Phanteks Announces New PSUs, 12VHPWR Adapter Cable, and Glacier One T30 Gen2 AIO Cooler
47,194 (7.56/day)
Phanteks is proud to announce their latest power supplies, the Revolt SFX 850 W Platinum PSU and AMP 1000 W Gold V along with the 12VHPWR PCIE GEN5 Adapter Cable compatible with AMP and Revolt Series PSU (rated 850 W and higher) to unlock the power of next-gen Graphic Cards. Also releasing today is their second generation of Glacier One T30 AIO liquid cooler. The Phanteks Revolt SFX 850 W is ready for the most powerful next-gen hardware in a super-compact SFX footprint. It was built according to the new Intel SFX12V 4.0 platform specifications, which mirror the ATX 3.0 specifications, and comes with native PCIe Gen 5 12VHPWR support out-of-the-box. The high efficiency, 80 PLUS Platinum certification guarantees 92% efficiency at 50% system load.
In collaboration with Seasonic, Phanteks AMP Series are high quality 80 Plus Gold Certified power supplies. The fully modular power supplies provide users with clean and great cable management, flat ribbon cables and includes a 12VHPWR cable for compatibility with next-gen GPUs. The 120 mm Fluid Dynamic Bearing Fan can be temperature controlled in Hybrid Fanless mode for ultimate silent performance.
Our 12VHPWR PCIe Gen 5 Adapter cable has been crafted with high-quality materials, such as high current terminal connectors and 16AWG wires to ensure safe usage with new ATX 3.0/PCIe 5.0 specifications. The new cable is compatible with our AMP and Revolt series PSU rated 850 W and higher. The 12VHPWR PCIe Gen 5 Adapter cable will be available in black and white.
Glacier One T30 AIO
The Phanteks Glacier One T30 Gen 2 is a high-end all-in-one liquid CPU cooler, capable of cooling powerful CPUs while operating silently. The T30-120 fans offer the ultimate in performance, quality, and flexibility. They are made of glass fiber reinforced Liquid Crystal Polymer, feature a 3-phase motor and multiple fan modes for the best performance in any scenario. Powered by Asetek's Gen 8 pump and a 30 mm thick radiator, the Glacier One T30 Gen 2 AIO models bring high-end cooling performance. Installation is a breeze thanks to the pre-filled all-in-one solution, flexible braided tubing and the Tube Clips that help routing the tubing and fan cables.
The Glacier One T30 Gen 2 features an infinity mirror pump cap design with a tempered glass window, anodized aluminium covers and integrated D-RGB lighting. Simply connect it to a D-RGB equipped Phanteks chassis or motherboard to control, sync and expand your lighting setup.
Availability: From March 2023.
Pricing (MSRP), USD:
  • Revolt SFX 850 W Platinum: $199.99
  • AMP 1000 W V2 Black: $169.99
  • AMP 1000 W V2 White: $179.99
  • 12VHPWR PCIe Gen 5 Adapter Cable: $19.99
  • Glacier One 240T30 Gen 2: $189.99
  • Glacier One 360T30 Gen 2: $259.99
2,201 (1.26/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
In the age of atx 3.0 they're only offering a single 850w unit, with no info as to the OEM. But they're releasing a new 1000w Seasonic based unit. Neither will make inroads at their current placement. They should have gone 1000w with their atx 3.0 unit. With the right OEM, they would have sold truckloads.
3,343 (2.08/day)
System Name Mean machine
Processor 12900k
Motherboard MSI Unify X
Cooling Noctua U12A
Memory 7600c34
Video Card(s) 4090 Gamerock oc
Storage 980 pro 2tb
Display(s) Samsung crg90
Case Fractal Torent
Audio Device(s) Hifiman Arya / a30 - d30 pro stack
Power Supply Be quiet dark power pro 1200
Mouse Viper ultimate
Keyboard Blackwidow 65%
Finally, they released a 360 aio powered by T30!
273 (0.10/day)
Processor Intel i5-13600k
Motherboard MSI MEG Z690i Unify
Cooling Noctua NH-C14S
Memory G.Skill Ripjaws V F5-5600J2834F32GX2-RS5W 64GB
Video Card(s) Asus RX6800XT TUF
Storage Samsung 980 Pro 500GB x2
Display(s) Samsung U32H850
Case Streacom DA6 XL chrome
Audio Device(s) Denon PMA-50
Power Supply Corsair SF750
Mouse Logitech MX Master 3
Keyboard Microsoft Surface
Software Win 11 Pro
360 pricing is bonkers
152 (0.10/day)
Processor I7-6900K @ 4.2ghz 8c/4.3ghz 2c
Motherboard GA-X99-Ultra Gaming
Cooling Liquid Freezer II 240
Memory 32GB G.Skill @ 3200 15-17-17-34
Video Card(s) RTX 3080 12GB FTW3 Ultra Hybrid
Storage 1TB P31 NVMe and 2x 1TB S31 SATA
Display(s) CU34G2X and Ea244wmi
Case 5000D Airflow
Audio Device(s) Sound Blaster X4
Power Supply SuperNOVA 850 G+
Mouse G502 HERO/G700s
Keyboard Ducky Shine
Both AIOs are almost comedically overpriced given that you can buy an Arctic Freezer II 240/360 for ~$100/140 plus T30s for $60/90 thus saving ~$30 and likely getting better performance.
68 (0.05/day)
Yep and the arctic's have vrm cooling and a thicker core. You won't be able to plug the fans into the integrated fan controller because the amperage is too high, but that's what I'm using to great success. Got a refurb for 70 bucks back when they updated the gasket last year.
4,559 (0.93/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
It's a SFX unit, most SFX units are 550w to 750w. Corsair lists their highest power SFX unit at 750w as does Seasonic so 850w is a lot of power for a SFX. Seasonic made their 750w revolt and has been Phanteks go to OEM so there is a pretty good shot they also make the 850w.
19 (0.00/day)
Each 8-pin connector can draw up to 150 watt, then how come 2 connectors can drag 600 watt?!?
152 (0.10/day)
Case 5000D Airflow
You're looking at the part that plugs into the PSU which just means the ports on the PSU are capable of 300W. The number of pins don't necessarily limit capability for example EPS12V for CPU power is also an 8 pin connector, but it's rated at 300W.
19 (0.00/day)
Brother man, you do make sense in some sort of knowledge .. BUT... 16ga wire can only handle up to 13Ah in perfect world, so 13ah x12v =156 watt per connector. And I understand what you're saying, that power supply can produce even more... But for all that power, it will be impossible to be squeezed through this 16 gauge wire. It's like trying to squeeze all the water pressure of Hover's dam, through garden water hose, expecting same amount of output, versus man height pipes. Make sense?
152 (0.10/day)
Case 5000D Airflow
PCIe 8 pin has 3x 12v wires and EPS12V has 4.
19 (0.00/day)
I agree but what does it have to do with achieving 600 w. As you know lots of companies making 8pin x 4 to sustain 600 advertising watts with new NVIDIA plug. White bother if you can go with 2 then. Marketing... all I can say
3,343 (2.08/day)
Processor 12900k
Cooling Noctua U12A
Memory 7600c34
Storage 980 pro 2tb
Case Fractal Torent
You are confusing the connectors coming from the PSU with the ones leading to the GPU. The latter are rated for 150w, the former can be rated for as high as the PSU designer made it out to be. Usually it's at 300w per connector..
See post above
