Permanently disabling LED RGB lighting for MSI GPUs
1,260 (0.30/day)
Artem S. Tashkinov
I bought an MSI 1660 Ti GPU however 99% of the time I'm running it under Linux where there are no utilities to disable its LED RGB lighting.
Does anyone have an idea if and how I can disconnect/unplug something from the PCB without disassembling the whole thing (it will void the warranty) to disable LED RGB lighting permanently? I'm not a child with OCD to enjoy a Christmas tree under my table and there's no way I can cover the card properly (besides it will worsen the air flow).
370 (0.19/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Cooling Cyberdyne Superconduct SC5600
Memory 128TB QRAM
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) Multiple LG C9 3D Matrix OLED Cube
Software Skysoft Skynet
This? If so from the GURU teardown there seems to be 2 connectors for the LEDs. one at the top next to the white fan connector and one at the bottom. You should be able to unplug them without removing the shroud with a pair of pliers or something similar.
It's upside down here, you can see the black connector at the bottom, that plugs in next to the fan connector at the top. And at the top of the pic to the right is the other one that's at the bottom of the card.
Here you can see the 2 LED connectors so you know where to look behind the shroud. Top one again just next to the white fan connector and bottom one near the end of the card.
Hopefully they are just pull out ones and there's no retaining clip.
19,371 (3.57/day)
Without taking it apart, no idea. I do not know where the LED power/data plugs into the board as opposed to the fans. Maybe look at a TPU review of the PCB and see?
9,900 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
have you checked the pcb? since it uses 2 fans, it should be one connector for fan and one for light effect
9,900 (1.85/day)
Jakarta, Indonesia
Case Icute Super 18
what about using tweezer
juhaj
1 (0.00/day)
That's good, i am also going to buy it.
