Please help me identify this fake GTX 1050 Ti
Carbon
5 (0.00/day)
Please help me identify this fake GTX 1050 Ti. Fortunately I received my money back, but would like to load the proper BIOS to see if its usable. Thanks...
The GPU is easily identifiable as a GF116, it has eight Samsung K4G10325FE-HC04 memory chips (4 on the front and 4 on the back.) The card was marketed as GTX1050ti 4GB 128 Bit.
40,435 (6.52/day)
Hmm 8 ram chips
cdawall
where the hell are my stars
27,680 (4.23/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
40,435 (6.52/day)
Carbon
5 (0.00/day)
Thanks and if it relevant the board has One DVI, one, VGA and one HDMI
40,435 (6.52/day)
With the ram chips being 8, typically 1024
Carbon
5 (0.00/day)
Thanks... I was thinking it’s 2Gb, since the ram chips are 1Gb with 32 bit structure according to the Samsung data sheet and with 8 chips in a 128 bit arrangement it might be a total of 2Gb?
40,435 (6.52/day)
Not with a GF 116
Carbon
5 (0.00/day)
So I decided to use the dos version of nvflash. I made a DOS bootable USB with that version of nvflash on it. I figured I would try to backup the fake BIOS from the Fake card first. However, I says no Nvidia card found. I exchanged that fake card for a known good XFX GT610, without changing my process, that is, did every step the same, with that card I can read the Eprom etc. Any ideas why I get no Nvidia card on the fake GTX1050?
Thanks...
712 (0.23/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
Thanks...
This video explains how to flash the correct BIOS. It seems you won't be able to do so with NVflash.
2,707 (0.79/day)
On The Highway To Hell \m/
1Gb(Gigabit) = .125GB(Gigabyte)
.125GB(Gigabyte) x 8 = 1GB(Gigabyte)
Carbon
5 (0.00/day)
Thank you all for your help! Its always fun to learn something new!
