Philips Announces the Brilliance 272P7VUBN Monitor: 27" 4K, IPS, 60 Hz, 5 ms, 350 nits - $349
Raevenlord
3,755 (1.21/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
After introducing a 32" Brilliance monitor some time ago, Phillips is now bringing another lowcost 4K monitor that boasts a very impressive feature/price ratio. The new Brilliance 272P7VUBN monitor cuts the diagonal on the previous release to 27", but maintains most other specs, including the 4K resolution (with the expected increase in pixels per inch to 163) and the same IPS panel. The monitor remains just shy of a HDR 400 rating (350 nits maximum) and keeps the 60 Hz refresh rates and 5 ms response time, but those are features that are well in-line with casual gamers who want to make the move towards a higher, 4K resolution. Besides, the 60 Hz refresh rate is likely the best one to take advantage of with the current crop of graphics cards on the market - at least for the most recent and demanding titles.
The panel features a 178º angle of view and 1.07 billion colors reproduce 122% of the sRGB color gamut as well as 103% of the NTSC color gamut. The Brilliance 272P7VUBN also ships factory-calibrated to a Delta E < 2 accuracy. Height, tilt, and swivel are available, as well as a 90 degree rotation capability. I/O stands at 1x DisplayPort 1.2, 1x HDMI 2.0a, 1x USB Type-C (with DP 1.2, 65 W PD, data), as well as a 2-port USB 3.0 hub and 1x 3.5 mm headphone port.
17,671 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Display(s) 27" QD-OLED Glossy 240hz 1440p
Case NZXT H710 (Red/Black)
I doubt it actually measures that well out of the box, Phillips blows a lot of smoke last few years in my experience
274 (0.10/day)
Wont be long now to see if your statement blows or not. Reviews will tell truths, not just negative or positive speculation.
