Phillips Releases Energy Efficient 272B1G Monitor: 27" IPS, 1080P, 75Hz
1,519 (0.84/day)
The recently announced Phillips 272B1G monitor features a 27 inch IPS 1080P screen, with a 4 ms (Grey to Grey) response time, 250 nits brightness, 1000:1 contrast ratio, and 76% NTSC/98% sRGB coverage. The IPS panel allows for wide viewing angles of 178º (H)/178º (V) and comes with an anti-glare, 3H, Haze 25% coating.
The monitor includes several energy-saving features such as PowerSensor and LightSensor along with a "Super-energy-efficient" design. PowerSensor uses an infrared sensor to detect the presence of a user and can automatically reduce screen brightness in the case of absence reducing power draw up to 70% while increasing monitor lifespan. The LightSensor feature uses a smart sensor to adjust the screen brightness depending on the light conditions in the room.
The monitor features an Energy Star 8.0 certification and an A++ energy grade thanks to its internal power supply which was chosen for its high efficiency paired with the low power W-LED backlight system. The rear of the monitor also includes a "0 watt hard switch" which cuts all power to the monitor resulting in zero power consumption.
The monitor features a healthy selection of I/O including HDMI 1.4, DisplayPort 1.2, DVI-D, and VGA (only HDMI & DisplayPort support 75Hz operation). The monitor comes with a pair of 2W speakers along with audio passthrough capability for easy access, also included is a four-port USB 3.2 hub with one fast charge B.C 1.2 port. The included SmartErgoBase allows for 150 mm height adjustment, ±90º pivot, ±180º swivel, and tilt (-5º-35º). The monitor also features a 100x100 VESA mount for custom mounting.
14,397 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Lol at the "0 Watt hard switch"
My house is full of them.
182 (0.09/day)
Processor Ryzen 3600 / intel i7 11800H
Motherboard MSI X470 Gaming Plus Max / whatever's in razer blade 15 2021
Cooling stock noisy AMD wraith cooler / noisy razer blade fans
Memory Corsair Vengeance RGB Pro 16GB DDR4-3200MHz / Samsung 16GB DDR4-3200 so dimms
Video Card(s) Sapphire Nitro RX580 8GBs / nVidia Geforce 3070 mobile
Storage Adata Gammix S11 Pro 1TB nvme / Kingston KC3000 2TB
Display(s) Gigabyte M32U
Case Corsair Caribide Air 540 / Razer Blade 15 2021 laptop
Mouse anything with optical switches
I love how Philips is integrating windows hello compliant webcameras in a lot of their monitors, so I was a bit dissapointed to see this one doesn't have it. Seeing how the options for windows hello webcams is very limited, still (not even microsoft makes one. most options are either hugely expensive or from noname chinese makers) it's a great differentiator and selling point to put one on a monitor.
