PCI x16 running significantly slow!! Help!!
Noob Makes PC
12 (0.00/day)
Okay so I have
Asus Hero Alpha
i7 6700k
GTX 1070
So when I made this PC, I intentionally installed the gpu in PCI x8 slot (just because it did not cover my ROG LED which in case of x16 did)
So Just for the sake of curiosity, I removed the card from x8 and installed it to x16 slot and now my fps droped
form 120 fps to 60 fps in battlefield 1. Not only that but even GPUz Render Test dropped fps from 400 to 90-100!!
I don't know whats wrong, If I install it back to x8 slot then it runs correctly. But in GPUz I noticed that bandwidth, Pixel Fillrate does increase a bit in case of x16.
Oh and I did check the gpu usage in x16 mode and it was 99% at the time of render test.
The Photo that I have attached is of x16
newtekie1
Semi-Retired Folder
28,473 (4.03/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
The card is only running at PCI-E x1 1.1, that is the problem. The 1.1 will likely change to 3.0 when you put load on the card, but the x1 won't. For some reason the card is downgrading to x1 in the PCI-E x16 slot.
Make sure the card is fully seated in the slot, a lot of times just reseating the card can fix this.
Aquinus
Resident Wat-man
13,191 (2.75/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
Reseating the CPU can sometimes help as well since the those PCI-E pins end up going through the CPU socket and into the CPU. Over-tightening a CPU cooler can do something like this.
127 (0.04/day)
Italy
Processor i7-13700kf
Motherboard MSi Z690-A
Cooling cuplex kryos full copper @ Xylem D5 PWM + EK 360mm + 4xNB-eLoop B12-4 @ Aquareo6
Memory 2X16GB 6600Mhz CL34 G.Skill Trident Z5
Video Card(s) RX 6900XT Ref.
Storage Samsung (980 PRO 2TB + 980 PRO 1TB + PM951 512GB)
Display(s) Benq XL2540K + Benq EX2510 + Sony 50W805b
Case Hyte Y60
Audio Device(s) Beyerdinamics DT990 600ohm & Dali Zensor 5 @ Cambridge Audio CXA60
Power Supply Sharkoon CoolZero Silent Storm 850W
Mouse Zowie FK1
Keyboard Leopold Fc900r
try to tap that " ? " ... and do start render test
Noob Makes PC
12 (0.00/day)
Well my card did tun in 30. when I did the Render Test, So that is not the case.
And I installed my card 2-3 times so its sitting correctly in there
htening a CPU co
Tried it but still no luck :(
Bro It is running in 3.0 mode when I do the render test.
newtekie1
Semi-Retired Folder
28,473 (4.03/day)
Indiana, USA
The 1.1 to 3.0 isn't the problem. It is that it is only run at PCI-E x1 instead of x16.
831 (0.26/day)
System Name Gaming Desktop
Processor i7 6700k
Motherboard asus rog alpha
Cooling H110i
Memory Corsair Dominator 16gb DDR4 3200
Video Card(s) GTX 1080
Storage EVO 840 500gb, EVO 850 500gb, Perc 710 Raid WD RED 4tbx4
Case Corsair 500r
Power Supply Antec 850
Mouse Logitec G502
Keyboard a cheap dell
notice the highlighted part
475 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
I am not a pro but since it (the PCIe x16) remained unused for long(?) time, could be some dust have went inside it thus prevent full contact to the card?
44,090 (6.81/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
its possible, however i might suggest a GPU Driver Reinstall as well
831 (0.26/day)
Processor i7 6700k
Cooling H110i
Case Corsair 500r
Mouse Logitec G502
Noob Makes PC
12 (0.00/day)
8,243 (2.11/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I wonder if any BIOS settings were changed before and the OP forgot about it.
I would try this in order, uninstall drivers & use a driver cleaner to remove left over drivers, remove the card, reset CMOS, reboot once, shut PC down after POST, reinstall the card in x16 slot, and finally do the (pre-cleaned) Driver install.
Noob Makes PC
12 (0.00/day)
I didnt make any changes in bios otherthan overclocking, but i tried resetting it back to factory setting, will try the CMOS method tho.
831 (0.26/day)
Processor i7 6700k
Cooling H110i
Case Corsair 500r
Mouse Logitec G502
pushing the top button (1) on the io panel will reset the bios to factory.
Toothless
Tech, Games, and TPU!
9,788 (2.44/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Ignoring the horrid elephant in the thread.
Did the card stay in 1.1 during games or did it go to 3.0? Sorry if I missed if you answered that already.
82 (0.03/day)
Melbourne
System Name Edit King
Processor i7 3930k
Motherboard ASRock X79 Extreme 6
Cooling Corsair H110i GT
Memory 4 x 4GB GSkill 2133
Video Card(s) R9 Nano x 2
Storage Seagate Barracuda 2TB
Display(s) LG 34UM88
Power Supply EVGA G2 750
Mouse Gigabyte M6580
Keyboard Azio
Your mobo - https://www.asus.com/au/Motherboards/ROG-MAXIMUS-VIII-HERO-ALPHA/specifications/
has -
"Expansion Slots
2 x PCIe 3.0/2.0 x16 (x16 or dual x8, +gray)
1 x PCIe 3.0/2.0 x16 (x4 mode, +black)
3 x PCIe 3.0/2.0 x1"
You said " I intentionally installed the gpu in PCI x8 slot" - there is none. You will only have 2 x8 slots with 2 cards in them.
Usually the first slot only will, with one card, be x16. But the wording doesn't say that. You have two slots that will (most likely) be x16 with just one card in it.
Would both of them result in "cover my ROG LED" if you used them? If not, try the x16 slot that won't.
Noob Makes PC
12 (0.00/day)
when you inserted the card in the top pcie 16 slot did it click in place?
also what does the gpu info page in the bios say
page 130 of the manual
http://dlcdnet.asus.com/pub/ASUS/mb...2_WEB.pdf?_ga=1.65162599.876308345.1471930507
has -
"Expansion Slots
But when I installed my card into second PCIe Slot, It runs at x8 so I guess My mobo only has 1 pcie x16 slot
It did go to 3.0 when playing games, And surely that guys is enjoying his We3d.
82 (0.03/day)
Melbourne
Processor i7 3930k
Keyboard Azio
Noob Makes PC
12 (0.00/day)
Toothless
9,788 (2.44/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
@Noob Makes PC Try not to multipost. You can quote more than one person in a single post. Double/triple posting is against forum rules.
Now when you say it runs at 3.0, that's what it should do. Go to 1.1 on idle and 3.0 under load.
82 (0.03/day)
Melbourne
Processor i7 3930k
Keyboard Azio
So looks like your choice is x16 or led ROG logo with x8.
Noob Makes PC
12 (0.00/day)
Sorry about that,
Anyways, The problem is not that what you understood, My card is running at x1 rather than at x16
Take a look at the photo attached.
Exactly!
