- Dec 22, 2016
- 33 (0.01/day)
- Taiwan
Specs:
INTEL I9 9900KASUS ROG MAXIMUS XI GENENVIDIA GEFORCE RTX 2080 TiAPACER AS2280 M.2 SATA III 128GZADAK MOAB M.2 RGB HEAT SPREADERZADAK SHIELD RGB DDR4 3200MHz 16GB(8GBx2)ZADAK CPU WATER BLOCKZADAK MOAB II WATER-COOLED PCFSP DAGGER PRO 650W SFX PSUCOOLER MASTER MASTER FAN MF120R A-RGBMJ MOD CABLE
Mods:
Custom Internal structureCustom Spray paint Custom Cable
Hello everyone,Cooperation project with Nvidia TaiwanFallout76 game theme.I chose the Fallout 76 theme as Pip-Boy is instantly recognizable to gamers and the MOAB II PC case fits the Mark VI concept perfectly.It was my first time using 3D printing to make key elements of the Pip-Boy mod. Each of the 20 3D components took between 15 to 23 hours to print, plus the long time it takes to smooth out the prints using epoxy resin. Polishing required an additional two weeks, the painting took several layers, then finishing off with an oxidized metal finish to create a special ageing effect. I had to be incredibly patient. I also created the accessories with iron netting, leather and vacuumed light bulbs, which I custom-made, which took a further week or so. Taking into account UV printing and acrylic laser cutting, the project took me around 6 weeks to accomplish in total.
Specs:
Mods:
