Gaming X670E-Plus Wifi
Cooling 2 fans
Memory Corsair Vengeance 2 x 16GB, 6400 MHz, DDR5-RAM
Video Card(s) NVIDIA GeForce RTX 2070 SUPER
Storage 4 ssds
Display(s) AOC 24G2SPU/BK
Case ??!!!
Audio Device(s) Realtek S1220A
Power Supply as old as time itself
I had a similar issue in the past and it turned out to be the power supply. Computer would start or not when I pressed the power button, was quite random and hard to diagnose.
First step would be to bypass the power button as previously said.
13,690 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Whenever a computer is transported, before powering on at the new destination, it should be opened up and every power and data cable connection should be double checked to ensure it is securely fastened.
I realize you babied it, seat-belting it in the back seat. But you still lugged it out to the car, drove over a bump or two; perhaps some railroad tracks, then lugged it into your dorm room. And you were digging around inside to remove the card and reinsert the card. A cable could have been knocked loose. Being a modular PSU, be sure to check both ends of the cables.
Since everything inside the computer depends on good, clean, stable power, I agree with psyko12 and recommend your beg, borrow, stea... err... borrow a spare PSU to swap in and see what happens. This is especially so in your case since you indicated your Corsair suffered some damage. Then of course, triple check your connections again.
You might also check your BIOS Setup Menu to see if there is some obscure power button action setting that somehow changed. I don't recall any settings that affect powering on, but there maybe some. Not sure how it would have changed, however, unless your CMOS battery is weak.
914 (4.42/day)
I had a semi defective CORSAIR RM750 which annoyed me for over a year. I had a lot of discussion with amazon.de to get that one refunded. Power supply issues are hard to diagnose as an end user. it is enough when the power supply unit causes one or two issues a week, like i had. The replacement enermax power supply unit gave me since than a proper working computer. AFter the two weeks testing period, when i just wired from the glass panel side the psu inside my existing computer, i discussed with amazon.de // Not all, but my Corsair psu i previous owned was trash.
I'm an electronics guy. I collected all those computer case cables. These are still the same. I would as suggested by someone else, use another computer case power button cable to rule out a defective case.
If that does not work.
Does the issue happens with the bare minimum parts needed to boot up the computer?
Just to make it 100% clear (i hope you get my point)
1x mainboard
1x psu
1x dram stick
1x cpu graphics
only power connector connected to the mainboard from the front panel.
22 (0.02/day)
Yes, I just tried this and it did all the same stuff.
One of my roommates (with a desktop) is away on a music performance trip for the weekend... ;)
9,705 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Could just be the button itself, unplug the power button and short the pins on the motherboard with a screwdriver or something and see if same thing happens.
Nvm, saw you already did, then the power supply is probably the issue, does the motherboard have debug LEDs ?
13,690 (2.02/day)
Nebraska, USA
Mouse Logitech M190
If it does turn out to be the power button switch on your case, and if your case also has a Reset button, an easy workaround is to simply pull the two wires from the motherboard's front panel I/O header and tie them back out of the way. Then move the two wires from the Reset switch to where the power switch wires used to be. Then just use the Reset button from now on.
22 (0.02/day)
Unfortunately, it seems the case/power button are not the root cause since the same issue appeared after bypassing the power button.
13,690 (2.02/day)
Nebraska, USA
Mouse Logitech M190
That's too bad. I would try to borrow another PSU to see what happens.
22 (0.02/day)
9,705 (3.27/day)
Case Phanteks NV7
