pcie power output
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
What is the max power(watts) output of an pcie 1.0 x16 slot?
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
75w if i remember correctly.
Athlon2K15
HyperVtX™
7,909 (1.17/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
cadaveca
My name is Dave
17,238 (2.48/day)
PCI-E 1.0 is 60w.
A standard height x16 add-in card intended for graphics
applications must, at initial power-up, not exceed 25 W of power dissipation, until
configured as a high power device, at which time it must not exceed 60 W of power
dissipation.
Devices draw power from 12v and 3.3v, and cannot exceed 75w between the two.
specks
440 (0.09/day)
Software WinXp
how about for pcie 2.0 x16?
cadaveca
My name is Dave
17,238 (2.48/day)
Same thing, as far as I know, added 8-pin for high-power spec(where the actual power increase comes from) and the speed increase. There's something about PCI-E cabling(for server-type stuff), the automatic speed and link-width dynamic chages for power saving, and other such stuff unrelated to this conversation.
specks
440 (0.09/day)
Software WinXp
So does this mean that slot powered gpu's like(my)hd4670 can only draw a max of 60watts from the pcie slot?
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
no, its 75W from the slot, some being 3.3V and some being 12V. thats the most any PCI-E card can use, graphics or not.
specks
440 (0.09/day)
Software WinXp
So still, it cannot consume more than 75 watts from the slot alone?
Mussels
58,412 (7.78/day)
Oystralia
it CAN, but not at default settings. if you overclock it can use more than that, for example.
specks
440 (0.09/day)
Software WinXp
So say if the card is under load(overclocked or not)and it should be able to consume for example 100watts then can the slot give out 100watts?
Mussels
58,412 (7.78/day)
Oystralia
no. no card would ever be sold that breaches the 75W limit from the slot. this is why most cards have external power.
if it went over that 75W limit, things could get screwy. wiring overheating, voltage drops to other devices powered from the mobo, etc. there is a hard limit that all PCI-E devices must adhere to.
specks
440 (0.09/day)
Software WinXp
In this case, the card can only use 75watts under normal clocks and more power if overclocked?
Are the power outputs of pcie 1.0, 1.1, 2.0 and 2.1 still 75watts?
Mussels
58,412 (7.78/day)
Oystralia
Yes, but things can go wrong if you do so.
no. as the standards go up, they boosted the power via the external cables.
specks
440 (0.09/day)
Software WinXp
Mine is overclocked and all is fine. :D
What i mean is the max power of the slots alone disregarding the external power cables. Do you know what is the max of the pcie 2.0 x16?
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
its 75watts (from the slot itself. a combination of 60 watts from 12volt and 15watts from 3.3volt according to cadavas post) as has already been said MANY times.....
yes im sure you can pull more then 75 watts out of the slot if you tried too, however im sure bad things will start to happen at some point.
there has been threads on here with people showing Burnt ATX 24pin power cables from pulling too much power from multiple PCI-E slots.
EDIT:
http://www.pcisig.com/developers/ma...c_id=b590ba08170074a537626a7a601aa04b52bc3fec
Page 39 and 41 should give you some clear numbers of what PCI-E can provide power wise.
link borrow from Mussels :D
95Viper
Super Moderator
13,306 (2.20/day)
A little light reading, look at layout pages 10, 11, 12, and 13 for answer to your question.
PDF here and zip file download of PCI Sig's PCI Express 1.1 Mechanical Form Factors.
Mussels
58,412 (7.78/day)
Oystralia
its been said many times. 75W for slot, rest from external cables only. as the standards went up the slot power did not change.
cadaveca
My name is Dave
17,238 (2.48/day)
It is possible to push 150w out of one PCI-E slot, on some motherboards. Some can push 300w over 4 slots, however, most often, these boards feature an additional power plug just for the slots.
Many board, however, that come out long ago, cannot even supply enough power over PCIe for 3x VGA....we had guys modding extra wires from PSU, as multiple cards would blow the 24-pin. Also, you'll find the new ASUS Black X58 board features MANY ways to add power to PCIe slots.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Thats not true, W1z reviewed one a while ago that did exactly that. I think it was a GT240 that pulled something like 85w maximum through just the slot. I also believe a lot of those G92/G94 based "Green Edition" cards exceeded the PCI-E spec as well.
The standard for 1.1 and 2.0 are both 75w, but the slot will really give whatever is asked of it. However, going over the 75w can lead to some pretty nasty things.
specks
440 (0.09/day)
Software WinXp
EDIT:
I would appreciate it if you can give me a link to those burnt atx power cables. i'm just curious:D
Anyways, thanks to all for clearing things for me!:respect:
