Placa GTX 1050 ti FAKE 4GB DDR5 128Bits
demilton
2 (0.00/day)
Hello Guys, I would like to help you guys if you have the same problem I'm with a GTX 1050 card Fake, I searched here on the forum and in other places similar cases. GTS 460 card, GTX 550 ti, however none checking the card's chip or even ate the no model was similar to what I have. I have an eprom recorder and tried to install another bios but they didn't work. i own the backup of the fake save bios. in the photos I'll send the fake bios by the eprom recorder, as settings by gpu-z and the picture of the card.
164 (0.14/day)
System Name HAL
Processor AMD Ryzen 3700x
Motherboard ASRock B450 Pro4
Cooling AORUS Liquid 240
Memory 32GB Teamgroup 3200mhz
Video Card(s) EVGA 2060 GTX
If you are still around and have that card, post the bios here and I'll look at fixing it.
demilton
2 (0.00/day)
This is the bios that came on the board, there are several of the gtx550 ti.
please change the file extension to .bin
  • backup_bios.txt
164 (0.14/day)
System Name HAL
Do you have the original BIOS that came on the card? This isn't a fake, this is a BIOS from a 550 Ti.
41,426 (6.58/day)
164 (0.14/day)
System Name HAL
The goal isn't to use one from here, it's to edit his original to report the correct card type and ram, keeping the timings for whatever screwy memory & chips they've thrown together on it.
41,426 (6.58/day)
:rolleyes: Those all are the bios versions that match what was submitted by OP. I suppose you want to take up doing the bios mods for all these fake cards???
If you open that link and go to the 1050ti fake card you will see there are no timings specified, however you will see the video outputs, and then 1 or multiple of below samsung, hynix, micron, elpida memories. The same goes for any Nvidia bios.
164 (0.14/day)
System Name HAL
I suppose because it's not listed in the database here like the Radeon's you think the bios doesn't have timings for the specific chips?
Would you prefer to keep telling people to try random bios and maybe find one that works?
"Version" doesn't have anything to do with it. They mod the heck out of these things ,and half of them put some garbage version number that isn't real in there.
The file OP submitted is not from his original fake bios. It's a bios from a legitimate 550ti card. I can't do anything with that.
Given the one that originally came with the card, edit the card type to report correctly, edit the amount of ram to report correct, then adjust clock speeds if needed.
164 (0.14/day)
System Name HAL
To illustrate a point, here is a comparison of two of those files with the same "version" on that list. The nvidia one and the Yeston one. Both support Samsung, Elpdidia, and Hynix. Both have the same outputs. And yet, they are significantly different. When you consider how easily edited the version number is, it is almost meaningless on those chinese cards. I've seen some with a compile date in 2020 that had a version number that doesn't actually exist.
