Pc won’t boot
400 (0.22/day)
NewPc won’t boot only the motherboard and ram then stays on and gpu and fans turn on for a second then turn off
specs
3080 ti
5950x
1200w psu 80 plus platninum
980 pro 2tb
X570 dark hero
1,715 (0.39/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Display(s) Samsung Odyssey G7
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
specs
3080 ti
5950x
980 pro 2tb
Reseat everything. Check all plugs. Your board should support the cpu out of the box but you might need bios update but try to clear cmos. I dont have the dark hero but I have ch8 and there should be a button to clear cmos. If not successful, you might need to update bios using the usb bios flashback
494 (0.23/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
Both power cables hooked up to the mb for cpu?
400 (0.22/day)
Yup
I tried changing ram and I took out gpu and power it up with no gpu and I cleared cmos nothing but my cpu came in with no bubble ram in the packaging just a cpu box and a bag
Also when the ox is just sitting there won’t the mobo and ram rgb on the cpu doesn’t get hot even with no cooler
Hello someone please reply
120 (0.09/day)
System Name Black Diamond
Processor AMD Ryzen 5 3600X 6-Core Processor 3.80 GHz
Motherboard msi a320 a pro max
Cooling Default
Memory 32 GB ddr4 3200mhz
Video Card(s) Rtx 2070, 86 F no extra fans or stuff.
Storage nvme samsung (the fastest one) 1tb
Display(s) Some sceptre monitor and a tv
Case rosewill
Power Supply rosewill
Mouse Verbatim
Keyboard Magic wings
Software Lots
Benchmark Scores IDk
Yup
dm me and i may be able to help
42,984 (6.72/day)
Breadboard the system to test it. Pull all from case (Put on non conductive table)
Low quality post by PandaH05
Low quality post by xcescxa
120 (0.09/day)
Cooling Default
Case rosewill
Mouse Verbatim
Software Lots
Check now, i dm you.
836 (0.61/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
System Name °( ఠ ͟ʖ ఠ)°
Processor Intel | i7 _ 11700K | @ ~ 5GHz all | cooling ~ Thermal Grizzly CARBONAUT
Motherboard Asus | ROG Strix -- Z 590-E wifi
Cooling Asus | ROG Ryujin 240 2* _Noctua F PPC °3000 | 4+1* _beQuiet_ Silent/Light Wings 3 °2200
Memory G Skill | Trident Z *RGB @ 4000_ | _15-15-15-36_ |
Video Card(s) Asus | ROG Strix -- RTX 3070Ti_ #OC Edition
Storage WD black | Samsung EVO 860 / 970 EVO plus| WDC WD40 | Intenso x2
Display(s) Alienware | AW3821DW _ 38" {3840*1600} wide - curved
Case be Quiet | DARK BASE PRO 900 --- _rev. 2 --- #Silver
Audio Device(s) Asus | ROG Throne - Qi_7.1 | LOGITECH_G560 Speaker (RGB)
Power Supply be Quiet | DARK Power PRO 12 __ 1200W *titanium
Mouse Razer | NAGA Trinity (19 buttons)
Keyboard Razer | Huntsman V2 analog | Razer Goliathus (RGB) black
VR HMD Razer | Kraken Ultimate HEADSET __7.1 THX ____| DX RACER - Gaming Leather Chair_____ VR?? is odd!
Benchmark Scores See signature URL
a modern motherboard has got 3 major LEDs (gpu/cpu/ram) that give green light or even a red one if something fails. according to this i have got a display with numbers showing me an error or the operation that is handled by the bios.
which number/combination do YOU see?
Low quality post by Caring1
14,179 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
That's against Forum rules.
All assistance is to be submitted publicly in the forum to prevent scams.
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
on all asus motherboards there should be a small sticker with a serial and the bios number it came with.
normally around the 24pin connector.
! and plz be careful panda with whom ya interact and how for help !
Low quality post by eidairaman1
42,984 (6.72/day)
8,223 (2.15/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Also check for a misplaced motherboard stand. If it doesnt line up with a screw hole in the motherboard, take it out.
866 (0.48/day)
As post above says. Breadboard it.
Check all PSU cables are in properly and right module cable used (if PSU modular) and all components seated properly.
Have faith it'll boot, nothing like a post beep from a new machine .
14,179 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Since when?
You are correct, it is not specifically mentioned in the Forum Guidelines.
I was going by a previous post from a Mod relating to a member that was banned for doing the same thing.
120 (0.09/day)
Cooling Default
Case rosewill
Mouse Verbatim
Software Lots
Nothing even happened all i got was a video of him turning it on and stuff, and then we decided on the cpu being what it was. Then he left
He also said he built it himself, and that he has been building pc's for a long time, and none of the other ones he built ever did this before.
Basically got some new news from him that might help, that was not on here.
Low quality post by basco
2,012 (0.35/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
to all: better safe then sorry. this is not against individuals but we protect each other and thats why we like this forum so much.
and now backtotopic
836 (0.61/day)
ÐҼƱ₸ꞨƇҤՆԹՌÐ
X570 dark hero
Bois he has got the MoBo as above, he just need to follow what this mainboard showing him...It is a brand new ASUS one.
it is just easy. if NOT then i would return the PC immediately. EZ
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Try minimal, 1 stick of memory, a GPU, no mouse, no key board, out side the case. Also a speaker for boot chimes...
381 (0.10/day)
Processor Amd 2400g/Amd 3800x
Display(s) 50" LG 4k hdr
Case scratch build
It should just work acording to specs but when it does not fun begins. Are You using any extention cords? If, then do not . Maybe pic of setup would help ,do not be shy, we do like good hardware pics now and then . Cheers.
2,012 (0.35/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
just take the chainlink symbol with "insert link"
400 (0.22/day)
Just a update on things I have already tried
Gpu is known to work tested it in another rig , psu works tested in another rig, already tried a different ram kit no fixes, even if ssd wasn’t working it would still boot if not mistaken that’s why I went ahead and exchanged CP and mobo because what else could it be cpu comes in on wenesday and mobo says coming later this month because it’s in stock soon but we all know when Amazon says that it comes wayyy sooner but do guys think it’s cpu or mobo like I do
