PCIe 4.0 running at x8
solrac87
2 (0.00/day)
Hi there,
I just build a new pc with these specs:
CPU: 5700x
GPU: 6650xt
Motherboard: gigabyte B550 AORUS Elite V2 ( latest bios )
Ram: 32GB ddr4 3600
SSD: Samsumg 980 nvme m.2 and another one for windows ( sata 3 )
PSU: corsair rm650 Gold
As you can see the PCIe is running at x8 instead of x16
What I've tried so far:
  1. Disconnect everything from the motherboard but CPU + GPU + Memories and check bios info, nothing still x8
  2. In the BIOS change PCIe from auto to Gen4 or Gen3 or the followings... no luck at all
  3. Rollback BIOS update, no bueno.
  4. Disconnect the GPU clean all the pins and pcie slot, nothing.
And yes the GPU is connected to the correct PCIe slot ( the closest to the CPU ).
Any ideas ? thanks in advance
9,658 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Is that other SATA drive M2?
1,075 (0.72/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Radeon RX 6650 XT is connected to the rest of the system using a PCI-Express 4.0 x8 interface. Because this is all it has been wired to do. Look at the PCB.
200 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
3x0
973 (1.15/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
The 6650XT is a x8 Gen4 native card, not x16.
Welp, got ninja'd :D
solrac87
2 (0.00/day)
o_O
I´m seeing now, I´m coming from nvidia GPU which was pcie 3.0 at 16 so I thought that I had some problems with lane sharing, my bad!
Thank you all!
