PCI-SIG Exploring an Optical Interconnect to Enable Higher PCIe Technology Performance
18,015 (2.44/day)
PCI-SIG today announced the formation of a new workgroup to deliver PCI Express (PCIe) technology over optical connections. The PCI-SIG Optical Workgroup intends to be optical technology-agnostic, supporting a wide range of optical technologies, while potentially developing technology-specific form factors.
"Optical connections will be an important advancement for PCIe architecture as they will allow for higher performance, lower power consumption, extended reach and reduced latency," said Nathan Brookwood, Research Fellow at Insight 64. "Many data-demanding markets and applications such as Cloud and Quantum Computing, Hyperscale Data Centers and High-Performance Computing will benefit from PCIe architecture leveraging optical connections."
"We have seen strong interest from the industry to broaden the reach of the established, multi-generational and power-efficient PCIe technology standard by enabling optical connections between applications," said PCI-SIG President and Chairperson Al Yanes. "PCI-SIG welcomes input from the industry and invites all PCI-SIG members to join the Optical Workgroup, share their expertise and help set specific workgroup goals and requirements."
Existing PCI-SIG workgroups will continue their generational march towards a 128GT/s data rate in the PCIe 7.0 specification, while this new optical workgroup will work to make the PCIe architecture more optical-friendly.
18,015 (2.44/day)
The picture is not related to what the PCI-SIG is working on and was just added as an illustration.
2,437 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
This would circumvent the escalating attenuation issues with Gen5-onwards.
Interested in if they intend some kind of standard adapter/backwards compatibility, or if this is expected to be 'industry-use only'?
5,902 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
You assume that optical technology won't have its own issues.
Optical is the transport mechanism, PCIe is the protocol, there is no backwards compatibility concern.
7,228 (1.08/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Interesting. If one fibre optic could carry multiple PCIe lanes... image what you could "dock" a laptop on to... Or reimagine what a mainboard or PC looks like if all you needed was one fibre optic link to carry 8x PCIe v4 lanes. (16GT/s PCIe v4 @ 128GT/s PCIe v7)
487 (0.34/day)
Processor AMD 7600x
Motherboard Asrock x670e Steel Legend
Cooling Silver Arrow Extreme IBe Rev B with 2x 120 Gentle Typhoons
Memory 4x16Gb Patriot Viper Non RGB @ 6000 30-36-36-36-40
Video Card(s) XFX 6950XT MERC 319
Storage 2x Crucial P5 Plus 1Tb NVME
Display(s) 3x Dell Ultrasharp U2414h
Case Coolermaster Stacker 832
Power Supply Thermaltake Toughpower PF3 850 watt
Mouse Logitech G502 (OG)
Keyboard Logitech G512
OPtical Fibre transcievers arent cheap!! So expect this to be a data center only thing for the short/mid term
For example Cornings Optically based 5m Thunderbolt cable is ~£400
A Passive 2 meter cable from a reputable brand is like ~£30
2,437 (1.16/day)
Olympia, WA
You assume, I assumed. Optical has its own 'issues', yes. However, we're about at the edge of what traditional copper interconnects can do with modern signalling methodology.
Fibre Optics are fairly well developed, but there's immense 'headroom' for faster and faster transfer rates.
...and PCIe is 32-bit and 64-bit PCI and PCI-X backwards compatible by PCI-SIG spec too. 'Parallel' was just the transport mechanism, right?
Still requires a bridge chip for the signals. That's what I'm curious about.
3,421 (1.10/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
We can all stop assuming and just read this scholarly paper on the challenges of optical interconnects for electronic chips (Note that the following link is a direct download of the PDF): https://citeseerx.ist.psu.edu/docum...&doi=d9dab715629bb9672886e3f2b833b121d583e6bc
6,348 (1.54/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
"look into the light" :)
283 (0.21/day)
With optical pcie, will that be a boon for external connections as well, and replace the likes of occulink and thunderbolt ?
2,203 (0.77/day)
Tanagra
System Name Budget Box
Processor Xeon E5-2667v2
Motherboard ASUS P9X79 Pro
Cooling Some cheap tower cooler, I dunno
Memory 32GB 1866-DDR3 ECC
Video Card(s) XFX RX 5600XT
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Antec P7 Neo
This could change the way we build PCs, which are facing the limits of power and cooling and even mounting in existing form factors. I wonder if they could potentially separate the main components more effectively so that nothing is dumping heat directly into the case. The PSU, CPU and GPU could each get their own sub-module, or even be separated entirely from each other. The GPU could be the monitor base with some IO ports or something like that.
661 (0.32/day)
Moscow, Russia
Processor Intel 12600K
Video Card(s) Palit RTX 4080
Display(s) Dell S2721qs
Case Phanteks P300A Mesh
Mouse Glorious Model D-
Most of this can be done now with standard cables and connectors but requires a move away from ATX, which nobody seems to be able to try and force.
56 (0.09/day)
Intel worked on the same a decade ago. SIG should group with them, to then possibly develop at a faster pace.
2,517 (0.78/day)
I had proposed the use of optical for PCIE interconnect on forums in 2020 at one point. It's interesting to see that PCI-SIG is trying to explore the idea of it. I don't know how effective it'll be on costs at least now with optical not being as widely adopted which doesn't really help in bringing down costs. It'll still probably improve over time a bit on relative costs though the way most things do. I see a bright future ahead for optical technology.
Something that could be done as well is better use of 3D environment space in regard to PCB's and interconnects. Running a PCIE slot 6 to 7 inches away isn't nearly as optimal as a quarter inch interconnecct between two short 3D planes of a PCB's. I'd re-thinking how PC's are built and setup is a one area for notable improvements on trace layouts and optimal performance by reducing the distances on those things by stacking pcb's cleverly to reduces overall trace lengths between destination sources.
4,081 (0.93/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
Intel did try, with BTX, and failed miserably.
It's a monumental attempt to force a different standard into an established market. ATX is long in the tooth, but somebody will need to shoulder the cost of re tooling, well, everything. New cases, PSU designs, PCB designs, ece.
2,203 (0.77/day)
Tanagra
Storage WD NVME 1GB
Case Antec P7 Neo
Just put RGB on it and it will pay for itself. :D
In all seriousness now, BTX was too soon and was seen as Intel trying to push a change so they could sell their failing Netburst designs. Power and cooling needs were quite modest compared to today’s stuff. Now we’re starting to max out air cooling in the space we have to work with. Even then, OEMs are already taking some liberties with the ATX form factor. I’m really surprised the aftermarket world hasn’t pushed for something different. I guess it does take cooperation from AMD and Intel on designing something around the CPU.
Solaris17
Super Dainty Moderator
27,186 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
cant wait to stare at my new blinky class 1 laser product!!
I am curious about heat. tranceivers get prettttttyyyy warm.
Frick
Fishfaced Nincompoop
19,761 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
I just want to sell optical chips on Leeds.
2,437 (1.16/day)
Olympia, WA
You can trust Richard Winston Tobias to make you the best deal anywhere!
Geeze, that takes me back. o_O
564 (0.62/day)
We already have some boards that use clever dongles to mount several things in 3d, like a board that plugs into the board and has both 90 degree sata and usb ports on it. Some boards have nvme slots stacked on top of each other (can't think it does good for the heat output).
It's mostly a things with ITX boards since they are the most space limited.
2,203 (0.77/day)
Tanagra
Storage WD NVME 1GB
Case Antec P7 Neo
I wonder how practical something like putting the motherboard in the middle of a wider but shorter case would be, where the CPU, RAM, and NVME drives are on one side, and the PCIe slots would be on the other. The motherboard itself could act as a natural barrier, and cooling could be approached from pretty much all sides. I suppose if GPUs were able to be mounted vertically, then it may not even take up more width than a traditional case. They might even be able to solve the issue of trace length for high speed PCIe, at least in the short term. We could probably also get away with much shorter cabling.
3,735 (1.71/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
If not backwards compat, forget it.
2,671 (0.97/day)
It irks me that you need to clarify that. :D
It's called DWDM. Although another form of muxing can be adopted for that.
Ask nvidia to hook you up with a cooler. Theirs seem to be a hot topic these days.
Someone didn't know of ISO's OSI. :)
I have heard of 800Gbps FO transcievers and those cost bonkers! And they can work at lenghts no greater than Mr. Leather Jacket's pp.
2,517 (0.78/day)
Two motherboards that connect along the edge with short interconnect inside of newer designed case format would make most sense to me. Not only do you shorten trace lengths, but you increase PCB board space significantly which from a design standpoint has big ramifications. Could have second connection along the memory edge as well easily if more PCIE slot bandwidth was needed between the daughter motherboard. A slight deviation from that would allow for some serious stacking of M.2's on a PCB for dense raid of them provided you have enough PCIE lanes. Instead lets stick to the same dated formula that has issues with long PCB trace lengths that end up increasing design costs as well.
I think we're overdue for approaching it a bit more optimally. In a good case design you could probably squeeze in 4 full size ATX or micro ATX boards with pretty short connections between them especially with optical. some kind of PCIE connection along each of the 3 upper board edges and you could connect one of each to another board for 4 boards in total. That's certainly gives you a lot of PCB space to work with. It complicates cooling more depending on how dense you get with it. Depending on how spread apart they are at least w/o optical you kind of are back to square one on long trace lengths.
3,382 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Maybe new reasons to get into water cooling. Full nickel EK transceiver block can't wait for it except for the pricetag.
