Please help decide on 850W PSU
22 (0.04/day)
Japan
System Name My PC
Processor AMD Ryzen 5 5500
Motherboard AsRock B550M PRO 4
Cooling NZXT T120
Memory Patriot Viper Steel RGB 2x16GB DDR4 3200
Video Card(s) XFX Radeon RX6600
Storage Samsung 870 Evo SATA SSD
Display(s) Pixio 23" PX248P 144Hz IPS
Case NZXT H6 Flow
Audio Device(s) Logicool G433 Gaming Headset
Power Supply DeepCool PQ850M
Software Microsoft Windows 10 Home
Hi everyone. Can you please help me decide which is the best selection for a 850W PSU? I have these 3 summed below and prices are almost identical. All lists under A tier according to the PSU Cultist List.
DeepCool PQ850M
Fractal Design ION Gold 850W
XPG Core Reactor 850W
Specs that will be powered:
AMD R5 5500 w/ stock cooler
XFX Radeon RX6600
2x8GB DDR4 3200
1TB SATA SSD
Notes:
- Will change case later and add case fans and aftermarket cpu air cooler
- Change SATA SSD to NVME
- May upgrade GPU down the road so I go 850W. Since I have 1080p 144Hz monitor so I don't expect myself to buy a super high end GPU
- May upgrade CPU down the road to a 5800X3D.
TIA!
18,584 (2.66/day)
System Name AlderLake
22 (0.04/day)
Japan
System Name My PC
Cooling NZXT T120
Case NZXT H6 Flow
I do not have that option on the local store. The PSUs listed are the ones readily available.
472 (0.10/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Generic
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
If they are all tier A on the list, the quality should be pretty much equal.
Did you already check all the reviews on them?
Maybe that will give you a preference. Length of warranty is normally also a point to consider.
Will it be visible in your build, than also take the 'looks' in consideration.
If you have only these three options, just go for the best according to the reviews. Aestatics should only be apliccable as they are quality wise comparible and for example you may want custom sleeved cables in the future. than check for which model these cables are available.
If you have patience and in your local store you can order a top model, it is a better alternative, provided the price is right according to your budget.
Whatever is advised here, you have to make the final deciscion :cool:
17,556 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
DeepCool PQ850M
XFX Radeon RX6600
2x8GB DDR4 3200
1TB SATA SSD
Notes:
TIA!
here is a review on the fractal design. i recommend looking up reviews for each of the PSU's and then you can go decide for yourself. toms hardware gives the Fractal Design a pretty mediocre score... so not good
18,584 (2.66/day)
I wouldn't buy a PSU with less then 10~12 years warranty.
455 (0.50/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
DeepCool PQ850M
Out of the 3, I would go with the XPG, then the Deep Cool. Both of these have 10 Year warranties.
