please help. Asus EAX1950 Pro Want to know the location of Chip Bios.
surin26
16 (0.00/day)
I want to know the location of the Chip Bios Asus EAX1950 Pro that is where I saw Chip 8 legs are nowhere as many of them. Because it does more photos And without any bad when I plug into a PCIe slot, so I will try Connecting pins 1 and 8 will come together in the system.
Thank you
12,305 (2.32/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
WTF? That is awesome. I don't think you can fix that. Well lets say its not worth fixing
FreedomEclipse
~Technological Technocrat~
23,622 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
what thermal paste is that??? brown sauce? Or were you trying to trend with BBQ sauce?
Kursah
Super Moderator
14,701 (2.26/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Looks like the main GPU is toast if that picture is real. That = a dead card = replace. :toast:
surin26
16 (0.00/day)
I need to chip bios EAX1950 Pro. Its location The chip is
Please help Me
40,822 (6.55/day)
Ok the cards done. Go get a 3850/4670
1,980 (0.41/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Look for vbios chip: on the surface of the 8pin chip is inscribed/printed with its datasheet reference number Pm25LV010 [dot next to pin 1 with arrow pointing at it]
*Example:
upload high resolution pictures if require more assistance
Note: as other members of the TPU community have mentioned the VPU looks dead
atb
Law-II
Toothless
Tech, Games, and TPU!
9,450 (2.50/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard Asus Crosshair VIII Hero Wi-Fi
Memory 2x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I don't think that OP gets that they are trying to work with a dead card, if that is said card they're working with.
surin26
16 (0.00/day)
Hi
*Example:
atb
Law-II
Hi Thank you for your Law-II
I have upload high resolution pictures To see if it is a chip bios. (front card pictures 1, back card pictures 2-5)
1,980 (0.41/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi surin26
I have sent a pm to a friend of mine as I have been unable to double check the chip reference number on any of the sites I use to locate datasheets, I assume due to the vga cards age.
I am fairly sure which chip it is but do not want to second guess the information; my friend or I will get back to you in due course and let you know either way.
atb
Law-II
INSTG8R
Vanguard Beta Tester
7,991 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
"Fixing" the BIOS will not bring that card back. The GPU itself is toast, WELL Toasted...
surin26
16 (0.00/day)
Hi surin26
atb
Law-II
I waited
2,750 (0.46/day)
Minnesota
I have upload high resolution pictures To see if it is a chip bios. (front card pictures 1, back card pictures 2-5)View attachment 59189 View attachment 59190 View attachment 59191 View attachment 59192 View attachment 59193
None of the identifiable ones are the BIOS. It's possible that the top-right one in the last pic is the BIOS but the markings on it aren't searchable. That would make sense as none of the others are the BIOS and it's labelled as U2.
INSTG8R
7,991 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
That is beyond fixing
2,750 (0.46/day)
Minnesota
So I did a little more research. U2 is definitely the BIOS chip. Every other card from that generation for ATI used that location and U2 to label the BIOS chip.
http://www.hw-museum.cz/ looks to be a great resource for high resolution pictures of hardware if anyone's interested.
surin26
16 (0.00/day)
Thank you "Maban" A good data
I wait "Law-II" course back
INSTG8R
7,991 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
It SHOULD look like this. You see there are some components in that very burnt silicon that are gone...
INSTG8R
7,991 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
What type of special silicon is going to replace these? They're gone....
40,822 (6.55/day)
Surin that core of that gpu is cracked. The electrical traces and transistors are not in tact anymore. Stop fooling yourself, Move on and Get a 3850 or 4670.
