PCI-Express Slot power?
newfellow
314 (0.06/day)
System Name ID
Processor Q9450 ~3.74Ghz
Motherboard ASUS-P5E
Cooling Air
Memory G.Skill CL4-8GB
Video Card(s) ATI/Geforce 5850/9800
Storage A-lot
Display(s) BenQ G2400WT
Case 900
Audio Device(s) Shitty ASUS FX;P
Power Supply OCZ GXS 850W
Software -
Benchmark Scores too many machines to spec
Well, I know all the GPUs nowdays uses their own 6/8-pin power connectors, but does the PCI-E slot itself give the card or generally use any power from motherboard?
Mussels
Freshwater Moderator
58,413 (7.91/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
yes. upto 75W
hat
Enthusiast
21,747 (3.29/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
The PCI-E slot provides 75w, however when gpu's have external power connectors, the slot doesn't do much in the way of providing power.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.44/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Every pair is an additional 25w. 6-pin = 75w, for example, in addition to the 75w slot power granting a maximum power draw of 150w for the entire card.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
If a PCIe card has an onboard power connector, be it 6pin or 8pin or both, then slot power is hardly used at all. Basically, those cards that have 6pin/8pin use PCIe slot power only to power the VRAM so the total draw from slot is usually 30W or so. HD4870X2 draws only about 45W from the slot.
jomjomjom5
1 (0.00/day)
PCI Ex 16x Slot MaxPower = 75w. 6pin or 18pin is 12V line.If that have 20A in line(You must see A(Amp) at you PSU Spec).It will have MAX Power in line is 12V * 20A = 240W per one Slot(6 or 8 pin) .If your card require power at 120w.You must use one 6pin for card.(Pci = 75w + 6pin = 0 - 240w)
