- Jan 12, 2007
- 2,276 (0.35/day)
- Cairns QLD, Aussie
System Name | GaMEr / HTPC |
Processor | FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD) |
Motherboard | 990FX-UD5 / GA-MA785GPMT-US2H |
Cooling | XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma |
Memory | 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T |
Video Card(s) | 3gb HD7950 / Onboard |
Storage | 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens |
Display(s) | 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD |
Case | LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC |
Audio Device(s) | OB / Auzentech cinema 7.1 |
Power Supply | TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan. |
Software | 7 Ult / 7 premium x64 |
Specs:
Phenom 9550 B3
GA-MA780GM-S2H
4gb G-Skill PI series 1066mhz
2 x 640gb WD's RAID 0
HX520 modular psu
NH-C12P cpu cooler
2 x 120mm fans
80mm fan cooling Hdd's
Samsung 2232BW 22" Monitor
Microsoft 6000 laser mouse/kboard
Mods:
Only minor mods atm. Cut 1 of the cd drive bezels to allow psu cable through to tidy up wiring. painted 120mm fan bracket black. still have matching black ally dvd drive cover to mod and fit. Did have a swiftech water cooling setup in it but the pump was to noisey, RMA'd it for the NH-C12P. Sleeved all wiring with black snake skin and mounted all fans on anti-vibration mounts.
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1801%2F1_275_208.jpg&hash=474d9c24433dac2b162e9e9133a3e9c6)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1801%2F2_275_208.jpg&hash=5f7f176b6c16ef63d58ecbc1d4fc5a79)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1801%2F3_275_208.jpg&hash=50744a73c8bedacf997ea3d0e1d21896)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1801%2F4_275_208.jpg&hash=3be3de9f19dafc7059f6c37379fbf562)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1801%2F5_275_208.jpg&hash=87ea8d3373ffb4b2d25e94c716987949)
Specs:
Phenom 9550 B3
GA-MA780GM-S2H
HX520 modular psu
NH-C12P cpu cooler
2 x 120mm fans
Mods:
