- May 8, 2023
- 65 (0.08/day)
I have a Gigabyte RTX 3070 with a Phanteks Revolt Pro 1000w; more than enough for everything in my PC. anyway, I've monitored my GPU Rail Voltages and their behaviors, and noticed something with the PCIe 12v Input Rail Voltage (with HWInfo of course) while playing Destiny 2
normally my PCIe 12v Voltage is 12.050v; however, once my Power Consumption exceeds 100 watts, the GPU Voltage will increase above 1v, which will then cause the PCIe 12v Input Rail Voltage to droop down to 11.86-11.89v (the exact number can vary but that's the range it always falls to once the GPU Voltage is greater than 1v)
the lowest number I have seen while gaming (Destiny 2) is 11.856v, but 9 times out of 10, the voltage of the PCIe rail will be 11.887-11.89v; sometimes it drops briefly or sometimes it will linger there for a few seconds, depends on how long the voltage remains above 1v, which usually isn't too long
it's absolutely within ATX spec for sure, and yes "software can be inaccurate", but let's assume it's telling the 100% truth right now about these GPU Rail Voltages. is this voltage droop too much on the PCIe 12v Input Rail? 12.05v to 11.86-11.89 (with an absolute minimum of 11.856) after exceeding 100 watts...I've heard you should never drop more than 0.2v on the line under load and 12.05 - 0.2 is 11.85, so I'm confused and concerned?
under benchmarks with highest settings, at 230w, the PCIe line has always been observed at 11.80-11.85v during the benchmark, for further context. so I haven't really universally gone below 11.80, or at least below 11.879 on the PCIe even at max wattage on the card, and that's not really my realistic gaming power consumption. also the 8-pin and 6-pin voltages never sag that far in my games either; they're always fairly stagnant at 12.0v and 12.1v
