Phanteks Enthoo ATX Full-tower Chassis Now Available
47,304 (7.52/day)
Phanteks are very well known for their high-end cooling solutions, the Dutch design team created some of the best on the market but today we see the debut of their new ATX case the Enthoo Primo. The case sets accessibility and functionality levels of its own.
Dutch designers at Phanteks have created some of the best and most efficient coolers on the market today, well known for their unique looks and colour schemes. Today Phanteks debut their new case to the world, the Enthoo Primo - a case that sets a level of it's own and it's really a monster. When you are dealing with a company that specifically design coolers, you know the capability in a case will be above and beyond. The case has clean and elegant style, refined with aluminium front and top panels along with controllable LED lighting. The stealth interior covers the PSU, HDD and cables along with grommets (modular cable cover) for the most clean and sleek looking system.
For more installation flexibility, the internal HDD cases can be repositioned or removed which can also give unrestricted airflow. A closed HDD panel strengthens the chassis rigidity even when the cages have been removed. Drop-n-Lock brackets is a great feature which means SSD's can be installed on 3 different locations, the brackets are supplied with the case. For easy installation of cooling components the front and top covers can be removed along with dust filters that can be removed cleaned and reinserted with ease. Tidy cable management is always essential, the Enthoo has pre-installed management capabilities with tools behind the motherboard tray that can be fastened and released. LED ON/OFF switch is capable of controlling 4 additional LED fans and LED strips. The case has space for up to 2 PSU's.
Now we get to the cooling, and this is pretty special! Phanteks have hit the nail on the head with this and it would be expected from a company passionate about thermal solutions. The Enthoo has up to 16 fan mount locations (120mm / 140mm) and comes stocked with 5 of Phanteks's new PH-F140SP premum 140mm fans. The PWM hub will enable PWM functions to 3-pin fans. A max number of 11 fans can be connected to the hub. The thermally isolated PSU location directs heat away from critical components. Extensive watercooling can be supported in the case and support provides 5 different installation locations for thin and thick radiators from single all the way to quad along with clearance for push-pull fan configurations. The case has innovative liquid cooling mounting systems which include:
  • Radiator brackets allows for easy installation (bottom and side).
  • Modular cable cover with pre-drilled holes for mounting reservoirs.
  • Rear reservoir mounting location.
  • Universal pump bracket with vibration dampening function.
Case specifications
  • Dimension: 250 mm x 650 mm x 600 mm (W x H x D)
  • Form Factor: Full tower
  • Material(s): Aluminum faceplates, Steel chassis
  • Motherboard support: ATX, EATX, mATX, SSI EEB
  • Front I/O: 2x USB 3.0, 2x USB 2.0, Mic, Headphone,
  • LED switch
  • Side window: Yes, split-window design
Expansion & Drive Bays
  • Expansion slots: 8
  • Power supply slots: 2
  • External 5.25": 5
  • Internal 3.5": 6 (2x 3HDD cages)
  • Internal 2.5": 12 (2x 3HDD cages + 2x doublestack SSD brackets*expandable to 3x)
For more information, and to purchase, visit this page. Price: £199.99.
9,910 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
groove on one side, oh no thanks..
make it symmetric first
962 (0.17/day)
Currently somewhere around NSW, Australia
System Name hmmm... / lappy (ASUS Scar III)
Processor Intel Core i7-8086K / Intel Core i7-9750H
Motherboard ASUS Maximus XI Formula / ASUS G531GW
Cooling Noctua NH-D15s w/ 2 x Noctua NF-F12 PWM Chromax and 1 x Noctua NF-A15 HS-PWM Chromax Fans / Stock
Memory 4x16gb G.Skill Trident Z DDR4 3600mhz / 2x16gb Kingston Hyper X Impact DDR4 2666mhz C15
Video Card(s) 2 x EVGA GTX 1080 TI FTW3 / Nvidia RTX 2070 8gb
Storage 2 x Samsung 960 EVO Plus 1tb NVME/ 1tb Intel SSDPEKNW010T8 NVME + 2tb Samsung 860 EVO SSD
Display(s) Acer Predator X34P / ASUS 15.6" Screen
Case Fractal Design Meshify S2 White-TG + Noctua Chromax Fans / ASUS Scar III Case
Audio Device(s) Onboard + Logitech Z623 / Onboard
Power Supply Seasonic Prime Ultra Titanium 1000W + PROLINK PRO903WS / ASUS ADP-230GB B Power Brick
Mouse Corsair Vengeance M65 PRO RGB / Logitech MX Anywhere 2S
Keyboard Corsair K70 LUX RGB / ASUS Scar III Keyboard
Software Windows 10 Professional x64 / Windows 10 Professional x64
I like it. Time to wait for a review. I do hope it becomes available here.
2,025 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
I like it too,...
Unfortunately I've been looking for a case that can support 9 or more 5.25" bays and this isnt it. I'm starting to think they dont make that type of case anymore,...
But yeah, like the vertical lower PSU location and additional rear fan space,...
146 (0.03/day)
I like it too,...
Why in the world do you need 9+ 5.25" bays? Newegg carries several cases with 9, 10, and 12 5.25" bays.
9 5.25" bay cases
10 5.25" bay cases
12 5.25" bay case
I've read good things about the Xigmatek Elysium (12 bay case) if you're willing to go with the "Super Tower" form factor, though the front panel aesthetic isn't for everyone.
Case Labs also sells several highly-customizable all-aluminum enclosures that have "flex bays" in the front. Natively they are 5.25" bays with covers but you can buy accessories to mount 3.5" drives, card readers, radiators, fans, and reservoirs in them. They're higher-end cases than your standard steel/plastic enclosure and cost a bit more as a result.
http://caselabs-store.com/
43,609 (6.48/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
That's a good looking case. :)
1,585 (0.28/day)
Los Angeles/Orange County CA
System Name Vulcan
Processor i6 6600K
Motherboard GIGABYTE Z170X UD3
Cooling Thermaltake Frio Silent 14
Memory 16GB Corsair Vengeance LPX 16GB (2 x 8GB)
Video Card(s) ASUS Strix GTX 970
Storage Mushkin Enhanced Reactor 1TB SSD
Display(s) QNIX 27 Inch 1440p
Case Fractal Design Define S
Power Supply Cooler Master V750
Software Win 10 64-bit
To emphasize what others have said.
I LIKE it!
274 (0.05/day)
Unknown
System Name ASAS
Processor Intel Core i5 2500K @ 4.2 GHz
Motherboard Gigabyte GA-Z68A-D3-B3
Cooling Scythe Ashura
Memory Patriot 2x4GB DDR3 1600MHz 9-9-9-24 T1 @ 1.5V
Video Card(s) MSI GeForce GTX 770 2GB Gaming
Storage Samsung 830 256GB + Samsung Spinpoint T133 HD400LJ 400GB
Display(s) Samsung SyncMaster EX1920
Case Bitfenix Ghost
Audio Device(s) Realtek ALC889
Power Supply Seasonic S12II-620 Bronze 620W
Software Windows 7 Ultimate 64-bit SP1
Looks TERRIBLE
12,062 (2.60/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
I really like this case, except for that big fat annoying panel covering the drive bays and 5.25 bays. Id rather that were completely removed and I could at least remove the whole bottom half of that area, similar to the switch 810 or corsair C70. Then this case would be perfect. Air 540 is still my favorite case so far though.
1,585 (0.28/day)
System Name Vulcan
Processor i6 6600K
I think a lot of people are taking a superficial glance at this case and not looking at the innovative design and water cooling possibilities.
365 (0.07/day)
Gorgeous case. The internal drive faceplate seems a little odd, but I like the side-oriented PSU at the bottom to make room for a 120mm.
3,145 (0.65/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
Wow this is an impressive piece.
At a first glance it makes me think at a watercooled, silent yet powerful system powered by a couple of 520W fanless PSUs.
Deleted member 24505
Very nice case, nice clean looking interior, not sure on the groove, but I could live with it.
2,070 (0.39/day)
System Name iJayo
Processor i7 14700k
Cooling Pearless Assasi
Case O11 mini
Power Supply LIan li 750 mini
Mouse corsair Dark Saber
Keyboard Roccat Vulcan 121
Software Window 11 pro
nice to see some tasteful outside of the box thinking
2,074 (0.46/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
This case is sweet! I was thinking it was just another $100 case, going by the looks, but when I saw the specs, I took a closer look. For water cooling this might top even the 900D, and the way everything fits together like a Chinese jigsaw puzzle makes more efficient use of space without sacrificing anything. A lot of skull sweat went into this design. Check out the great videos on the Phanteks website; http://www.phanteks.com/#&panel1-1&panel2-1
MxPhenom 216
ASIC Engineer
13,012 (2.49/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
That is one sweet case. Holly shit ballz!
Can't wait to see some sweet water cooled rigs in this.
Wouldn't mind seeing a TPU review of this.
MxPhenom 216
ASIC Engineer
13,012 (2.49/day)
Loveland, CO
Looks like it could get pretty cramped inside though.
2,516 (0.47/day)
Canada
Groovy!
See what i did there? :p
Nice case, well thought out. Looks like buttloads of room behind the MoBo tray ;)
I don't like the price :eek: $150CAD pl0x :)
944 (0.20/day)
Slovenia
System Name PC.
Software Windows7 64....
Realy best build case i ever see .Many can learn how to use space.:respect:
432 (0.09/day)
Processor Intel i9-9900k @ 5GHz
Motherboard Gigabyte Z390 Aorus Pro Wifi
Cooling ThermalTake Riing 240
Memory 2x8GB G-Skill 3600 CL19 @ 16-19-19-20
Video Card(s) Zotac RTX 2060 Amp!
Storage 2x Samsung 860 Evo 512GB, 4x Seagate 8TB
Display(s) 2x Dell U2713H
Case CoolerMaster M500P
Power Supply ThermalTake Toughpower 730W
I hope there's a no-window option.
