Hello, recently figured out what Throttlestop was and decided to do an undervolt.
I have an i5-8250U laptop, Dell Inspiron 15 5579. I undervolted CPU core and cache to -135mv, and have the System auto fan speed set. At max fan speed, 5600RPM, and running the benchmark, the cpu slowly crawls its way, and as soon as it touches 100C, PL 1 limit kicks in and it is limited down to 15W at 2.7GHz, not at full boost, 3.4GHz. Any way to force it to run at full speed, or just thermal throttle instead?
More info: On the right in FIVR, it shows my offset is +0 on everything, even if i have -250mv on CPU core. Does this mean absolutely nothing is changing?
And also, I set my PL 1 limit to 35W, and it hits 35W but after like 5 seconds or so for some reason, PL1 limits power usage down to 20W even though my limit is set to 35W.
UPDATE: I downgraded my laptop bios to 1.12, from 1.13. This fixed the undervolting, so now it undervolts. But anyway, my CPU is able to go at 30W for like 5 seconds, but then PL1 limit kicks in, throttles it down to 15W and slows it down to 2.50GHz. I enable that patch everyone said to enable, and it now throttles it to 23W at 3GHz. Better, but not as good as I want, as I know this is capable of full turbo indefinitely. The cooler can handle it.
